F
| FARBA | ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
| FARLY | FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 | ca.1933 | - |
| FAROS | FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 | ca.1933 | |
| FARPU | ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
| FARUX | Panoramic tripod head | 1933-1936 | - |
| FASKI | FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 | ca.1933 | |
| FAVOO | No. 2 medium yellow filter; screw-on type H | ca.1935 | - |
| FAWAG | FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 | ca.1933 | |
| FAXIS | FARUX Scale ring for Elmar (I) f= 9 cm 1:4 | ca.1933 | |
| FAZOY | No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 | ca.1933-1938 | NY item |
| FBOOK | UVa filter; screw-on type H | ca.1935 | - |
| FBXOO | Panchromatic green no. 1 filter; screw-on type H | ca.1935 | - |
| FCKOO | Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 | 1951-1960 | - |
| FCOOI | No. 2 medium infra-red filter; screw-on type H | ca.1935 | - |
| FCZOO | No. 1 light infra-red filter; screw-on type F | ca.1931 | - |
| FDOOH | No. 3 dark infra-red filter; screw-on type G | ca.1935 | - |
| FEARM | Copy arm used with FESSA base and FEHUN column | 1931-19?? | - |
| FEDOO | No. 1 light infra-red filter; slip-on type A36 | ca.1931-1950 | 13040 |
| FEFFU | Copy base and column, used with FILUM arm and STALI lighting = FEPRO | 1931-19?? | - |
| FEHUN | Column support used with FESSA base and FEARM | 1931-19?? | - |
| FEOOG | No. 3 dark infra-red filter; slip-on type A36 | ca.1935 | 13050 |
| FEPRO | Copy stand with FEFFU base, column, FILUM arm and STALI lighting | 1931-19?? | used with front lenses 2 & 3, WICAP and WINKO |
| FESSA | Copy base used with FEHUN column and FEARM | 1931-19?? | - |
| FESTO | Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting | 1931-19?? | used with front lenses 1, 2 or 3, WICAP and WINKO |
| FGHOO | Replacement hood for Hektor f= 7.3 cm 1:1.9 | 1936-1946 | - |
| FGOOE | No. 1 light infra-red filter; screw-on type I | ca.1933 | - |
| FHKOO | Single film holder for I, II, III, IIIa, IIIb1 | 1935-1960 | - |
| FHOOD | No. 3 dark infra-red filter; screw-on type I | ca.1935 | - |
| FIAKU | Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate | 1926-19?? | - |
| FIALT | Holder for film handling during the development process | 1930's | - |
| FIAMA | Panoramic tripod head for 5 cm lens | 1926-19xx | - |
| FIARO | ? | 19xx-19xx | - |
| FIATE | ? | 19xx-19xx | - |
| FIAVI | ? | 19xx-19xx | - |
| FIBLA | ? | 19xx-19xx | - |
| FIBOB | No. 2 medium infra-red filter; screw-on type G | ca.1933 | - |
| FIBOS | ? | 19xx-19xx | - |
| FICAT | No. 1 light yellow filter; screw-on type F | ca.1930 | - |
| FICFA | Kodachrome type A filter; ADFIK 34 mm mount | ca.1949- | - |
| FICHR | Kodachrome flash filter; slip-on type A36 | ca.1949- | - |
| FICOM | No. 2 medium yellow filter; screw-on type F | ca.1930 | - |
| FICOR | Panchromatic green no. 2 filter; slip-on type A36 | ca.1945 | NY item |
| FICUR | No. 3 dense yellow filter; screw-on type F; | ca.1930 | - |
| FIDAY | Kodachrome type F filter; screw-on type L | ca.1959- | - |
| FIDAYMI | Kodachrome type A filter; screw-on type E39 | ca.1949- | NY item |
| FIDRI | ? | 19xx-19xx | - |
| FIEKT | ? | 19xx-19xx | - |
| FIFLO | Kodachrome photo-flood filter; screw-on type L | ca.1949- | NY item |
