S
| SAIOO | Folding type "Sports" viewfinder for Hektor f= 7.3 cm 1:1.9 lens | 1935-19?? | - |
| SAMWO | F = 3.5 cm 1:2 Summicron I for M3 | 1958-1969 | 11108 |
| SAWOM | 35mm f/2 Summicron II for M2 | 1958-1969 | 11 308 |
| SAWOO | Summicron (I) f= 3.5 cm 1:2 | 1958-1963 | 11 008 |
| SBKOO | Enclosed chrome, flared cone viewfinder for 21 mm with parallax adjustment by concentric ring like SGVOO ; later versions are black | ca.1960 | 12002 |
| SBLOO | Finder for Summaron f= 3.5 cm 1:3.5 | ca.1951-1960 | 12010 |
| SBOOI | Enclosed, cylindrical viewfinder for 5 cm lenses JCB's a little...Ig | ca.1951-1960 | 12015 JCB's a little...Ic |
| SCNOO | Rapid winder for Leica IIIa (model G), Leica IIIb | ca.1937 | JCB's a little...IIIa |
| SDOOG | Tripod head with spring catch for rapidly fixing camera to tripod | 1936-1949 | - |
| SDPOO | Close-focus attachment with "eyes" for F = 5 cm 1:2 Summicron II | 1956-1968 | - |
| SELAN | Angle bracket to enable vertical flash unit | ca.1947 | - |
| SELBA | Battery case for SELIS or SELBA flash units | 1947-19?? | - |
| SELCA | 14 inch flex cable for vertical flash unit | ca.1947 | - |
| SELEX | 10 foot flash cable for remote flash unit | 1947-19?? | - |
| SELIS | Horizontal flash unit with delay slider for Leica IIc and Leica IIIc | 1947-19?? | - |
| SELLO | 6 foot flash cable for remote flash unit | 1947-19?? | - |
| SELOR | Three-way flash socket to attach leads to a synchronizer | 19??-19?? | - |
| SELSY | Horizontal flash unit with delay slider for Leica cameras above sn. 111450 except Leica IIc and Leica IIIc per SELIS | 1947-19?? | - |
| SEOOF | Summicron (I) f= 9 cm 1:2 | 1959-1962 | |
| SEOOF-M | Summicron (I) f= 9 cm 1:2 | made in Canada only | |
| SEOOM | Summicron (II) f= 9 cm 1:2 | 1959-1979 | - |
| SEROO | Folding chrome or black (rare) viewfinder for 9 cm with parallax | 1935-19?? | JCB's...a little III |
| SEVUE | Fixed cradle type, chrome & black viewfinder for 9 cm with paralax | 1949-19?? | NY item |
| SFTOO | Mini-telescope viewfinder for 20 cm; black tapered rectangle | 1938-19?? | 12035, 12034- metric version |
| SGOOD | Enclosed chrome, flared cone viewfinder for 85 mm with parallax adjustment by concentric ring like SGVOO | 1951-19?? | 12020 |
| SGVOO | 90mm viewfinder/bright finder | 1951-? | 12025 |
| SHADE | Replacement hood for Thambar f= 9 cm 1:2.2 | 1939-19?? | - |
| SHOLD | Shoulder pad for a camera neck strap | 1950-19?? | NY item |
| SHOOC | Enclosed chrome, flared cone viewfinder for 135 mm with parallax adjustment by concentric ring like SGVOO | 1951-19?? | 12030 |
| SHOOE | Black, rangefinder accessory clip | 1949-1951 | 66260 NY item |
| SHXOO | 13.8 mm shutter speed dial supplied free of charge for Leica's with a different sized dial | 19??-19?? | - |
| SIMOM | Summaron f= 3.5 cm 1:2.8 for M2 | 1958-1974 | 11306 Y |
| SIMOO | Summaron f= 3.5 cm 1:2.8 screw-mount | 1958-1963 | 11106 P |
| SIMWO | Summaron f= 3.5 cm 1:2.8 for M3 boxed with "specs" and caps | 1958-1974 | 11106 Q |
| SIUUB-Glas | Parvo 100 / Prado 100 projector with Hektor 2.5/8.5cm | 1949-1950 | - |
| SIZOO | Folding viewfinder for 10.5 cm | 1935 | - |
