T
TBKOO | Microscope to camera connector with correction lens | 1939-19?? | - |
TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
TEQOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13326 |
TFOOG | Yellow very light no. 0 filter; screw-on type E85 | ca.1938 | 13291 |
TFSOO | Yellow light no. 1 filter; screw-on type E85 | ca.1938 | 13296 |
TGOOF | Yellow medium no. 2 filter; screw-on type E85 | ca.1938 | - |
TGUOO | Infra-red light no. 1 filter; screw-on type E85 [1] | ca.1938 | 13316 |
THMOO | Replacemant hood for F = 40 cm 1:5 Telyt I | 1951-1955 | see also TMEOO |
THOOE | Infra-red medium no. 2 filter; screw-on type E85 | ca.1938 | 13316 |
THWOO | Infra-red dark no. 3 filter; screw-on type E85 | ca.1938 | 13326 |
TIOOD | UVa filter; screw-on type E85 | ca.1938 | 13331 |
TIYOO | Panchromatic green filter; screw-on type E85 | ca.1938 | 13306 |
TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
TMEOO | Replacemant hood for F = 40 cm 1:5 Telyt II | 1954-1966 | see also THMOO |
TNGOO | Replacemant hood for f = 20 cm 1:4 Telyt | 1954-19?? | see also THMOO |
TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
TOOQE | Small, table top tripod complete with FOOMI ball and socket | 1952-19?? | - |
TOOSF | 84 | 19??-19?? | - |
TOOUG | Small, table top tripod complete with FOOMI ball and socket; black crackle enamel; later gray enamel | 1952-19?? | 14100 |
TOWIN | 37 | 19??-19?? | - |
TREPL | Complete photomicrography outfit with microscope, mirror reflex housing and copy stand | 1938-19?? | - |
TROOV | Leather wrist strap with threaded connector | 1938-19?? | - |
TRPOO | Neck strap with patent hooks | 1951-19?? | - |
TRPOO-M | Neck strap with patent hooks for Leica-M | 1956-19?? | - |
TSOOV | Neck strap with split rings for atachment to camera side lugs; later version has non-slip shoulder pad | 1960-19?? | 14092 |
TUSOO | Steel tape measure for ROOFU arm | 1951-19?? | - |
TUVOO | Chrome attachment for VIOOH viewfinder for 2.8 cm lenses | ? | - |
TXBOO | Extension tube for TEYLT's on M-cameras | 19??-19?? | 14024 |
TZFOO | Extension tube for TEYLT's on screw cameras | 19??-19?? | - |
TZOON | Extension tube for TEYLT's on screw cameras, early version | 19??-19?? | 14023 |
