Leica If
Revision as of 21:44, 26 January 2010 by Admin (talk | contribs)
Leica If "red dial" camera with 1952 Elmar f = 5 cm 1:3.5 lens = OEINO
  • Code names - OEINO = OEFGO + ELMAR, OESFO = OEFGO + SOORE, OEGIO = OEFGO + FOKUS per Farines List. Note: OEGIO is the code name for the Leica Ic body with viewfinder as well as Leica If, depending on the date of the catalog: Leica Ic < 1951 > Leica If.
  • Production era - 1952-1958; 15,786 cameras
  • Variants - Black Dial, Red Dial, 3-crown Swedish Military, and Swedish Post versions
  • Evolution - Leica IIIf body without rangefinder or viewfinder intended for technical use like mounted in a microscope or Visoflex; the Leica If has two accessory shoes on the top
  • Serial numbers - 562801-565000, 575001-580000, 673001-674999, 682001-684000, 760001-762000, 780091-780100, 789001-790000, 807501-808500, 815001-816000, 822001-823000, 850901-851000; 17,309 total assigned numbers 1952-1957
  • Body - aluminum with chrome plated brass top plate, base plate and knobs
  • Size L x W x H - 136 x 39 x 65 mm / 5.35 x 1.54 x 2.60 in
  • Brochures and Manuals
  • Forum discussion
