T
Revision as of 17:14, 6 February 2010 by Admin (talk | contribs)
TBKOO Microscope to camera connector with correction lens 1939-19?? -
TELOO F = 20 cm 1:4 Telyt 1956-1966 -
TEQOO Infra-red light no. 1 filter; screw-on type E85 ca.1938 13326
TFOOG Yellow very light no. 0 filter; screw-on type E85 ca.1938 13291
TFSOO Yellow light no. 1 filter; screw-on type E85 ca.1938 13296
TGOOF Yellow medium no. 2 filter; screw-on type E85 ca.1938 -
TGUOO Infra-red light no. 1 filter; screw-on type E85 JCB's a little...9 ca.1938 13316
THMOO Replacemant hood for F = 40 cm 1:5 Telyt I 1951-1955 see also TMEOO
THOOE Infra-red medium no. 2 filter; screw-on type E85 ca.1938 13316
THWOO Infra-red dark no. 3 filter; screw-on type E85 ca.1938 13326
TIOOD UVa filter; screw-on type E85 ca.1938 13331
TIYOO Panchromatic green filter; screw-on type E85 ca.1938 13306
TLCOO F = 40 cm 1:5 Telyt II 1956-1966 -
TMEOO Replacemant hood for F = 40 cm 1:5 Telyt II 1954-1966 see also THMOO
TNGOO Replacemant hood for f = 20 cm 1:4 Telyt Forum discussion 1954-19?? see also THMOO
TOODY Thambar f= 9 cm 1:2.2 1935-1939 1937 catalog
TOOLP F = 20 cm 1:4.5 Telyt (also named OTPLO) 1935-1960 1937 catalog
TOOQE Small, table top tripod complete with FOOMI ball and socket 1952-19?? -
TOOSF Table-top tripod (per Accessory Guide page 84) ca.1936 -
TOOUG Small, table top tripod complete with FOOMI ball and socket; black crackle enamel; later gray enamel 1952-19?? 14100 JCB's a little...17
TOWIN Stereo tandem coupling (per Accessory Guide page 37) 1949-1950 NY item
TREPL Complete photomicrography outfit with microscope, mirror reflex housing and copy stand 1938-19?? -
TROOV Leather wrist strap with threaded connector 1938-19?? -
TRPOO Neck strap with patent hooks 1951-19?? -
TRPOO-M Neck strap with patent hooks for Leica-M 1956-19?? -
TSOOV Neck strap with split rings for atachment to camera side lugs; later version has non-slip shoulder pad 1960-19?? 14092
TUSOO Steel tape measure for ROOFU arm 1951-19?? -
TUVOO Chrome attachment for VIOOH viewfinder for 2.8 cm lenses ? -
TXBOO Extension tube for TEYLT's on M-cameras 19??-19?? 14024
TZFOO Extension tube for TEYLT's on screw cameras 19??-19?? -
TZOON Extension tube for TEYLT's on screw cameras, early version 19??-19?? 14023