| FIFLOMI | Kodachrome photo-flood filter; screw-on type E39 | ca.1949- | NY item |
| FIGAM | No. 2 medium yellow filter; slip-on type A36 | ca.1931-1950 | - |
| FIGDA | ? | 19xx-19xx | - |
| FIGIL | Graduated Yellow filter; slip-on type C | ca.1931 | - |
| FIGON | ? | 19xx-19xx | - |
| FIGRO | No. 1 light yellow filter; slip-on type A36 | ca.1931-1950 | 13005 |
| FIGUN | No. 1 light yellow filter; ADFIK 34 mm mount | ca.1945 | NY item |
| FIHAZ | Kodachrome haze filter; screw-on type L | ca.1949- | NY item |
| FIHEL | No. 0 very light yellow filter; slip-on type A36 | ca.1933 | 13000 |
| FIIRL | ? | 19xx-19xx | - |
| FIKAT | Kodachrome type A filter; slip-on type A36 | ca.1949- | NY item |
| FIKHA | Kodachrome type A filter; ADFIK 34 mm mount | ca.1949- | NY item |
| FIKLO | Kodachrome photo-flood filter; slip-on type A36 | ca.1949- | NY item |
| FIKOZ | Kodachrome haze filter; slip-on type A36 | ca.1949- | NY item |
| FIKUS | ? | 19xx-19xx | - |
| FIKYB | No. 2 medium infra-red filter; slip-on type A36 | ca.1933-1950 | - |
| FILBY | No. 1 light yellow filter; slip-on type A | ca.1926 | - |
| FILCA | ? | 19xx-19xx | - |
| FILES | ? | 19xx-19xx | - |
| FILGE | No. 2 medium yellow filter; slip-on type A | ca.1925 | - |
| FILOY | ? | 19xx-19xx | - |
| FILPO | ? | 19xx-19xx | - |
| FILSO | No. 1 light yellow filter; slip-on type C | ca.1933 | - |
| FILTU | No. 3 dense yellow filter; slip-on type A | ca.1925-1926 | - |
| FILUM | Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO | 1931-19?? | - |
| FILXA | No. 3 dense yellow filter; screw-on type I | ca.1933 | - |
| FILYT | ? | 19xx-19xx | - |
| FIMOO | No. 0 very light yellow filter; screw-on type H | ca.1935 | - |
| FINON | ? | 19xx-19xx | - |
| FINOT | ? | 19xx-19xx | - |
| FINOW | ? | 19xx-19xx | - |
| FINUS | No. 3 dense yellow filter; screw-on type G | ca.1931 | NY item |
| FIOKO | UVa filter; screw-on type F | ca.1931 | - |
| FIOLA | UVa filter; slip-on type A36 | ca.1931 | 13055 |
| FIOMU | No. 2 medium infra-red filter; slip-on type C | ca.1933 | - |
| FIONA | ? | 19xx-19xx | - |
| FIOOC | No. 1 light yellow filter; screw-on type H | ca.1935 | - |
| FIOPY | No. 0 very light yellow filter; slip-on type C | ca.1933 | - |
| FIORE | UVa filter; screw-on type G | ca.1931 | - |
| FIOSI | UVa filter; slip-on type C | ca.1933 | - |
| FIOUX | FSEOO Orange filter; slip-on type A36 | ca.1939 | NY item |
| FIPAN | ? | 19xx-19xx | - |
| FIPHO | Kodachrome photo flood filter; ADFIK 34 mm mount | ca.1949- | NY item |
| FIPLO | No. 2 medium infra-red filter; screw-on type I | ca.1933 | - |
| FIPOS | Panchromatic green no. 1 filter; slip-on type A36 | ca.1933-1950 | 13015 |
| FIPPA | No. 2 medium yellow filter; slip-on type C | ca.1933 | - |
| FIQUX | Orange filter; slip-on type A36 | ca.1939-1950 | NY item |
| FIRAD | Graduated Yellow filter; slip-on type A36 | ca.1931 | - |
| FIRCO | ? | 19xx-19xx | - |
| FIREG | No. 1 light yellow filter; screw-on type I | ca.1933 | - |
| FIRGI | ? | 19xx-19xx | - |
| FIRHE | No. 1 light yellow filter; screw-on type G | ca.1931 | 13001 |
| FIRHU | ? | 19xx-19xx | - |
| FIRMY | No. 2 medium yellow filter; screw-on type G | ca.1931 | - |
| FIROL | ? | 19xx-19xx | - |
| FIRYX | Panchromatic green no. 1 filter; screw-on type I | ca.1933 | - |
