Digilux 2
3D image Click-to-turn view
Digilux 2 Wikipedia
Lens - LEICA DC VARIO-SUMMICRON 7 > 22.5 mm f/2.0 > 2.4 ASPH. zoom lens (corresponds to a 28 > 90 mm zoom lens for the 35 mm format), 13 lens elements in 10 groups.
Focus range - Close-up limit 30 cm (ca. 12 inches).
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder, SF 24D Flash Unit.
- Specifications adapted from manufacturer's technical data of June 2006. Leica Digilux 2 Data
Reviews