| SLOOZ | Viewfinder, 28 mm, black or chrome | 1960-? | 12007 |
| SMUUY | Parvo 100 / Prado 100 projector with condenser I (f. 7.3-10cm) | 1949/ 1950 | - |
| SMYOM | Rapid winder known as Leicavit-MP for M1, M2 and MD | 1960-1966 | 14008, 14018-with 3/8" bush |
| SNHOO | Adaptor for using Summicron 42 mm E39 filters on Summitar | 1957-19?? | 13078 |
| SNOOX | Summaron f= 2.8 cm 1:5.6 | 1955-1963 | - |
| SOMKY | Close focus accessory for collapsible version of the Summicron or Elmar 50mm lens, and with the front element of the fixed Summicron with the use of an adapter called UOORF | 1956 | also called SOMKY-M |
| SOMKY-UOORF | Close focus accessory for non-collapsible version of the Summicron with the use of an adapter called UOORF | 19??-19?? | 16509 |
| SOMNI | Summicron (II) f= 5 cm 1:2 | 1956-1968 | 11 818 |
| SOMWO | M3 fitting with "eyes" for Summaron f= 3.5 cm 1:3.5 | 1958-19?? | JCB's a little...M3 |
| SOOAW | Fixed cradle type, chrome & black viewfinder for Hektor f= 7.3 cm 1:1.9 with or without parallax adjustment | 1943-19?? | Lager doubts SOOAW was produced commercially |
| SOOBK | Hood for Summaron f= 2.8 cm 1:5.6 | ca.1955-1963 | - |
| SOOCX | Summarex f= 8.5 cm 1:1.5 | 1948-1960 | - |
| SOODL | Viewfinder, 50 mm | ca.1949 | Lager doubts SOODL was produced commercially |
| SOOEY | Adaptor for use of Summitar type L filters on 42 mm lenses | 1957-19?? | 13077 |
| SOOFM | Collapsible hood for 5 cm Summicron | 1954-19?? | - |
| SOOGZ | Adaptor for ADVOO with lenses of 36 mm diameter; also for use of Summicron 42 mm, E39 filters on A36, 36 mm | 1955-19?? | 13154 |
| SOOHN | Hood for Hektor f= 2.8 cm 1:6.3 | ca.1935-1955 | - |
| SOOIA | Summarit f= 5 cm 1:1.5 | 1949-1960 | - |
| SOOIA-M | F = 5 cm 1:1.5 Summarit | 1952-? | |
| SOOIC | Summicron (I) f= 5 cm 1:2 | 1953-1960 | - |
| SOOIC-M | Summicron (I) f= 5 cm 1:2 | 1954-1960 | - |
| SOOKY | Close focus accessory for rangefinder Elmar 5c lens with parallax | 1954-19?? | - |
| SOOKY-M | Close focus accessory for M-series Summicron or Elmar 5c lens with parallax; later called SOMKY | 1956-19?? | 16507 |
| SOOLB | 85 mm "sport" viewfinder | 1959-1961 | 66155 |
| SOOME | Summilux (I) f= 5 cm 1:1.4 | 1959-1961 | - |
| SOOMP | Summar f= 5 cm 1:2 | 1936 | Wetzlar & NY versions |
| SOONC | Summaron f= 3.5 cm 1:3.5 | 1948-1960 | - |
| SOONC-M | Summaron f= 3.5 cm 1:3.5 | 1956-1960 | - |
| SOONC-MW | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M3 | 1956-1960 | JCB's a little...M3 |
| SOONC-MT | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M2 | 1957-1960 | - |
| SOOPD | Collapsible hood for 5 cm Summitar JCB's a little...IIIb | 1949-19?? | - |
| SOOQR | Adaptor for use of Summitar type L filters on 42 mm lenses | 1954-1956 | - |
| SOORE | Summitar f= 5 cm 1:2 | 1939-1955 | - |
| SOOTF | Adaptor to use screw-in filters for 5 cm Summitar on A36 Elmar 9cm | 1939-1955 | 13079 |
| SOOUT | Cradle type viewfinder for 90 mm lens | 1943-1949 | JCB's a little...Ic |
| SOOUV | Fixed cradle type, chrome & black viewfinder for 9 cm with or without parallax adjustment | 1943-19?? | - |
