WXYZ
WEISO | Mini-telescope viewfinder for Elmar f= 3.5 cm 1:3.5; black or chrome; early with flare | 1933-1950 | - |
WESTO | "Leicameter" exposure meter Weston model 650; large, black rectangular housing with chamfered corners | 1936-19?? | NY item |
WICAB | Copy accessory lens cap with a shoe for angular finder WINKO | 1936-1939 | - |
WICAP | Copy accessory lens cap with a shoe for angular finder WINKO | 1931-1935 | - |
WINKO | Angle viewfinder for Standard Leica (model E) early versions have a larger eyecup | 1929- | black or chrome |
WINTU | Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus | 1933-1948 | black or chrome |
WOOLD | Angle viewfinder for Standard Leica (model E) with additional interior prism | 1938-1950 | black or chrome |
WOOSU | Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus with additional interior prism | 1938-1948 | black or chrome |
WZCOO | Copy accessory lens cap with a shoe for angular finder WINTU for Leica II and III's | 1936-1939 | - |
XADEE | Special stand for dental photography using XBEET connector | 1939-19?? | - |
XBEET | Sliding connector with wingnut forfitting FOCOSLIDE to pillar stands LURTE or USII | 1939-19?? | - |
XDQII | Siding arm for rotating stage using ball bearings for positioning of camera | 1938-19?? | - |
XEMOO | Xenon f= 5 cm 1:1.5 | 1939-1950 | - |
XIOOM | Hood for Xenon f= 5 cm 1:1.5 chrome or black; folds flat; NY or Wetzlar | 1939-19?? | - |
XOFLA | Kodachrome type A flash filter; E41 mount | ca.1949-19?? | - |
XOOAM | Yellow no. 0 very light filter; slip-on type E | ca.1938 | - |
XOOAY | Kodachrome type A filter; E41 mount | ca.1949-19?? | - |
XOOBZ | Yellow no. 1 light filter; slip-on type E | ca.1938 | - |
XOOCN | Yellow no. 2 medium filter; slip-on type E | ca.1938 | - |
XOODA | Graduated yellow filter; slip-on type E | ca.1938 | - |
XOOFB | UVa filter; slip-on type E | ca.1938 | - |
XOOGP | Panchromatic green no. 1 filter; slip-on type E | ca.1938 | - |
XOOHC | Graduated green filter; slip-on type E | ca.1938 | - |
XOOIM | 106-7 | 19??-19?? | - |
XOOIO | Infra-red no. 1 light filter; slip-on type E | ca.1938 | - |
XOOKD | Infra-red no. 2 medium filter; slip-on type E | ca.1938 | - |
XOOLR | Infra-red no. 3 dense filter; slip-on type E | ca.1938 | - |
XOOME | Orange filter; slip-on type E | ca.1938 | - |
XOOMT | Yellow no. 3 dense filter; slip-on type E | ca.1938 | - |
XOONS | Lens hood for Summarit f= 5 cm 1:1.5 | ca.1949-1960 | - |
XOOOG | Yellow no. 1 light filter; screw-on type E41 | ca.1955 | 13160 |
XOOPT | Yellow no. 0 very light filter; screw-on type E41 | ca.1949 | 13155 |
XOOQG | Yellow no. 1 light filter; screw-on type E41 | ca.1949 | 13160 |
XOOSH | Panchromatic no. 1 filter; screw-on type E41 | ca.1949 | 13170 |
XOORU | Yellow no. 2 medium light filter; screw-on type E41 | ca.1949 | - |
XOOUI | Infra-red no. 1 light filter; screw-on type E41 | ca.1949 | 13190 |
XOOVL | UVa filter; screw-on type E41 | ca.1949 | 13205 |
XOOVW | Infra-red no. 2 medium filter; screw-on type E41 | ca.1949 | - |
XOOWK | Infra-red no. 3 dense filter; screw-on type E41 | ca.1949 | 13200 |
XOOZY | Orange filter; screw-on type E41 | ca.1949 | 13175 |
XOSKY | Kodachrome skylight filter; E41 mount | ca.1949-19?? | - |
XQIOO | Graduated polarizing filter; screw-in E41 mount | ca.1949-19?? | 13360 |
