E
EAWOO | - | ||
EBOOH | Everready leather case for R3 | ca.1961 | 14615 Q |
ECUUG | ca.1961 | 37033 B | |
EDCUU | ca.1961 | 37044 N | |
EDUUF | ca.1961 | 37066 L | |
EELUD | - | ||
EEPMG | Macro lamp, a circle with 4 x 25 W bulbs | ? | - |
EEPLG | Macro lamp, a circle with 4 x 40 W bulbs | ? | - |
EEPSV | Small holder for auxiliary GUHII, for screw mounting to the macro state MADAH | ? | - |
EEPSU | Larger holder for auxiliary GUHII, for screw mounting to the macro state MADAH | ca. 1956 | - |
EEVRN | Tapered bellows for large format with tape measure | - | |
EEXRL | Holder for ISOFLEX | ? | - |
EEXRM | Holder for ISOFLEX | ca.1955 | - |
EEXSN | Holder for ISOFLEX with hammer paint finish | ? | - |
EEZYX | Slide device MACRODIA for macro photography | ? | - |
EFERN | Elmar f= 13.5 cm 1:4.5 nickel finish | ? | - |
EFGOO | Everready leather case for Leica IIc, IIf, IIIc, IIIf with 50mm Summicron or Summitar and attached universal or mirror viewfinder | ca.1961 | -37088 K |
EGIUU | ca.1961 | 37077 P | |
EGOOI | - | ||
EGUUC | ca.1961 | 37099 N | |
EITPL | - | ||
EKURZ | Elmar f= 3.5 cm 1:3.5 chrome finish | 1933-1950 | - |
EKURZUP | Elmar f= 3.5 cm 1:3.5 nickel finish | 1930-1933 | - |
EKUUZ | ca.1961 | 32600 G | |
ELANG | Elmar (II) f= 9 cm 1:4 | 1930-1945 | - |
ELANG-M | Elmar (III) 1:4 / 90mm | 1954-1968 | - |
ELCAR | Early close-up lens for Compur Leica (model B) | ? | - |
ELCAT | Late close-up lens for Compur Leica (model B) | 1930 | - |
ELCOM | Early close-up lens for Compur Leica (model B) diopter No. 2 | ? | - |
ELCON | Late close-up lens for Compur Leica (model B) diopter No. 2 | ? | - |
ELCUR | Early close-up lens for Compur Leica (model B) diopter No. 3 | ? | - |
ELCUS | Late close-up lens for Compur Leica (model B) diopter No. 3 | ? | - |
ELDIA | Contact printer for 35 mm negatives | pre 1937 | - |
ELDUR | Contact printer to make 2 x 2” lantern slides | pre 1937 | - |
ELDUS | - | ||
ELESS | - | ||
ELGAM | Elmar (III) 1:4 / 90mm | 1946-1963 | 11 830 |
ELGLA | Metal pressure plate for ELDUR contact printer | pre 1937 | - |
ELKIM | Movie window panel 18x24 cm for contacts from Cinema negatives | ? | - |
ELKIN | Movie window panel 18x24 cm for contacts from Cinema negatives | ? | - |
ELKOO | - | ||
ELMAR | Elmar (I) f= 5 cm 1:3.5 | 1931-1959 | - |
ELMAM | Elmar (III) f= 5 cm 1:3.5 with M-bayonet | 1954-1961 | 11 610 |
ELMOM | Elmar f= 5 cm 1:2.8 with M-bayonet | 1958-1966 | 11 612 |
ELMOO | Elmar f= 5 cm 1:2.8 | 1957-1962 | - |
ELPAS | Close-Up lens no.1 for dial-set Compur Leica (model B) | 1927 | - |
ELPET | Close-up lens No. 3 for Elmar | ? | - |
ELPEX | Close-up lens No. 3 for Summar | ? | - |
ELPEZ | Close-up lens No. 3 for Summitar | ? | - |
ELPIK | Close-up lens No. 2 for Elmar | ? | - |
ELPIL | Close-up lens No. 2 for Summar | ? | - |
ELPIS | Close-up lens No. 2 for Summitar | ? | - |
ELPRO | Close-up lens attachments for R-50 mm, 90 mm and 135 mm | 1966-2009 | - |
ELPUR | - | ||
ELPYN | - | ||
ELRIM | Elmarit f= 9 cm 1:2.8 with bayonet mount | 1959-1974 | - |
ELRIT | Elmarit f= 9 cm 1:2.8 with screw mount | 1959-1963 | 11 029 |
ELROO | Elmar f= 3,5 1:4, “snap-shot” lens, prototype only | ca.1950 | - |
ELRUU | - | ||
ELUUY | - | ||
ELZEN | The “Mountain Elmar” Elmar f= 10.5 cm 1:6.3 | 1932-1937 | - |
EMQOO | - | ||
