V
Revision as of 15:33, 27 January 2010 by Admin (talk | contribs)
VACUB Earliest Leica flash unit ca.1933 NY item
VALOY Complete copy stand type I and II OKYNO 19??-19?? -
VAMAX X-ray enlarger used with VEHAL and 48" VESTA arm 1933-19?? -
VARIP Large copying device with VELTU base and column, and VEARM arm and STAFO lighting, VEHIG and STAMA 1933-19?? -
VEARM Large copying device with 40" VELTO base and column, front lenses 1, 2 & 3 and VALFA or FILYT enlarger 1933-19?? -
VEDUK Cable with plug and switch for VEKAS 1931-19?? -
VEHAL Bent camera arm with wingnut; used with VERAP 1931-19?? -
VEHIG Fixed focusing stage with ground glass housing complete with 5x magnifier and protecting lid for camera body opening 1933-19?? -
VEKAS 16 x 20 inch lightbox with 6 lights, VEDUK cable and various glass covers to hold film flat; on base of VERAP 1931-19?? -
VEKOT 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and VERYK glass covers to hold film flat 1931-19?? -
VELIF Arm for VIHAK small copy stand 1933-19?? -
VELTU Base and column part of VARIP or ROOKA large copy stand 1933-1936 -
VELYP 16 x 12 inch glass covers to hold film flat 1933-19?? -
VEPUT 16 x 12 inch lightbox with 4 lights, VEDUK cable and various glass covers, VELYP to hold film flat 1932-19?? -
VERAP X-ray reproduction device with VESTA base and column, VEHAL arm and VEKAS light box with VEHIG and 12 feet of cable with switch 1931-19?? -
VERYK 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and various glass covers, VEYRK to hold film flat; on base of VERAP 1932-19?? -
VESTA Base and column; used with VERAP 1931-19?? -
VEZUK Curved lateral holder to support the camera when used vertically ca.1933 -
VIDEO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses 1932-1933 black
VIDOM Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image 1933-1939
VIEFF Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses 1932-1933 black
VIEME Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses 1932-1933 black
VIFUR Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1933-1936 black or chrome
VIGEH Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses 1932-1933 black
VIHAK 74 19??-19?? -
VIHEU Small, torpedo shaped finder for 3.5cm, 5cm lenses 1932- black
VIKAN Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIKUL 9 1/2 x 12 inch lightbox with 3 lights and various glass covers, VIRUP to hold film flat 1933-19?? -
VILLO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIOAD 12 19??-19?? -
VIOOH Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm 1940-1964 reaches 2.8 cm with TUVOO add-on
VISAX Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1932-1933 black
VISET Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses 1932-1933 black
VISIL 10 19??-19?? -
VISOR The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1931-1931 black
VISSI Small, torpedo shaped finder for 3.5cm, 9cm lenses 1932-1933 black
VITRE Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses 1933-1936 black or chrome
VIUNA Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses 1933-1936 black or chrome
VIZWO Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1933-1936 black or chrome
VLOOF Spare, folding reflector for CEYOO, CEYAL or CAVOO 1951-1953 15532
VMCOO Intermediate ring for use of Elmar front lenses on 5 cm Summar 19??-19?? -
VOOLA Thin metal diaphram setting ring to adjust aperature of 5 cm Elmar when slip-on filter is in place 1955-19?? 16621
VOOQF 32 inch copy stAND column with guide rail like Valoy II OVURO ca.1955 17552
VORGI Intermediate ring for use of Hektor front lenses on 5 cm Summar 19??-19?? -
VOROD Sereoly system for Leica II, III and IIIa 1932 NY item
VORSA Early Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa 1931-1939 -
VORSTAN Sereoly system for non-rangefinder cameras 1933-1934 -
VORUF Stereoly arm to mount prisum on Leica II, III and IIIa ca.1939 -
VOSTN Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa 1935-1939 -
VOTIV Stand for VOTRA stereo transparency viewer; nickel plated 1931-19?? -
VOTRA Stereo transparency viewer; nickel plated 1931-19?? -
VSPOO Focusing mount for Focoslide OOBAZ or OTGOO using F = 5 cm 1:2 Summicron II 1956-1968 16608
VTOOX Aperature setting ring for 50mm f/2.8 Elmar-M 1958-19?? 16622
VTROO Aperature setting ring for 60 mm f/2.2 Summicron-M 1956-19?? 16686
VUROO Valloy II copy stand with 25 1/2 inch column including UWOOS bracket to take FOCOSLIDE 1960-19?? 16702 16704-3/8" bush
VWOOU Repro N extension tub 26mm fitted between Focoslide OOBAZ or OTGOO 1956-19?? 16689
VXOOT Focusing mount for Focoslide OOBAZ using F = 5 cm 1:3.5 Elmar and VALOO aperature setting ring 1958-19?? 16622
VXZOO Focusing mount for Focoslide OOBAZ or OTGOO using 50mm f/2.8 Elmar-M 1958-19?? 16608