XQOOE | Blue filter; screw-on type E41 | ca.1955 | 13172 |
XWTVS | Focusing mount for Summar f= 5 cm 1:2 or Summitar f= 5 cm 1:2 with focus to infinity | 1948-19?? | NY item |
YAOOOO | Kodachrome type FP filter; E43 mount | ca.1959-19?? | - |
YAROB | Magnifying lens | ? | - |
YBEOO | Yellow no. 0 very light filter; screw-on type E43 | ca.1959 | - |
YCGOO | Yellow no. 1 light filter; screw-on type E43 | ca.1959 | 13161 |
YELOO | Panchromatic no. 1 filter; screw-on type E43 | ca.1959 | 13171 |
YFLASH | Kodachrome flash filter; E43 mount | ca.1949-19?? | - |
YFOOOO | Kodachrome type F filter; E43 mount | ca.1949-19?? | - |
YFPOOO | Kodachrome type FP filter; E43 mount | ca.1959-19?? | - |
YGPOO | Infra-red no. 1 light filter; screw-on type E43 | ca.1959 | 13191 |
YHROO | Infra-red no. 3 dense filter; screw-on type E43 | ca.1959 | 13196 |
YLXOO | Orange filter; screw-on type E43 | ca.1959 | 13176 |
YMOOL | Blue filter; screw-on type E43 | ca.1959 | 13173 |
YMZOO | UVa filter; screw-on type E43 | ca.1959 | 13206 |
YOOQU | Single exposure intermediate ring for oler models | ca.1939- | - |
YQHOO | Additional middle section for ZSLOO | 1936-19?? | - |
YRKOO | Rack and pinion connector for ROOFU arm of copy stand | 1939-1950 | - |
YROOF | Rack and pinion connector for ROOFU arm of copy stand with finer adjusment | 1951-19?? | - |
YSKYLI | Kodachrome skylight filter; E43 mount | ca.1954-19?? | - |
YSOOE | Extension foot for Albada brite-line SUOOQ or similar finder to clear camera housing | 1950's | - |
ZIOOQ | Extension accessory shoe for Leica If & Leica Ig with flash and finder SBOOI | 1954-1960 | 15546 |
ZOOAN | Short, chrome focusing mount for Hektor f= 13.5 cm 1:4.5 ; see also ZOOMF | 1938-19?? | 16495 |
ZOOEP | Short, chrome focusing mount for the Summicron M 2/90 mm to Visoflex II / III | 16462 | |
ZOOMF | 50 mm extension tube for Hektor f= 13.5 cm 1:4.5 in short mount ZOOAN | 1951-19?? | - |
ZOONT | Special focusing mount for Elmar f= 3.5 cm 1:3.5 | 1951-19?? | - |
ZOOSI-HESUM | Complete focusing stage for Summar and Summitar | 1951-19?? | - |
ZOOXY | Focusing mount for Elmar f= 3.5 cm 1:3.5; 1:18-1:2 reduction; "Focomount" NY designation | 1951-19?? | - |
ZPOOK | Table clamp for VALOY II column | 1955-19?? | 17508 |
ZQGOO | Helical focusing mount with screw adaptor ring no. 3 for 50 mm 1:4,5 FOCOTAR 1:2.5 to infinity | 1956-19?? | 16688 |
ZSLOO | Collapsible upright with table clamp in 3 parts for traveling; see also YQHOO | 1936-19?? | - |
ZSOOG | Tri-pod extension for short ball and socket to enable wide camera support plates | 1938-19?? | - |
ZTNOO | 2 small, chrome cylindrical adaptors for converting tri-pod thread; English & metric | 1938-19?? | - |
ZTOOF | Small, chrome cylindrical adaptor for converting English tri-pod thread to metric | 1938-19?? | - |
ZUPOO | Lighting device for press photographers with 4 chrome reflectors on a vertical stem | 1937-19?? | - |
ZVOOD | Small, chrome cylindrical adaptor for converting metric tri-pod thread to English | 1938-19?? | - |
ZWOOC | Set of extension tubes ZWTOO, BOOXZ, MOOBG, MOODH & MOOGW | 1936-19?? | - |
ZWTEL | Focusing mount for Elmar (II) f= 5 cm 1:3.5 with focus to infinity | 1948-19?? | NY item |
ZWTOO | Focusing mount for Elmar f= 3.5 cm 1:3.5 | 1936-1950 | - |
ZWTOO-HESUM | Focusing mount for Summar f= 5 cm 1:2 | 1936-1940 | - |