EMTOO | Telyt leather case | 14585 B | |
EMTUU | 32620 T | ||
EMUUX | 32630 V | ||
ENUUW | - | ||
EPOCH | Small canvas case for LEICA III or Standard | ca.1933 | - |
ERKOM | 11128 M | ||
ESFAB | Everready leather case for LEICA III or Standard with non-colapsing Summar | ca.1933 | - |
ESFOO | Everready leather case for LEICA 250 | - | |
ESFUS | Everready leather case for Leica IIc, IIf, IIIc, IIIf with 50mm Summicron or Summitar | ? | - |
ESMAL | Everready leather case for LEICA III | ca.1933 | - |
ESMOS | Everready leather case for LEICA III or Standard with long lens | ca.1933 | - |
ESNAR | Everready leather case for LEICA III or Standard | ca.1933 | - |
ESNEL | Everready leather case for Leica I (model A) | - | |
ESOOG | Everready leather case for Leica Ic or Leica Ig JCB's a little...Ig | 1949-1952 | JCB's a little...Ic |
ETBIX | Leather lens case without strap for Summar 5 cm 1:2 | ca.1933 | - |
ETGUS | Large leather accessory case (19.5 x 24.5 x 8 cm) for camera and 5 lenses | ca.1933 | - |
ETIFF | Leather lens case with strap for Elmar 10.5 cm | ca.1933 | - |
ETILA | Leather lens case without strap for Elmar 3.5 cm | ca.1933 | - |
ETIME | Leather lens case without strap for Hektor or Elmar 5 cm | ca.1933 | - |
ETINI | Leather lens case with strap for Elmar 9 cm | ca.1933 | JCB's a little...IIf |
ETINX | Leather lens case with strap for Hektor 7.3 cm | ca.1933 | - |
ETIPO | Leather lens case with strap for Elmar or Hektor 13.5 cm | ca.1933 | - |
ETISY | Leather lens case with strap for Elmar or Hektor 13.5 cm and Elmar 3.5 cm | ca.1933 | - |
ETKAL | Small lady's canvas case for LEICA III or Standard | ca.1933 | - |
ETMAX | Large leather accessory case (22.5 x 29.5 x 8 cm) for camera and 7 lenses similar to ETGUS | ca.1933 | - |
ETNEU | Large leather accessory case (18.5 x 25.5 x 8 cm) for camera and 4 lenses similar to ETGUS | ca.1933 | - |
ETOSA | Leather lens case with strap for Hektor 7.3 cm and Elmar 3.5 cm | ca.1933 | - |
ETRIN | Leather accessory case (16 x 11 x 5 cm) for LEICA III or Standard | ca.1933 | - |
ETRUX | Small vertical leather case for LEICA III or Standard | ca.1933 | - |
ETTAS | Small canvas case for LEICA III or Standard | ca.1933 | - |
ETTEL | Small canvas case for LEICA III or Standard | ca.1933 | - |
ETTRE | Large leather accessory case (15.5 x 15.5 x 8 cm) for camera and 3 lenses similar to ETGUS | ca.1933 | - |
ETTWO | Leather accessory case (17 x 15 x 5.5 cm) for LEICA III or Standard | ca.1933 | - |
ETXBE | Small bellows, used with EEXSN and Aristophot II micro-photgraphy | ? | - |
ETXBS | Small bellows, used with Aristophot II micro-photgraphy | ? | - |
EUKOS | Everready case for Standard Leica (model E) | - | |
EUKUT | Deerskin purse for one lens filter | pre 1934 | - |
EUROS | - | ||
EUVER | - | ||
EUVIL | Morocon leather purse for one lens filter | pre 1934 | - |
EXCOR | - | ||
EUDIT | Leather case for FODUA Leica I (model A) | ? | - |
EUSAF | Small canvas case for Standard with long lens | ca.1933 | - |
EYMZE | 6-volt lamp housing with a focusing objective, and 2 blue glass filters | ? | - |
EYMZG | 6-volt lamp housing with a focusing objective, and 2 green glass filters | ? | - |
EYMZH | 6-volt lamp housing with a focusing objective, and 2 filters | ? | - |
EZDOO | Leather strap for 125mm Hektor | - |
