WXYZ
| WEISO | Mini-telescope viewfinder for Elmar f= 3.5 cm 1:3.5; black or chrome; early with flare | 1933-1950 | - |
| WESTO | "Leicameter" exposure meter Weston model 650; large, black rectangular housing with chamfered corners | 1936-19?? | NY item |
| WICAB | Copy accessory lens cap with a shoe for angular finder WINKO | 1936-1939 | - |
| WICAP | Copy accessory lens cap with a shoe for angular finder WINKO | 1931-1935 | - |
| WINKO | Angle viewfinder for Standard Leica (model E) early versions have a larger eyecup | 1929- | black or chrome |
| WINTU | Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus | 1933-1948 | black or chrome |
| WOOLD | Angle viewfinder for Standard Leica (model E) with additional interior prism | 1938-1950 | black or chrome |
| WOOSU | Angle viewfinder for Leica II, Leica III & Leica IIIa with swing-in prism for right angle focus with additional interior prism | 1938-1948 | black or chrome |
| WZCOO | Copy accessory lens cap with a shoe for angular finder WINTU for Leica II and III's | 1936-1939 | - |
| XADEE | Special stand for dental photography using XBEET connector | 1939-19?? | - |
| XBEET | Sliding connector with wingnut forfitting FOCOSLIDE to pillar stands LURTE or USII | 1939-19?? | - |
| XDQII | Siding arm for rotating stage using ball bearings for positioning of camera | 1938-19?? | - |
| XEMOO | Xenon f= 5 cm 1:1.5 | 1939-1950 | - |
| XIOOM | Hood for Xenon f= 5 cm 1:1.5 chrome or black; folds flat; NY or Wetzlar | 1939-19?? | - |
| XOFLA | Kodachrome type A flash filter; E41 mount | ca.1949-19?? | - |
| XOOAM | Yellow no. 0 very light filter; slip-on type E | ca.1938 | - |
| XOOAY | Kodachrome type A filter; E41 mount | ca.1949-19?? | - |
| XOOBZ | Yellow no. 1 light filter; slip-on type E | ca.1938 | - |
| XOOCN | Yellow no. 2 medium filter; slip-on type E | ca.1938 | - |
| XOODA | Graduated yellow filter; slip-on type E | ca.1938 | - |
| XOOFB | UVa filter; slip-on type E | ca.1938 | - |
| XOOGP | Panchromatic green no. 1 filter; slip-on type E | ca.1938 | - |
| XOOHC | Graduated green filter; slip-on type E | ca.1938 | - |
| XOOIM | Conical, tapered hood for 50mm f/1.4 Summilux-M II black with wide chrome band | 1968-1995 | 12586 |
| XOOIO | Infra-red no. 1 light filter; slip-on type E | ca.1938 | - |
| XOOKD | Infra-red no. 2 medium filter; slip-on type E | ca.1938 | - |
| XOOLR | Infra-red no. 3 dense filter; slip-on type E | ca.1938 | - |
| XOOME | Orange filter; slip-on type E | ca.1938 | - |
| XOOMT | Yellow no. 3 dense filter; slip-on type E | ca.1938 | - |
| XOONS | Hood for Summarit f= 5 cm 1:1.5 | ca.1949-1960 | - |
| XOOOG | Yellow no. 1 light filter; screw-on type E41 | ca.1955 | 13160 |
| XOOPT | Yellow no. 0 very light filter; screw-on type E41 | ca.1949 | 13155 |
| XOOQG | Yellow no. 1 light filter; screw-on type E41 | ca.1949 | 13160 |
| XOOSH | Panchromatic no. 1 filter; screw-on type E41 | ca.1949 | 13170 |
| XOORU | Yellow no. 2 medium light filter; screw-on type E41 | ca.1949 | - |
| XOOUI | Infra-red no. 1 light filter; screw-on type E41 | ca.1949 | 13190 |
| XOOVL | UVa filter; screw-on type E41 | ca.1949 | 13205 |
| XOOVW | Infra-red no. 2 medium filter; screw-on type E41 | ca.1949 | - |
| XOOWK | Infra-red no. 3 dense filter; screw-on type E41 | ca.1949 | 13200 |
| XOOZY | Orange filter; screw-on type E41 | ca.1949 | 13175 |
| XOSKY | Kodachrome skylight filter; E41 mount | ca.1949-19?? | - |
| XQIOO | Graduated polarizing filter; screw-in E41 mount | ca.1949-19?? | 13360 |
