F
FARBA | ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
FARLY | FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 | ca.1933 | - |
FAROS | FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 | ca.1933 | |
FARPU | ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
FARUX | Panoramic tripod head | 1933-1936 | [1] |
FASKI | FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 | ca.1933 | |
FAVOO | No. 2 medium yellow filter; screw-on type H | ca.1935 | - |
FAWAG | FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 | ca.1933 | |
FAXIS | FARUX Scale ring for Elmar (I) f= 9 cm 1:4 | ca.1933 | |
FAZOY | No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 | ca.1933-1938 | NY item |
FBOOK | UVa filter; screw-on type H | ca.1935 | - |
FBXOO | Panchromatic green no. 1 filter; screw-on type H | ca.1935 | - |
FCKOO | Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 | 1951-1960 | - |
FCOOI | No. 2 medium infra-red filter; screw-on type H | ca.1935 | - |
FCZOO | No. 1 light infra-red filter; screw-on type F | ca.1931 | - |
FDOOH | No. 3 dark infra-red filter; screw-on type G | ca.1935 | - |
FEARM | Copy arm used with FESSA base and FEHUN column | 1931-19?? | - |
FEDOO | No. 1 light infra-red filter; slip-on type A36 | ca.1931-1950's | 13040 |
FEFFU | Copy base and column, used with FILUM arm and STALI lighting = FEPRO | 1931-19?? | - |
FEHUN | Column support used with FESSA base and FEARM | 1931-19?? | - |
FEOOG | No. 3 dark infra-red filter; slip-on type A36 | ca.1935-1950's | 13050 |
FEPRO | Copy stand with FEFFU base, column, FILUM arm and STALI lighting | 1931-19?? | used with front lenses 2 & 3, WICAP and WINKO |
FESSA | Copy base used with FEHUN column and FEARM | 1931-19?? | - |
FESTO | Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting | 1931-19?? | used with front lenses 1, 2 or 3, WICAP and WINKO |
FGHOO | Replacement hood for Hektor f= 7.3 cm 1:1.9 | 1936-1946 | - |
FGOOE | No. 1 light infra-red filter; screw-on type I | ca.1933 | - |
FHKOO | Single film holder for I, II, III, IIIa, IIIb1 | 1935-1960 | - |
FHOOD | No. 3 dark infra-red filter; screw-on type I | ca.1935 | - |
FIAKU | Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate | 1926-19?? | JCB's a little...IIIa |
FIALT | Holder for film handling during the development process | 1930's | - |
FIAMA | Panoramic tripod head for 5 cm lens | 1926-19xx | - |
FIARO | Stereoly slide bar 75 mm long | 1926-1926 | - |
FIATE | Stereoly slide bar 150 mm long; early version had center tripod bush; later versions with off-center tripod bush | 1926-1940 | - |
FIAVI | Angle bracket to support camera on panorama head | 1929-19?? | - |
FIBLA | Small canister spirit level for camera top shoe or on FIAVI for vertical pictures; replaced by DOOLU in 1936 | 1929-1935 | - |
FIBOB | No. 2 medium infra-red filter; screw-on type G | ca.1933 | - |
FIBOS | Leather neck strap with metal snap hooks for cameras with side lugs | 1936-ca.1950 | - |
FICAT | No. 1 light yellow filter; screw-on type F | ca.1930 | - |
FICFA | Kodachrome type A flash filter; ADFIK 34 mm mount | ca.1949-1950's | - |
FICHR | Kodachrome flash filter; slip-on type A36 | ca.1949-1950's | - |
FICOM | No. 2 medium yellow filter; screw-on type F | ca.1930 | - |
FICOR | Panchromatic green no. 2 filter; slip-on type A36 | ca.1945 | NY item |
FICUR | No. 3 dense yellow filter; screw-on type F; | ca.1930 | - |
FIDAY | Kodachrome type F filter; screw-on type L | ca.1959- | - |
FIDAYMI | Kodachrome type A filter; screw-on type E39 | ca.1949- | NY item |
FIDRI | Shutter release cable, 10 feet long | 1931-19?? | - |
