E
| EAWOO | - | ||
| EBOOH | Everready leather case for R3 | ca.1961 | 14615 Q |
| ECUUG | ca.1961 | 37033 B | |
| EDCUU | ca.1961 | 37044 N | |
| EDUUF | ca.1961 | 37066 L | |
| EELUD | - | ||
| EEPMG | Macro lamp, a circle with 4 x 25 W bulbs | ? | - |
| EEPLG | Macro lamp, a circle with 4 x 40 W bulbs | ? | - |
| EEPSV | Small holder for auxiliary GUHII, for screw mounting to the macro state MADAH | ? | - |
| EEPSU | Larger holder for auxiliary GUHII, for screw mounting to the macro state MADAH | ca. 1956 | - |
| EEVRN | Tapered bellows for large format with tape measure | - | |
| EEXRL | Holder for ISOFLEX | ? | - |
| EEXRM | Holder for ISOFLEX | ca.1955 | - |
| EEXSN | Holder for ISOFLEX with hammer paint finish | ? | - |
| EEZYX | Slide device MACRODIA for macro photography | ? | - |
| EFERN | Elmar f= 13.5 cm 1:4.5 nickel finish | ? | - |
| EFGOO | Everready leather case for Leica IIc, IIf, IIIc, IIIf with 50mm Summicron or Summitar and attached universal or mirror viewfinder | ca.1961 | -37088 K |
| EGIUU | ca.1961 | 37077 P | |
| EGOOI | - | ||
| EGUUC | ca.1961 | 37099 N | |
| EITPL | - | ||
| EKURZ | Elmar f= 3.5 cm 1:3.5 chrome finish | 1933-1950 | - |
| EKURZUP | Elmar f= 3.5 cm 1:3.5 nickel finish | 1930-1933 | - |
| EKUUZ | ca.1961 | 32600 G | |
| ELANG | Elmar (II) f= 9 cm 1:4 | 1930-1945 | - |
| ELANG-M | Elmar 90mm f/4 | 1954-1968 | - |
| ELCAR | Early close-up lens for Compur Leica (model B) | ? | - |
| ELCAT | Late close-up lens for Compur Leica (model B) | 1930 | - |
| ELCOM | Early close-up lens for Compur Leica (model B) diopter No. 2 | ? | - |
| ELCON | Late close-up lens for Compur Leica (model B) diopter No. 2 | ? | - |
| ELCUR | Early close-up lens for Compur Leica (model B) diopter No. 3 | ? | - |
| ELCUS | Late close-up lens for Compur Leica (model B) diopter No. 3 | ? | - |
| ELDIA | Contact printer for 35 mm negatives | pre 1937 | - |
| ELDUR | Contact printer to make 2 x 2” lantern slides | pre 1937 | - |
| ELDUS | - | ||
| ELESS | - | ||
| ELGAM | Elmar (III) 1:4 / 90mm | 1946-1963 | 11 830 |
| ELGLA | Metal pressure plate for ELDUR contact printer | pre 1937 | - |
| ELKIM | Movie window panel 18x24 cm for contacts from Cinema negatives | ? | - |
| ELKIN | Movie window panel 18x24 cm for contacts from Cinema negatives | ? | - |
| ELKOO | - | ||
| ELMAR | Elmar (I) f= 5 cm 1:3.5 | 1931-1959 | - |
| ELMAM | F = 5 cm 1:3.5 Elmar with M-bayonet | 1954-1961 | 11 610 |
| ELMOM | Elmar f= 5 cm 1:2.8 with M-bayonet | 1958-1966 | 11 612 |
| ELMOO | Elmar f= 5 cm 1:2.8 | 1957-1962 | - |
| ELPAS | Close-Up lens no.1 for dial-set Compur Leica (model B) | 1927 | - |
| ELPET | Close-up lens No. 3 for Elmar | ? | - |
| ELPEX | Close-up lens No. 3 for Summar | ? | - |
| ELPEZ | Close-up lens No. 3 for Summitar | ? | - |
| ELPIK | Close-up lens No. 2 for Elmar | ? | - |
| ELPIL | Close-up lens No. 2 for Summar | ? | - |
| ELPIS | Close-up lens No. 2 for Summitar | ? | - |
| ELPRO | Close-up lens attachments for R-50 mm, 90 mm and 135 mm | 1966-2009 | - |
| ELPUR | - | ||
| ELPYN | - | ||
| ELRIM | Elmarit f= 9 cm 1:2.8 with bayonet mount | 1959-1974 | - |
| ELRIT | Elmarit f= 9 cm 1:2.8 with screw mount | 1959-1963 | 11 029 |
| ELROO | Elmar f= 3,5 1:4, “snap-shot” lens, prototype only | ca.1950 | - |
| ELRUU | - | ||
| ELUUY | - | ||
