C2
Revision as of 17:23, 8 November 2009 by Admin (talk | contribs)
Production era - September 1, 2002-2005
Order no. - 18 110.
Type - Compact 35 mm autofocus viewfinder camera with zoom lens.
Lens - 35–70 mm f/4.6–8.6 LEICA VARIO-ELMAR (7 elements in 6 groups).
Focus range - 0.6 m /2 ft < infinity. Smallest object field - 190 x 285 mm.
Autofocus system - Passive phase-detection multi-zone infrared autofocus.
Exposure control - Programmed automatic exposure control with automatic flash activation (Auto), flash on, flash off, Auto with stroboscopic pre-flash for red-eye reduction, Auto Slow (with longer exposure time)
Exposure metering - Center-weighted two-zone metering sensor with backlight recognition.
Memory - Focus is locked and metered value saved with light pressure on shutter release button.
Shutter speed range - 1/330 s < 2 s
Film speed setting - Automatic film speed setting for DX-coded films from ISO 50/18° to ISO 3200/36° ; Films without DX-coding and films with speeds under ISO 50/18° are set at ISO 100/21° ; Films with speeds over ISO 3200/36° are set at ISO 3200/36°.
Flash range with ISO 100 slide film - Wide-angle : 3 m (10ft) ; Telephoto : 1.63 m (5 ft 4") ; Guide number : 14 (46 ft)
Viewfinder - Real-image type zoom viewfinder with display of flash, autofocus and exposure metering symbols. 0.35 x with 35 mm to 0.67 x with 70 mm ; field of view is approximately 80 % of film format
Film transport - Automatic film threading and advance to first frame. Automatic rewind after last exposure. Midroll rewind possible.
Data imprinting - Integrated ; Imprinting of date or day and time.
Exposure series - The exposure series function is activated when the release button is pressed continuously.
Self-timer 10 sec. exposure delay.
Power supply - 3V lithium battery (CR 123A).
Body - Silver aluminum. Side attachment for carrying strap or wrist strap. Tripod thread A1/4 DIN 403 (1/4").
Weight - 240 g /8.5 oz without batteries.
Dimensions (W x H x D) - 121 x 66 x 39.5 mm /4 4/5x 2 5/8x 1 9/16 in.
Accessories - Leather case with belt loop, cable elease.
C2 Serial Numbers
SN Start SN End Product Year built Batch
2817001 2847000 Leica C2 2002 30,000
Inital assigned serial numbers 2002 only 30,000
Serial numbers from Serial Numbers Leica Cameras with computed batch total.