FIEKT | Polarising filter; swing-out, slip-on type C with clamping screw | ca.1939 | NY item |
FIFLO | Kodachrome photo-flood filter; screw-on type L | ca.1949-1950's | NY item |
FIFLOMI | Kodachrome photo-flood filter; screw-on type E39 | ca.1949- | NY item |
FIGAM | No. 2 medium yellow filter; slip-on type A36 | ca.1931-1950's | - |
FIGDA | Panchromatic green no. 2 filter; ADFIK 34 mm mount | ca.1945 | NY item |
FIGIL | Graduated Yellow filter; slip-on type C | ca.1931 | - |
FIGON | Adaptor for FISUM polarising filter on Contax | 1949-1950's | NY item |
FIGRO | No. 1 light yellow filter; slip-on type A36 | ca.1931-1950's | 13005 |
FIGUN | No. 1 light yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
FIHAZ | Kodachrome haze filter; screw-on type L | ca.1949-1950's | NY item |
FIHEL | No. 0 very light yellow filter; slip-on type A36 | ca.1933 | 13000 |
FIIRL | No. 1 light infra-red filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
FIKAT | Kodachrome type A filter; slip-on type A36 | ca.1949- | NY item |
FIKHA | Kodachrome haze filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
FIKLO | Kodachrome photo-flood filter; slip-on type A36 | ca.1949-1950's | NY item |
FIKOZ | Kodachrome haze filter; slip-on type A36 | ca.1949-1950's | NY item |
FIKUS | Extendable hood for 4 focal lengths: 3.5-13.5; early black & nickel; later black & chrome; NY all chrome version | 1933-1965 | 12530 JCB's a little...II |
FIKYB | No. 2 medium infra-red filter; slip-on type A36 | ca.1933-1950's | - |
FILBY | No. 1 light yellow filter; slip-on type A | ca.1926 | - |
FILCA | Film cassette originally for Leica I (model A) only; center spool with locking device introduced in 1939; postwar with shiny brown finish JCB's...a little | 1925-1954 | - |
FILES | Enlarger used with FILUM arm, FEFFU base and column with lenses 2 & 3 | 1931-19?? | - |
FILGE | No. 2 medium yellow filter; slip-on type A | ca.1925 | - |
FILOY | Enlarger used with FILUM arm, FEFFU base and column with front lenses 2 & 3 | 1931-19?? | - |
FILPO | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | NY item |
FILSO | No. 1 light yellow filter; slip-on type C | ca.1933 | - |
FILTU | No. 3 dense yellow filter; slip-on type A | ca.1925-1926 | - |
FILUM | Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO | 1931-19?? | - |
FILXA | No. 3 dense yellow filter; screw-on type I | ca.1933 | - |
FILYT | Enlarger or copying device used with FEARM arm, FESSA or FEHUN base and column with front lenses 2 & 3 | 1931-19?? | - |
FIMOO | No. 0 very light yellow filter; screw-on type H | ca.1935 | - |
FINON | Polarising filter; swing-out, screw-on type E41 with clamping screw | ca.1939-1950's | NY item |
FINOT | Shutter release cable, 10 inches long | 1931-19?? | - |
FINOW | Shutter release cable, 10 inches long; metal sheathed | 1939-19?? | NY item |
FINUS | No. 3 dense yellow filter; screw-on type G | ca.1931 | NY item |
FIOKO | UVa filter; screw-on type F | ca.1931 | - |
FIOLA | UVa filter; slip-on type A36 | ca.1931 | 13055 |
FIOMU | No. 2 medium infra-red filter; slip-on type C | ca.1933 | - |
FIONA | Orange filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
FIOOC | No. 1 light yellow filter; screw-on type H | ca.1935 | - |
FIOPY | No. 0 very light yellow filter; slip-on type C | ca.1933 | - |
FIORE | UVa filter; screw-on type G | ca.1931 | - |
FIOSI | UVa filter; slip-on type C | ca.1933 | - |
FIOUX | FSEOO Orange filter; slip-on type A36 | ca.1939 | NY item |
FIPAN | Panchromatic green no. 1 filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
FIPHO | Kodachrome photoflood filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
