T
| TBKOO | Microscope to camera connector with correction lens | 1939-19?? | - |
| TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
| TEQOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13326 |
| TFOOG | Yellow very light no. 0 filter; screw-on type E85 | ca.1938 | 13291 |
| TFSOO | Yellow light no. 1 filter; screw-on type E85 | ca.1938 | 13296 |
| TGOOF | Yellow medium no. 2 filter; screw-on type E85 | ca.1938 | - |
| TGUOO | Infra-red light no. 1 filter; screw-on type E85 JCB's a little...9 | ca.1938 | 13316 |
| THMOO | Replacemant hood for F = 40 cm 1:5 Telyt I | 1951-1955 | see also TMEOO |
| THOOE | Infra-red medium no. 2 filter; screw-on type E85 | ca.1938 | 13316 |
| THWOO | Infra-red dark no. 3 filter; screw-on type E85 | ca.1938 | 13326 |
| TIOOD | UVa filter; screw-on type E85 | ca.1938 | 13331 |
| TIYOO | Panchromatic green filter; screw-on type E85 | ca.1938 | 13306 |
| TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
| TMEOO | Replacemant hood for F = 40 cm 1:5 Telyt II | 1954-1966 | see also THMOO |
| TNGOO | Replacemant hood for f = 20 cm 1:4 Telyt | 1954-19?? | see also THMOO |
| TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
| TOOLP | F = 20 cm 1:4.5 Telyt | 1935-19?? | - |
| TOOQE | Small, table top tripod complete with FOOMI ball and socket | 1952-19?? | - |
| TOOSF | Table-top tripod (per Accessory Guide page 84) | ca.1936 | - |
| TOOUG | Small, table top tripod complete with FOOMI ball and socket; black crackle enamel; later gray enamel | 1952-19?? | 14100 JCB's a little...17 |
| TOWIN | Stereo tandem coupling (per Accessory Guide page 37) | 1949-1950 | NY item |
| TREPL | Complete photomicrography outfit with microscope, mirror reflex housing and copy stand | 1938-19?? | - |
| TROOV | Leather wrist strap with threaded connector | 1938-19?? | - |
| TRPOO | Neck strap with patent hooks | 1951-19?? | - |
| TRPOO-M | Neck strap with patent hooks for Leica-M | 1956-19?? | - |
| TSOOV | Neck strap with split rings for atachment to camera side lugs; later version has non-slip shoulder pad | 1960-19?? | 14092 |
| TUSOO | Steel tape measure for ROOFU arm | 1951-19?? | - |
| TUVOO | Chrome attachment for VIOOH viewfinder for 2.8 cm lenses | ? | - |
| TXBOO | Extension tube for TEYLT's on M-cameras | 19??-19?? | 14024 |
| TZFOO | Extension tube for TEYLT's on screw cameras | 19??-19?? | - |
| TZOON | Extension tube for TEYLT's on screw cameras, early version | 19??-19?? | 14023 |