| SOOYV | Fixed cradle type, chrome & black viewfinder for 13.5 cm with or without parallax adjustment | 1943-19?? | - |
| SOOZI | Summicron (I) f= 9 cm 1:2 | 1957-1959 | - |
| SOREI | Shutter release, soft, improved type; flared chrome cylinder | 1949-19?? | NY item |
| SOSIC | F = 5 cm 1:2 Summicron II | 1956-1968 | - |
| SPECS | Polaroid spectacles for stereo viewing | 1930's | - |
| SPMOO | Copy stand special large base | 1938-19?? | - |
| SPOOM | Spare film take-up spool | 1955-19?? | 14022 |
| SPOOV | Horseshoe copy stand for rotating OORES with white board for specimin | 1936-19?? | - |
| SPUCA | Spare film center cassette spool | ca.1953 | 14015 |
| SPULM | Spare film take-up spool | 1931-1953 | - |
| SQTOO | Mini-telescope viewfinder for 40 cm; black tapered rectangle | 1938-19?? | 12037, 12036- metric version |
| STAFO | Four lamp, large copy stand array on column mounted crossbar | 1933-19?? | - |
| STALI | Two lamp, small copy stand array on column mounted crossbar | 1931-19?? | - |
| STAMA | Steel tape measure plumb-bob for copy stand | 1933-19?? | - |
| STAOT | STARE copy stand + FLOTH plumb-bob | 1930's | - |
| STARE | Open base, collapsible copy stand with canvas carrying bag | 1931-19?? | - |
| STEFLA | Kodachrome flash filter; paired for Stemar | ca.1949- | NY item |
| STEKOA | Kodachrome type A filter; paired for Stemar | ca.1949- | NY item |
| STEKPF | Kodachrome photoflood filter; paired for Stemar | ca.1949- | NY item |
| STERO | Stereoly camera attachment for Leica IIIb for taking stereo photgraphs | 1939-19?? | NY item |
| STOOR | Four lamp, universal copy stand array on paired U-shaped sidebars | 1933-19?? | - |
| STUOO | Steel tape measure; part of REROD | 1936-19?? | - |
| STYYX | Four lamp, small copy stand array on paired sidebars for 1 1/4" column | 1939-19?? | NY item |
| SUMAR | Summar f= 5 cm 1:2 (SUMUS in 1933 catalog) | 1933-1940 | - |
| SUNGO | Replacement hood for 20 cm Telyt with clamping ring and set screw | 1939-19?? | NY item |
| SUOON | Super-Angulon f= 2.1 cm 1:4 | 1958-1963 | - |
| SUOOQ | Black or chrome folding viewfinder for Hektor f= 2.8 cm 1:6.3 | 1934-19?? | - |
| SUUHN | Parvo 100 / Prado 100 projector with condenser II (f. 5cm Summar/ Sumwithar) | 1949-1950 | - |
| SUUAI | Parvo 100 / Prado 100 projector with condenser III (f. 5cm Elmar/ Summar) | 1949-1950 | - |
| SUUZI | Film strip holder for projectors | 1952 | - |
| SUWOO | Mini-telescope viewfinder for single film housing; like the Leica Standard finder | 1935-19?? | - |
| SVOOP | Spare take-up film spool for all cameras prior to Leica IIIg | 1954-19?? | 14021 |
| SYBAT | Flash battery case extension to enable 3 cells to be used | 19??-19?? | - |
| SYEOO | Folding "Sports" viewfinder for Hektor f= 13.5 cm 1:4.5 or Elmar f= 13.5 cm 1:4.5 | 1935-19?? | JCB's a little...III |
| SYNCO | Horizontal flash unit with sync-head for connecting to the base plate of Leica II, III, IIIa and IIIb | 1938-19?? | NY item |
| SYOOM | Rapid winder for Leica IIIf or Leica IIIg | ca.1953 | - |
| SYOOM-M | Rapid winder for MP and MP2 or M2 | ca.1957 | JCB's a little...M2 |
