S
Revision as of 22:25, 3 February 2010 by Admin (talk | contribs)
SAIOO Folding type "Sports" viewfinder for Hektor f= 7.3 cm 1:1.9 lens 1935-19?? -
SAMWO F = 3.5 cm 1:2 Summicron I for M3 1958-1969 11108
SAWOM 35mm f/2 Summicron II for M2 1958-1969 11 308
SAWOO Summicron (I) f= 3.5 cm 1:2 1958-1963 11 008
SBKOO Enclosed chrome, flared cone viewfinder for 21 mm with parallax adjustment by concentric ring like SGVOO ; later versions are black ca.1960 12002
SBLOO Finder for Summaron f= 3.5 cm 1:3.5 ca.1951-1960 12010
SBOOI Enclosed, cylindrical viewfinder for 5 cm lenses JCB's a little...Ig ca.1951-1960 12015 JCB's a little...Ic
SCNOO Rapid winder for Leica IIIa (model G), Leica IIIb ca.1937 JCB's a little...IIIa
SDOOG Tripod head with spring catch for rapidly fixing camera to tripod 1936-1949 -
SDPOO Close-focus attachment with "eyes" for F = 5 cm 1:2 Summicron II 1956-1968 -
SELAN Angle bracket to enable vertical flash unit ca.1947 -
SELBA Battery case for SELIS or SELBA flash units 1947-19?? -
SELCA 14 inch flex cable for vertical flash unit ca.1947 -
SELEX 10 foot flash cable for remote flash unit 1947-19?? -
SELIS Horizontal flash unit with delay slider for Leica IIc and Leica IIIc 1947-19?? -
SELLO 6 foot flash cable for remote flash unit 1947-19?? -
SELOR Three-way flash socket to attach leads to a synchronizer 19??-19?? -
SELSY Horizontal flash unit with delay slider for Leica cameras above sn. 111450 except Leica IIc and Leica IIIc per SELIS 1947-19?? -
SEOOF Summicron (I) f= 9 cm 1:2 1959-1962
SEOOF-M Summicron (I) f= 9 cm 1:2 made in Canada only
SEOOM Summicron (II) f= 9 cm 1:2 1959-1979 -
SEROO Folding chrome or black (rare) viewfinder for 9 cm with parallax 1935-19?? JCB's...a little III
SEVUE Fixed cradle type, chrome & black viewfinder for 9 cm with paralax 1949-19?? NY item
SFTOO Mini-telescope viewfinder for 20 cm; black tapered rectangle 1938-19?? 12035, 12034- metric version
SGOOD Enclosed chrome, flared cone viewfinder for 85 mm with parallax adjustment by concentric ring like SGVOO 1951-19?? 12020
SGVOO 90mm viewfinder/bright finder 1951-? 12025
SHADE Replacement hood for Thambar f= 9 cm 1:2.2 1939-19?? -
SHOLD Shoulder pad for a camera neck strap 1950-19?? NY item
SHOOC Enclosed chrome, flared cone viewfinder for 135 mm with parallax adjustment by concentric ring like SGVOO 1951-19?? 12030
SHOOE Black, rangefinder accessory clip 1949-1951 66260 NY item
SHXOO 13.8 mm shutter speed dial supplied free of charge for Leica's with a different sized dial 19??-19?? -
SIMOM Summaron f= 3.5 cm 1:2.8 for M2 1958-1974 11306 Y
SIMOO Summaron f= 3.5 cm 1:2.8 screw-mount 1958-1963 11106 P
SIMWO Summaron f= 3.5 cm 1:2.8 for M3 boxed with "specs" and caps 1958-1974 11106 Q
SIUUB-Glas Parvo 100 / Prado 100 projector with Hektor 2.5/8.5cm 1949-1950 -
SIZOO Folding viewfinder for 10.5 cm 1935 -
SLOOZ Viewfinder, 28 mm, black or chrome 1960-? 12007
SMUUY Parvo 100 / Prado 100 projector with condenser I (f. 7.3-10cm) 1949/ 1950 -
SMYOM Rapid winder known as Leicavit-MP for M1, M2 and MD 1960-1966 14008, 14018-with 3/8" bush
SNHOO Adaptor for using Summicron 42 mm E39 filters on Summitar [1] 1957-19?? 13078
SNOOX Summaron f= 2.8 cm 1:5.6 1955-1963 -
SOMKY Close focus accessory for collapsible version of the Summicron or Elmar 50mm lens, and with the front element of the fixed Summicron with the use of an adapter called UOORF 1956 also called SOMKY-M
SOMKY-UOORF Close focus accessory for non-collapsible version of the Summicron with the use of an adapter called UOORF 19??-19?? 16509
SOMNI Summicron (II) f= 5 cm 1:2 1956-1968 11 818
SOMWO M3 fitting with "eyes" for Summaron f= 3.5 cm 1:3.5 1958-19?? JCB's a little...M3
SOOAW Fixed cradle type, chrome & black viewfinder for Hektor f= 7.3 cm 1:1.9 with or without parallax adjustment 1943-19?? Lager doubts SOOAW was produced commercially
SOOBK Hood for Summaron f= 2.8 cm 1:5.6 ca.1955-1963 -
SOOCX Summarex f= 8.5 cm 1:1.5 1948-1960 -
SOODL Viewfinder, 50 mm ca.1949 Lager doubts SOODL was produced commercially
SOOEY Adaptor for use of Summitar type L filters on 42 mm lenses 1957-19?? 13077
SOOFM Collapsible hood for 5 cm Summicron 1954-19?? -
SOOGZ Adaptor for ADVOO with lenses of 36 mm diameter; also for use of Summicron 42 mm, E39 filters on A36, 36 mm 1955-19?? 13154 Forum discussion
SOOHN Hood for Hektor f= 2.8 cm 1:6.3 ca.1935-1955 -
SOOIA Summarit f= 5 cm 1:1.5 1949-1960 -
SOOIA-M F = 5 cm 1:1.5 Summarit 1952-?
