Digilux 2
[Cick-to-Turn [1]]
Type - Small, high-proformance, digital fixed-lens camera.
Lens - LEICA DC VARIO-SUMMICRON 7 > 22.5 mm f/2.0 > 2.4 ASPH. zoom lens (corresponds to a 28 > 90 mm zoom lens for the 35 mm format), 13 lens elements in 10 groups.
Focus range - Close-up limit 30 cm (ca. 12 inches).
Weight - ca. 630 / 705 gm or 22 / 25 oz (with / without battery).
Camera body - Metal & black plastic.
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder.
- specifications adapted from manufacturer's technical data of June 2006. Leica Tecnical Data
--Tdavis 01:32, 17 November 2008 (CET)
Launched - December 1, 2003+.
Era - February 2004 > 2006 http://www.overgaard.dk/leica_digilux2.html