| FISAP | Panchromatic green no. 1 filter; slip-on type C | ca.1933 | - |
| FISEX | ? | 19xx-19xx | - |
| FISKF | ? | 19xx-19xx | - |
| FISON | ? | 19xx-19xx | - |
| FISUM | ? | 19xx-19xx | - |
| FISUMMI | ? | 19xx-19xx | - |
| FITAF | ? | 19xx-19xx | - |
| FITWO | ? | 19xx-19xx | - |
| FIUNS | No. 0 very light yellow filter; slip-on type A | ca.1933 | - |
| FIVPL | |||
| FIWAS | No. 0 very light yellow filter; screw-on type I | ca.1933 | - |
| FIWET | UVa filter; screw-on type I | ca.1933 | - |
| FIWIG | No. 2 medium yellow filter; screw-on type I | ca.1933 | - |
| FIXIO | Panchromatic green no. 1 filter; screw-on type G | ca.1933 | - |
| FIXLA | ? | 19xx-19xx | - |
| FIXTA | No. 0 very light yellow filter; screw-on type G | ca.1933 | - |
| FKDELM | Kodachrome type F filter; slip-on type A36 | ca.1959- | - |
| FKDSAX | Kodachrome type F filter; screw-on type E58 | ca.1959- | - |
| FKDSMI | Kodachrome type F filter; screw-on type E39 | ca.1959- | - |
| FKDSMT | Kodachrome type F filter; screw-on type E41 | ca.1959- | - |
| FKDTEL | Kodachrome type F filter; screw-on type E48 | ca.1959- | - |
| FLASH | ? | 19xx-19xx | - |
| FLECT | ? | 19xx-19xx | - |
| FLOOA | ? | 19xx-19xx | - |
| FLOTH | ? | 19xx-19xx | - |
| FLQOO | ? | 19xx-19xx | - |
| FMOOZ | No. 1 light infra-red filter; slip-on type C | ca.1933 | - |
| FMSOO | No. 3 dark infra-red filter; slip-on type C | ca.1935 | - |
| FNOOY | No. 1 light infra-red filter; screw-on type H | ca.1935 | - |
| FNUOO | No. 3 dark infra-red filter; screw-on type H | ca.1935 | - |
| FODIS | ? | 19xx-19xx | - |
| FOFER | ? | 19xx-19xx | - |
| FOKAL | ? | 19xx-19xx | - |
| FOKIN | ? | 19xx-19xx | - |
| FOKOS | ? | 19xx-19xx | - |
| FOKUX | ? | 19xx-19xx | - |
| FONOR | ? | 19xx-19xx | - |
| FONOT | ? | 19xx-19xx | - |
| FOOBD | Graduated Green filter; slip-on type A36 | ca.1938 | - |
| FOOCR | Graduated Green filter; slip-on type C | ca.1938 | - |
| FOOKH | ? | 19xx-19xx | - |
| FOOMI | ? | 19xx-19xx | - |
| FOONW | FARUX Scale ring for Hektor 2.8 cm | ca.1936 | |
| FOOQL | FARUX Scale ring for Telyt 20 cm | ca.1936 | |
| FOOVA | ? | 19xx-19xx | - |
| FOOXB | Filter holder; slip-on type A36 | ca.1951 | 13365 |
| FOOXC | Filter holder; screw-on type L | ca.1951 | - |
| FOOXD | Filter holder; screw-on type E41 | ca.1951 | 13375 |
| FOOXE | Filter holder; screw-on type E58 | ca.1951 | 13380 |
| FOOXF | Filter holder; screw-on type E48 | ca.1951 | 13385 |
| FOOXH | Filter holder; screw-on type E39 | ca.1955 | 13371 |
| FOOXK | Filter holder; screw-on type E43 | ca.1959 | 13384 |
| FOSAR | ? | 19xx-19xx | - |
| FPKELM | Kodachrome type FP filter; slip-on type A36 | ca.1959- | - |
| FPKSAX | Kodachrome type FP filter; screw-on type E58 | ca.1959- | - |
| FPKSMI | Kodachrome type FP filter; screw-on type E39 | ca.1959- | - |
| FPKSMT | Kodachrome type FP filter; screw-on type E41 | ca.1959- | - |
| FPLTEL | Kodachrome type FP filter; screw-on type E48 | ca.1959- | - |
| FPOOW | Orange filter; screw-on type G | ca.1939 | - |
| FQOOV | Orange filter; screw-on type H | ca.1939 | - |
| FRCOO | Orange filter; screw-on type I | ca.1939 | - |
| FSEOO | Orange filter; slip-on type C | ca.1939-1950 | - |
| FTGOO | Orange filter; slip-on type A36 | ca.1939 | 13025 |
| FUECD | ? | 19xx-19xx | - |
| FUFIF | ? | 19xx-19xx | - |
| FUFOR | ? | 19xx-19xx | - |
| FULDY | ? | 19xx-19xx | - |