FIPLO | No. 2 medium infra-red filter; screw-on type I | ca.1933 | - |
FIPOS | Panchromatic green no. 1 filter; slip-on type A36 | ca.1933-1950's | 13015 |
FIPPA | No. 2 medium yellow filter; slip-on type C | ca.1933 | - |
FIQUX | Orange filter; slip-on type A36 | ca.1939-1950's | NY item |
FIRAD | Graduated Yellow filter; slip-on type A36 | ca.1931 | - |
FIRCO | Intermediate collar for using a slip-on filter for Compur Leica (model B) | 1931-19?? | - |
FIREG | No. 1 light yellow filter; screw-on type I | ca.1933 | - |
FIRGI | Intermediate collar for using a slip-on filter in conjunction with supplementary lenses | 1931-19?? | - |
FIRHE | No. 1 light yellow filter; screw-on type G JCB's a little...IIIa | ca.1931 | 13001 |
FIRHU | Rear dust cover for screw lenses | 1939-ca.1954 | - |
FIRMY | No. 2 medium yellow filter; screw-on type G | ca.1931 | - |
FIROL | Adaptor for FILPO polarising filter on Rolleiflex or Rolleicord | 1949-1950's | NY item |
FIRYX | Panchromatic green no. 1 filter; screw-on type I | ca.1933 | - |
FISAP | Panchromatic green no. 1 filter; slip-on type C | ca.1933 | - |
FISEX | Shutter release cable, 20 feet long | 1931-19?? | - |
FISKF | Kodachrome skylight filter; slip-on A36 mount | ca.1954- | NY item |
FISON | Hood for 5 cm ELMAR; black cylinder with rectangular aperture until 1933 when changed to round aperture; last version was chrome with set screw | 1925-1963 | 12510 |
FISUM | Polarising filter; swing-out, screw-on type L with clamping screw | ca.1939 | NY item |
FISUMMI | Polarising filter; swing-out, screw-on type E39 with clamping screw | ca.1939 | NY item |
FITAF | Kodachrome type A filter; ADFIK 34 mm mount | ca.1949- | NY item |
FITWO | No. 2 yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
FIUNS | No. 0 very light yellow filter; slip-on type A | ca.1933 | - |
FIVPL | Complete unit for surgical operation photography with cast iron base and rack and pinion movement | 1939-19?? | |
FIWAS | No. 0 very light yellow filter; screw-on type I | ca.1933 | - |
FIWET | UVa filter; screw-on type I | ca.1933 | - |
FIWIG | No. 2 medium yellow filter; screw-on type I | ca.1933 | - |
FIXIO | Panchromatic green no. 1 filter; screw-on type G | ca.1933 | - |
FIXTA | No. 0 very light yellow filter; screw-on type G | ca.1933 | - |
FKDELM | Kodachrome type F filter; slip-on type A36 | ca.1959- | - |
FKDSAX | Kodachrome type F filter; screw-on type E58 | ca.1959- | - |
FKDSMI | Kodachrome type F filter; screw-on type E39 | ca.1959- | - |
FKDSMT | Kodachrome type F filter; screw-on type E41 | ca.1959- | - |
FKDTEL | Kodachrome type F filter; screw-on type E48 | ca.1959- | - |
FLASH | Horizontal mounted flash unit (like SYNCO) for Standard Leica (model E) | ca.1938 | - |
FLECT | Dull surfaced flash reflector for portraits | ca.1938 | - |
FLOOA | UV light copying device with ELMAR | 1939-19xx | - |
FLOTH | Plumbbob for copy stand use with U-shaped or angular harness for ELMAR; FLOTH + STARE = STAOT copy stand | 1931-19?? | - |
FLQOO | Hood for 35 mm Elmar; black or chrome; superseded by FOOKH | 1936-1950 | also NY version |
FMOOZ | No. 1 light infra-red filter; slip-on type C | ca.1933 | - |
FMSOO | No. 3 dark infra-red filter; slip-on type C | ca.1935 | - |
FNOOY | No. 1 light infra-red filter; screw-on type H | ca.1935 | - |
FNUOO | No. 3 dark infra-red filter; screw-on type H | ca.1935 | - |
FOCOMAT | Enlarging device used with Visoflex II & III | 1963-19?? | - |
FODIS | Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions | 1925-1929 | 2.15 cm wheel |
FODUA | Longbase rangefinder (without leather case) to measure distance from film plane to object; metric and international versions | 1925-1929 | 2.15 cm wheel |