SOOIC Summicron (I) f= 5 cm 1:2 1953-1960 -
SOOIC-M Summicron (I) f= 5 cm 1:2 1954-1960 -
SOOKY Close focus accessory for rangefinder Elmar 5c lens with parallax 1954-19?? -
SOOKY-M Close focus accessory for M-series Summicron or Elmar 5c lens with parallax; later called SOMKY 1956-19?? 16507
SOOLB 85 mm "sport" viewfinder 1959-1961 66155
SOOME Summilux (I) f= 5 cm 1:1.4 1959-1961 -
SOOMP Summar f= 5 cm 1:2 1936 Wetzlar & NY versions
SOONC Summaron f= 3.5 cm 1:3.5 1948-1960 -
SOONC-M Summaron f= 3.5 cm 1:3.5 1956-1960 -
SOONC-MW Summaron f= 3.5 cm 1:3.5 with viewfinder for the M3 1956-1960 JCB's a little...M3
SOONC-MT Summaron f= 3.5 cm 1:3.5 with viewfinder for the M2 1957-1960 -
SOOPD Collapsible hood for 5 cm Summitar JCB's a little...IIIb 1949-19?? -
SOOQR Adaptor for use of Summitar type L filters on 42 mm lenses 1954-1956 -
SOORE Summitar f= 5 cm 1:2 1939-1955 -
SOOTF Adaptor to use screw-in filters for 5 cm Summitar on A36 Elmar 9cm 1939-1955 13079
SOOUT Cradle type viewfinder for 90 mm lens 1943-1949 JCB's a little...Ic
SOOUV Fixed cradle type, chrome & black viewfinder for 9 cm with or without parallax adjustment 1943-19?? -
SOOYV Fixed cradle type, chrome & black viewfinder for 13.5 cm with or without parallax adjustment 1943-19?? -
SOOZI Summicron (I) f= 9 cm 1:2 1957-1959 -
SOREI Shutter release, soft, improved type; flared chrome cylinder 1949-19?? NY item
SOSIC F = 5 cm 1:2 Summicron II 1956-1968 -
SPECS Polaroid spectacles for stereo viewing 1930's -
SPMOO Copy stand special large base 1938-19?? -
SPOOM Spare film take-up spool 1955-19?? 14022
SPOOV Horseshoe copy stand for rotating OORES with white board for specimin 1936-19?? -
SPUCA Spare film center cassette spool ca.1953 14015
SPULM Spare film take-up spool 1931-1953 -
SQTOO Mini-telescope viewfinder for 40 cm; black tapered rectangle 1938-19?? 12037, 12036- metric version
STAFO Four lamp, large copy stand array on column mounted crossbar 1933-19?? -
STALI Two lamp, small copy stand array on column mounted crossbar 1931-19?? -
STAMA Steel tape measure plumb-bob for copy stand 1933-19?? -
STAOT STARE copy stand + FLOTH plumb-bob 1930's -
STARE Open base, collapsible copy stand with canvas carrying bag 1931-19?? -
STEFLA Kodachrome flash filter; paired for Stemar ca.1949- NY item
STEKOA Kodachrome type A filter; paired for Stemar ca.1949- NY item
STEKPF Kodachrome photoflood filter; paired for Stemar ca.1949- NY item
STERO Stereoly camera attachment for Leica IIIb for taking stereo photgraphs 1939-19?? NY item
STOOR Four lamp, universal copy stand array on paired U-shaped sidebars 1933-19?? -
STUOO Steel tape measure; part of REROD 1936-19?? -
STYYX Four lamp, small copy stand array on paired sidebars for 1 1/4" column 1939-19?? NY item
SUMAR Summar f= 5 cm 1:2 (SUMUS in 1933 catalog) 1933-1940 -
SUNGO Replacement hood for 20 cm Telyt with clamping ring and set screw 1939-19?? NY item
SUOON Super-Angulon f= 2.1 cm 1:4 1958-1963 -
SUOOQ Black or chrome folding viewfinder for Hektor f= 2.8 cm 1:6.3 1934-19?? -
SUUHN Parvo 100 / Prado 100 projector with condenser II (f. 5cm Summar/ Sumwithar) 1949-1950 -
SUUAI Parvo 100 / Prado 100 projector with condenser III (f. 5cm Elmar/ Summar) 1949-1950 -
SUUZI Film strip holder for projectors 1952 -
SUWOO Mini-telescope viewfinder for single film housing; like the Leica Standard finder 1935-19?? -
SVOOP Spare take-up film spool for all cameras prior to Leica IIIg 1954-19?? 14021
SYBAT Flash battery case extension to enable 3 cells to be used 19??-19?? -
SYEOO Folding "Sports" viewfinder for Hektor f= 13.5 cm 1:4.5 or Elmar f= 13.5 cm 1:4.5 1935-19?? JCB's a little...III
SYNCO Horizontal flash unit with sync-head for connecting to the base plate of Leica II, III, IIIa and IIIb 1938-19?? NY item
SYOOM Rapid winder for Leica IIIf or Leica IIIg ca.1953 -
SYOOM-M Rapid winder for MP and MP2 or M2 ca.1957 JCB's a little...M2
