S
SAIOO | Folding type "Sports" viewfinder for Hektor f= 7.3 cm 1:1.9 lens | 1935-19?? | - |
SAMWO | F = 3.5 cm 1:2 Summicron I for M3 | 1958-1969 | 11 108 |
SAWOM | 35mm f/2 Summicron II for M2 | 1958-1969 | 11 308 |
SAWOO | Summicron (I) f= 3.5 cm 1:2 | 1958-1963 | 11 008 |
SBKOO | Enclosed chrome, flared cone viewfinder for 21 mm with parallax adjustment by concentric ring like SGVOO ; later versions are black | ca.1960 | 12002 |
SBLOO | Finder for Summaron f= 3.5 cm 1:3.5 | ca.1951-1960 | 12010 |
SBOOI | Enclosed, cylindrical viewfinder for 5 cm lenses | ca.1951-1960 | 12015 |
SCNOO | Rapid winder for Leica IIIa (model G), Leica IIIb | ca.1937 | - |
SDOOG | Tripod head with spring catch for rapidly fixing camera to tripod | 1936-1949 | - |
SDPOO | Close-focus attachment with "eyes" for F = 5 cm 1:2 Summicron II | 1956-1968 | - |
SELAN | Angle bracket to enable vertical flash unit | ca.1947 | - |
SELBA | Battery case for SELIS or SELBA flash units | 1947-19?? | - |
SELCA | 14 inch flex cable for vertical flash unit | ca.1947 | - |
SELEX | 10 foot flash cable for remote flash unit | 1947-19?? | - |
SELIS | Horizontal flash unit with delay slider for Leica IIc and Leica IIIc | 1947-19?? | - |
SELLO | 6 foot flash cable for remote flash unit | 1947-19?? | - |
SELOR | Three-way flash socket to attach leads to a synchronizer | 19??-19?? | - |
SELSY | Horizontal flash unit with delay slider for Leica cameras above sn. 111450 except Leica IIc and Leica IIIc per SELIS | 1947-19?? | - |
SEOOF | Summicron (I) f= 9 cm 1:2 | 1959-1962 | |
SEOOF-M | Summicron (I) f= 9 cm 1:2 | made in Canada only | |
SEOOM | Summicron (II) f= 9 cm 1:2 | 1959-1979 | - |
SEROO | Folding chrome or black (rare) viewfinder for 9 cm with parallax
SEVUE | Fixed cradle type, chrome & black viewfinder for 9 cm with paralax | 1949-19?? | NY item |
SFTOO | Mini-telescope viewfinder for 20 cm; black tapered rectangle | 1938-19?? | 12035, 12034- metric version |
SGOOD | Enclosed chrome, flared cone viewfinder for 85 mm with parallax adjustment by concentric ring like SGVOO | 1951-19?? | 12020 |
SGVOO | 90mm viewfinder/bright finder | 1951-? | 12025 |
SHADE | Replacement hood for Thambar f= 9 cm 1:2.2 | 1939-19?? | - |
SHOLD | Shoulder pad for a camera neck strap | 1950-19?? | NY item |
SHOOC | Enclosed chrome, flared cone viewfinder for 135 mm with parallax adjustment by concentric ring like SGVOO | 1951-19?? | 12030 |
SHOOE | Black, rangefinder accessory clip | 1949-1951 | 66260 NY item |
SHXOO | 13.8 mm shutter speed dial supplied free of charge for Leica's with a different sized dial | 19??-19?? | - |
SIMOM | Summaron f= 3.5 cm 1:2.8 for M2 | 1958-1974 | 11306 Y |
SIMOO | Summaron f= 3.5 cm 1:2.8 screw-mount | 1958-1963 | 11106 P |
SIMWO | Summaron f= 3.5 cm 1:2.8 for M3 boxed with "specs" and caps | 1958-1974 | 11106 Q |
SIUUB-Glas | Parvo 100 / Prado 100 projector with Hektor 2.5/8.5cm | 1949-1950 | - |
SIZOO | Folding viewfinder for 10.5 cm | 1935 | - |
SLOOZ | Viewfinder, 28 mm, black or chrome | 1960-? | 12007 |
SMUUY | Parvo 100 / Prado 100 projector with condenser I (f. 7.3-10cm) | 1949/ 1950 | - |
SMYOM | Rapid winder known as Leicavit-MP for M1, M2 and MD | 1960-1966 | 14008, 14018-with 3/8" bush |
SNHOO | Adaptor for using Summicron 42 mm E39 filters on Summitar | 1957-19?? | 13078 |
SNOOX | Summaron f= 2.8 cm 1:5.6 | 1955-1963 | - |
SOMKY | Close focus accessory for collapsible version of the Summicron or Elmar 50mm lens, and with the front element of the fixed Summicron with the use of an adapter called UOORF | 1956 | also called SOMKY-M |
SOMKY-UOORF | Close focus accessory for non-collapsible version of the Summicron with the use of an adapter called UOORF | 19??-19?? | 16509 |
SOMNI | Summicron (II) f= 5 cm 1:2 | 1956-1968 | 11 818 |
SOOAW | Fixed cradle type, chrome & black viewfinder for Hektor f= 7.3 cm 1:1.9 with or without parallax adjustment | 1943-19?? | Lager doubts SOOAW was produced commercially |
SOOBK | Hood for Summaron f= 2.8 cm 1:5.6 | ca.1955-1963 | - |
SOOCX | Summarex f= 8.5 cm 1:1.5 | 1948-1960 | - |
SOODL | Viewfinder, 50 mm | ca.1949 | Lager doubts SOODL was produced commercially |
SOOEY | Adaptor for use of Summitar type L filters on 42 mm lenses | 1957-19?? | 13077 |
SOOFM | Collapsible hood for 5 cm Summicron | 1954-19?? | - |