FOFER | Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions with fixing clip; Nagel version has N on the wheel | 1925-1939 | 3.5 cm wheel |
FOKAL | Hinged bracket for attaching FOKIN to camera | 19xx-19xx | - |
FOKIN | Longbase rangefinder for cine cameras | 1926-1940 | 3.5 cm wheel |
FOKOS | Short black & nickel, black & chrome or all chrome rangefinder with 7.5 cm base; after 1949 - chrome only version with 6.2 cm base | 1933-1966 | - |
FOKUX | Ball and socket joint for longbase rangefinder | 19??-1940 | - |
FONOR | Longbase rangefinder for 6x9 to 10x15 cm; metric and international versions | 19??-1940 | - |
FONOT | Shutter release cable, 10 inches long with set screw | 1955-19?? | 14067 |
FOOBD | Graduated Green filter; slip-on type A36 | ca.1938 | - |
FOOCR | Graduated Green filter; slip-on type C | ca.1938 | - |
FOOKH | Hood for 3.5 cm Summaron & Elmar | 1951-1966 | 12505 |
FOOMI | Short, chrome ball and socket tripod head | 1938-1960 | 14104 (3/8") and 14105 |
FOONW | FARUX Scale ring for Hektor 2.8 cm | ca.1936 | |
FOOQL | FARUX Scale ring for Telyt 20 cm | ca.1936 | |
FOOVA | Tank for loading film cassettes in daylight | 1939-1950's | - |
FOOXB | Filter holder; slip-on type A36 | ca.1951 | 13365 |
FOOXC | Filter holder; screw-on type L | ca.1951 | - |
FOOXD | Filter holder; screw-on type E41 | ca.1951 | 13375 |
FOOXE | Filter holder; screw-on type E58 | ca.1951 | 13380 |
FOOXF | Filter holder; screw-on type E48 | ca.1951 | 13385 |
FOOXH | Filter holder; screw-on type E39 | ca.1955 | 13371 |
FOOXK | Filter holder; screw-on type E43 | ca.1959 | 13384 |
FOREST | Binocular 6 x 42 - CF | 1927-1939 | see Sport Optics |
FORESTON | Binocular 6 x 42 | 1927-1939 | see Sport Optics |
FORESTONA | Binocular 8 x 42 | 1927-1939 | see Sport Optics |
FORSTA | Binocular 8 x 42 - CF | 1927-1939 | see Sport Optics |
FOSAR | Angular bracket for holding ground glass housing VEHIG | ca.1933 | - |
FPKELM | Kodachrome type FP filter; slip-on type A36 | ca.1959- | - |
FPKSAX | Kodachrome type FP filter; screw-on type E58 | ca.1959- | - |
FPKSMI | Kodachrome type FP filter; screw-on type E39 | ca.1959- | - |
FPKSMT | Kodachrome type FP filter; screw-on type E41 | ca.1959- | - |
FPLTEL | Kodachrome type FP filter; screw-on type E48 | ca.1959- | - |
FPOOW | Orange filter; screw-on type G | ca.1939 | - |
FQOOV | Orange filter; screw-on type H | ca.1939 | - |
FRCOO | Orange filter; screw-on type I | ca.1939 | - |
FSEOO | Orange filter; slip-on type C | ca.1939-1950 | - |
FTGOO | Orange filter; slip-on type A36 | ca.1939 | 13025 |
FUECD | Complete extension tube set for FULDY; also for OORES | 1936-1939 | - |
FUFIF | 15 mm extension tube for FULDY | 1936-1939 | NY item |
FUFOR | 45 mm extension tube for FULDY | 1936-1939 | NY item |
FULDY | Sliding focusing stage using Leica screw thread to hold camera (later know as "Focoslide") in 4 types for various screw-thread cameras to sn. 400000; superseded by FULEC | 1930-1951 | - |
FULEC | Sliding focusing stage using Leica screw thread to hold camera for screw-thread cameras after sn. 400000 | 1948-1951 | - |
FULET | Like FULDY without sliding camera attachment | ca.1939 | NY item |
FULFO | 30 mm extension tube for FULDY | 1936-1950's | NY item |
FULGX | 60 mm extension tube for FULDY | 1936-1950's | NY item |
FULHI | 90 mm extension tube for FULDY | 1936-1950's | NY item |
FULOR | 12 mm extension tube for FULDY | 1936-1939 | NY item |
FUSEV | 7 mm extension tube for FULDY | 1936-1939 | NY item |
FVOOQ | 15 mm extension tube for ZWTOO-HESUM Summar focusing mount | ca.1949-1950's | - |