| XQOOE | Blue filter; screw-on type E41 | ca.1955 | 13172 |
| XWTVS | Focusing mount for Summar f= 5 cm 1:2 or Summitar f= 5 cm 1:2 with focus to infinity | 1948-19?? | NY item |
| YAOOOO | Kodachrome type FP filter; E43 mount | ca.1959-19?? | - |
| YAROB | Magnifying lens | ? | - |
| YBEOO | Yellow no. 0 very light filter; screw-on type E43 | ca.1959 | - |
| YCGOO | Yellow no. 1 light filter; screw-on type E43 | ca.1959 | 13161 |
| YELOO | Panchromatic no. 1 filter; screw-on type E43 | ca.1959 | 13171 |
| YFLASH | Kodachrome flash filter; E43 mount | ca.1949-19?? | - |
| YFOOOO | Kodachrome type F filter; E43 mount | ca.1949-19?? | - |
| YFPOOO | Kodachrome type FP filter; E43 mount | ca.1959-19?? | - |
| YGPOO | Infra-red no. 1 light filter; screw-on type E43 | ca.1959 | 13191 |
| YHROO | Infra-red no. 3 dense filter; screw-on type E43 | ca.1959 | 13196 |
| YLXOO | Orange filter; screw-on type E43 | ca.1959 | 13176 |
| YMOOL | Blue filter; screw-on type E43 | ca.1959 | 13173 |
| YMZOO | UVa filter; screw-on type E43 | ca.1959 | 13206 |
| YOOQU | Single exposure intermediate ring for oler models | ca.1939- | - |
| YQHOO | Additional middle section for ZSLOO | 1936-19?? | - |
| YRKOO | Rack and pinion connector for ROOFU arm of copy stand | 1939-1950 | - |
| YROOF | Rack and pinion connector for ROOFU arm of copy stand with finer adjusment | 1951-19?? | - |
| YSKYLI | Kodachrome skylight filter; E43 mount | ca.1954-19?? | - |
| YSOOE | Extension foot for Albada brite-line SUOOQ or similar finder to clear camera housing | 1950's | - |
| ZIOOQ | Extension accessory shoe for Leica If & Leica Ig with flash and finder SBOOI | 1954-1960 | 15546 |
| ZOOAN | Short, chrome focusing mount for Hektor f= 13.5 cm 1:4.5 ; see also ZOOMF | 1938-19?? | 16495 |
| ZOOEP | Short, chrome focusing mount for the Summicron M 2/90 mm to Visoflex II / III | 16462 | |
| ZOOMF | 50 mm extension tube for Hektor f= 13.5 cm 1:4.5 in short mount ZOOAN | 1951-19?? | - |
| ZOONT | Special focusing mount for Elmar f= 3.5 cm 1:3.5 | 1951-19?? | - |
| ZOOSI-HESUM | Complete focusing stage for Summar and Summitar | 1951-19?? | - |
| ZOOXY | Focusing mount for Elmar f= 3.5 cm 1:3.5; 1:18-1:2 reduction; "Focomount" NY designation | 1951-19?? | - |
| ZPOOK | Table clamp for VALOY II column | 1955-19?? | 17508 |
| ZQGOO | Helical focusing mount with screw adaptor ring no. 3 for 50 mm 1:4,5 FOCOTAR 1:2.5 to infinity | 1956-19?? | 16688 |
| ZSLOO | Collapsible upright with table clamp in 3 parts for traveling; see also YQHOO | 1936-19?? | - |
| ZSOOG | Tri-pod extension for short ball and socket to enable wide camera support plates | 1938-19?? | - |
| ZTNOO | 2 small, chrome cylindrical adaptors for converting tri-pod thread; English & metric | 1938-19?? | - |
| ZTOOF | Small, chrome cylindrical adaptor for converting English tri-pod thread to metric | 1938-19?? | - |
| ZUPOO | Lighting device for press photographers with 4 chrome reflectors on a vertical stem | 1937-19?? | - |
| ZVOOD | Small, chrome cylindrical adaptor for converting metric tri-pod thread to English | 1938-19?? | - |
| ZWOOC | Set of extension tubes ZWTOO, BOOXZ, MOOBG, MOODH & MOOGW | 1936-19?? | - |
| ZWTEL | Focusing mount for Elmar (II) f= 5 cm 1:3.5 with focus to infinity | 1948-19?? | NY item |
| ZWTOO | Focusing mount for Elmar f= 3.5 cm 1:3.5 | 1936-1950 | - |
| ZWTOO-HESUM | Focusing mount for Summar f= 5 cm 1:2 | 1936-1940 | - |