SOOGZ | Adaptor for ADVOO with lenses of 36 mm diameter; also for use of Summicron 42 mm, E39 filters on A36, 36 mm | 1955-19?? | 13154 |
SOOHN | Hood for Hektor f= 2.8 cm 1:6.3 | ca.1935-1955 | - |
SOOIA | Summarit f= 5 cm 1:1.5 | 1949-1960 | - |
SOOIA-M | F = 5 cm 1:1.5 Summarit | 1952-? | |
SOOIC | Summicron (I) f= 5 cm 1:2 | 1953-1960 | - |
SOOIC-M | Summicron (I) f= 5 cm 1:2 | 1954-1960 | - |
SOOKY | Close focus accessory for rangefinder Elmar 5c lens with parallax | 1954-19?? | - |
SOOKY-M | Close focus accessory for M-series Summicron or Elmar 5c lens with parallax; later called SOMKY | 1956-19?? | 16507 |
SOOLB | 85 mm "sport" viewfinder | 1959-1961 | 66155 |
SOOME | Summilux (I) f= 5 cm 1:1.4 | 1959-1961 | - |
SOONC | Summaron f= 3.5 cm 1:3.5 | 1948-1960 | - |
SOONC-M | Summaron f= 3.5 cm 1:3.5 | 1956-1960 | - |
SOONC-MW | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M3 | 1956-1960 | - |
SOONC-MT | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M2 | 1957-1960 | - |
SOOPD | Collapsible hood for 5 cm Summitar JCB's a little...IIIb | 1949-19?? | - |
SOOQR | Adaptor for use of Summitar type L filters on 42 mm lenses | 1954-1956 | - |
SOORE | Summitar f= 5 cm 1:2 | 1939-1955 | - |
SOOTF | Adaptor to use screw-in filters for 5 cm Summitar on A36 Elmar 9cm | 1939-1955 | 13079 |
SOOUV | Fixed cradle type, chrome & black viewfinder for 9 cm with or without parallax adjustment | 1943-19?? | - |
SOOYV | Fixed cradle type, chrome & black viewfinder for 13.5 cm with or without parallax adjustment | 1943-19?? | - |
SOOZI | Summicron (I) f= 9 cm 1:2 | 1957-1959 | - |
SOREI | Shutter release, soft, improved type; flared chrome cylinder | 1949-19?? | NY item |
SOSIC | F = 5 cm 1:2 Summicron II | 1956-1968 | - |
SPECS | Polaroid spectacles for stereo viewing | 1930's | - |
SPMOO | Copy stand special large base | 1938-19?? | - |
SPOOM | Spare film take-up spool | 1955-19?? | 14022 |
SPOOV | Horseshoe copy stand for rotating OORES with white board for specimin | 1936-19?? | - |
SPUCA | Spare film center cassette spool | ca.1953 | 14015 |
SPULM | Spare film take-up spool | 1931-1953 | - |
SQTOO | Mini-telescope viewfinder for 40 cm; black tapered rectangle | 1938-19?? | 12037, 12036- metric version |
STAFO | Four lamp, large copy stand array on column mounted crossbar | 1933-19?? | - |
STALI | Two lamp, small copy stand array on column mounted crossbar | 1931-19?? | - |
STAMA | Steel tape measure plumb-bob for copy stand | 1933-19?? | - |
STAOT | STARE copy stand + FLOTH plumb-bob | 1930's | - |
STARE | Open base, collapsible copy stand with canvas carrying bag | 1931-19?? | - |
STEFLA | Kodachrome flash filter; paired for Stemar | ca.1949- | NY item |
STEKOA | Kodachrome type A filter; paired for Stemar | ca.1949- | NY item |
STEKPF | Kodachrome photoflood filter; paired for Stemar | ca.1949- | NY item |
STERO | Stereoly camera attachment for Leica IIIb for taking stereo photgraphs | 1939-19?? | NY item |
STOOR | Four lamp, universal copy stand array on paired U-shaped sidebars | 1933-19?? | - |
STUOO | Steel tape measure; part of REROD | 1936-19?? | - |
STYYX | Four lamp, small copy stand array on paired sidebars for 1 1/4" column | 1939-19?? | NY item |
SUMAR | Summar f= 5 cm 1:2 (SUMUS in 1933 catalog) | 1933-1940 | - |
SUNGO | Replacement hood for 20 cm Telyt with clamping ring and set screw | 1939-19?? | NY item |
SUOON | Super-Angulon f= 2.1 cm 1:4 | 1958-1963 | - |
SUOOQ | Black or chrome folding viewfinder for Hektor f= 2.8 cm 1:6.3 | 1934-19?? | - |
SUUHN | Parvo 100 / Prado 100 projector with condenser II (f. 5cm Summar/ Sumwithar) | 1949-1950 | - |
SUUAI | Parvo 100 / Prado 100 projector with condenser III (f. 5cm Elmar/ Summar) | 1949-1950 | - |
SUUZI | Film strip holder for projectors | 1952 | - |
SUWOO | Mini-telescope viewfinder for single film housing; like the Leica Standard finder | 1935-19?? | - |
SVOOP | Spare take-up film spool for all cameras prior to Leica IIIg | 1954-19?? | 14021 |
SYBAT | Flash battery case extension to enable 3 cells to be used | 19??-19?? | - |
SYEOO | Folding "Sports" viewfinder for Hektor f= 13.5 cm 1:4.5 or Elmar f= 13.5 cm 1:4.5 | 1935-19?? | - |
SYNCO | Horizontal flash unit with sync-head for connecting to the base plate of Leica II, III, IIIa and IIIb | 1938-19?? | NY item |
SYOOM | Rapid winder for Leica IIIf or Leica IIIg | ca.1953 | - |