| ELZEN | The “Mountain Elmar” Elmar f= 10.5 cm 1:6.3 | 1932-1937 | - |
| EMQOO | - | ||
| EMTOO | Telyt leather case | 14585 B | |
| EMTUU | 32620 T | ||
| EMUUX | 32630 V | ||
| ENUUW | - | ||
| EPOCH | Small canvas case for LEICA III or Standard | ca.1933 | - |
| ERKOM | 11128 M | ||
| ESFAB | Everready leather case for LEICA III or Standard with non-colapsing Summar | ca.1933 | - |
| ESFOO | Everready leather case for LEICA 250 | - | |
| ESFUS | Everready leather case for Leica IIc, IIf, IIIc, IIIf with 50mm Summicron or Summitar | ? | - |
| ESMAL | Everready leather case for LEICA III | ca.1933 | - |
| ESMOS | Everready leather case for LEICA III or Standard with long lens | ca.1933 | - |
| ESNAR | Everready leather case for LEICA III or Standard | ca.1933 | - |
| ESNEL | Everready leather case for Leica I (model A) | - | |
| ETBIX | Leather lens case without strap for Summar 5 cm 1:2 | ca.1933 | - |
| ETGUS | Large leather accessory case (19.5 x 24.5 x 8 cm) for camera and 5 lenses | ca.1933 | - |
| ETIFF | Leather lens case with strap for Elmar 10.5 cm | ca.1933 | - |
| ETILA | Leather lens case without strap for Elmar 3.5 cm | ca.1933 | - |
| ETIME | Leather lens case without strap for Hektor or Elmar 5 cm | ca.1933 | - |
| ETINI | Leather lens case with strap for Elmar 9 cm | ca.1933 | - |
| ETINX | Leather lens case with strap for Hektor 7.3 cm | ca.1933 | - |
| ETIPO | Leather lens case with strap for Elmar or Hektor 13.5 cm | ca.1933 | - |
| ETISY | Leather lens case with strap for Elmar or Hektor 13.5 cm and Elmar 3.5 cm | ca.1933 | - |
| ETKAL | Small lady's canvas case for LEICA III or Standard | ca.1933 | - |
| ETMAX | Large leather accessory case (22.5 x 29.5 x 8 cm) for camera and 7 lenses similar to ETGUS | ca.1933 | - |
| ETNEU | Large leather accessory case (18.5 x 25.5 x 8 cm) for camera and 4 lenses similar to ETGUS | ca.1933 | - |
| ETOSA | Leather lens case with strap for Hektor 7.3 cm and Elmar 3.5 cm | ca.1933 | - |
| ETRIN | Leather accessory case (16 x 11 x 5 cm) for LEICA III or Standard | ca.1933 | - |
| ETRUX | Small vertical leather case for LEICA III or Standard | ca.1933 | - |
| ETTAS | Small canvas case for LEICA III or Standard | ca.1933 | - |
| ETTEL | Small canvas case for LEICA III or Standard | ca.1933 | - |
| ETTRE | Large leather accessory case (15.5 x 15.5 x 8 cm) for camera and 3 lenses similar to ETGUS | ca.1933 | - |
| ETTWO | Leather accessory case (17 x 15 x 5.5 cm) for LEICA III or Standard | ca.1933 | - |
| ETXBE | Small bellows, used with EEXSN and Aristophot II micro-photgraphy | ? | - |
| ETXBS | Small bellows, used with Aristophot II micro-photgraphy | ? | - |
| EUKOS | Everready case for Standard Leica (model E) | - | |
| EUKUT | Deerskin purse for one lens filter | pre 1934 | - |
| EUROS | - | ||
| EUVER | - | ||
| EUVIL | Morocon leather purse for one lens filter | pre 1934 | - |
| EXCOR | - | ||
| EUDIT | Leather case for FODUA Leica I (model A) | ? | - |
| EUSAF | Small canvas case for Standard with long lens | ca.1933 | - |
| EYMZE | 6-volt lamp housing with a focusing objective, and 2 blue glass filters | ? | - |
| EYMZG | 6-volt lamp housing with a focusing objective, and 2 green glass filters | ? | - |
| EYMZH | 6-volt lamp housing with a focusing objective, and 2 filters | ? | - |
| EZDOO | Leather strap for 125mm Hektor | - |
