Elmar (I) f= 5 cm 1:3.5
- Leica Code /No. – ELMAR LLC - 113
- Production era - 1930-1950
- Variants - Nickel Serial Nos. - / Chrome Serial Nos. / European scale / International scale / 11 o'clock bell push
- Lens mount - Screw-thread
- Number of lenses /groups – 5/3
- Aperture range – f/3.5 > f/18 & f/16
- Focusing range – 1 m / 3.28 ft < ∞
- Smallest object field -
- Diaphragm setting /type -
- Angle of view (diagonal) - 45 degrees
- Filter type - A36
- Accessories – Hood: FISON
- Weight – 125 g / 4.4 oz
- Inscription - Leitz Elmar 1:3,5 F=50mm
- Designer - Max Berek
Serial numbers compiled from Puts Pocket PodNote: Some of the numbers between 1946 and 1950 should be assigned to Elmar (II) 5 cm 1:35
UNKNOWN | pre-156001 | Elmar 5 cm 1:3.5 | -1933 | UNKNOWN |
156501 | 157000 | Elmar 5 cm 1:3.5 | 1933 | 500 |
157001 | 160000 | Elmar 5 cm 1:3.5 | 1933 | 3000 |
163101 | 165000 | Elmar 5 cm 1:3.5 | 1933 | 1900 |
169001 | 171000 | Elmar 5 cm 1:3.5 | 1933 | 2000 |
172501 | 176000 | Elmar 5 cm 1:3.5 | 1933 | 3500 |
179001 | 182000 | Elmar 5 cm 1:35 | 1933 | 3000 |
183101 | 186000 | Elmar 5 cm 1:3.5 | 1933 | 2900 |
187001 | 190000 | Elmar 5 cm 1:3.5 | 1933 | 3000 |
200001 | 205000 | Elmar 5 cm 1:35 | 1934 | 5000 |
211101 | 214000 | Elmar 5 cm 1:3.5 | 1934 | 2900 |
222001 | 225000 | Elmar 5 cm 1:3.5 | 1934 | 3000 |
230301 | 235000 | Elmar 5 cm 1:35 | 1934 | 4700 |
242001 | 245000 | Elmar 5 cm 1:3.5 | 1935 | 3000 |
253001 | 256000 | Elmar 5 cm 1:3.5 | 1935 | 3000 |
261001 | 265000 | Elmar 5 cm 1:3.5 | 1935 | 4000 |
275001 | 280000 | Elmar 5 cm 1:3.5 | 1936 | 5000 |
290001 | 295000 | Elmar 5 cm 1:3.5 | 1936 | 5000 |
304001 | 310000 | Elmar 5 cm 1:35 | 1934 | 6000 |
311501 | 315000 | Elmar 5 cm 1:35 | 1934 | 3500 |
315101 | 320000 | Elmar 5 cm 1:35 | 1936 | 4900 |
322001 | 325000 | Elmar 5 cm 1:35 | 1936 | 3000 |
327001 | 332000 | Elmar 5 cm 1:35 | 1936 | 5000 |
338001 | 345000 | Elmar 5 cm 1:35 | 1936 | 7000 |
358001 | 365000 | Elmar 5 cm 1:35 | 1937 | 7000 |
390001 | 400000 | Elmar 5 cm 1:35 | 1937 | 10000 |
427001 | 437000 | Elmar 5 cm 1:35 | 1938 | 10000 |
460301 | 465000 | Elmar 5 cm 1:35 | 1938 | 4700 |
473001 | 480000 | Elmar 5 cm 1:35 | 1938 | 7000 |
498001 | 503000 | Elmar 5 cm 1:35 | 1939 | 5000 |
510001 | 515000 | Elmar 5 cm 1:35 | 1939 | 5000 |
533001 | 538000 | Elmar 5 cm 1:35 | 1939 | 5500 |
542001 | 550000 | Elmar 5 cm 1:35 | 1940 | 8000 |
567101 | 570000 | Elmar 5 cm 1:35 | 1941 | 2900 |
571301 | 573000 | Elmar 5 cm 1:35 | 1941 | 1700 |
573401 | 575000 | Elmar 5 cm 1:35 | 1941 | 1600 |
582301 | 583500 | Elmar 5 cm 1:35 | 1942 | 1200 |
583501 | 584500 | Elmar 5 cm 1:35 | 1942 | 1000 |
591001 | 592000 | Elmar 5 cm 1:35 | 1942 | 1000 |
593501 | 594500 | Elmar 5 cm 1:35 | 1943 | 1000 |
595000 | 596000 | Elmar 5 cm 1:35 | 1945 | 1001 |
597001 | 600000 | Elmar 5 cm 1:35 | 1945 | 3000 |
601001 | 603000 | Elmar 5 cm 1:35 | 1946 | 2000 |
609001 | 610000 | Elmar 5 cm 1:35 | 1946 | 1000 |
612001 | 615000 | Elmar 5 cm 1:35 | 1946 | 3000 |
630001 | 633000 | Elmar 5 cm 1:35 | 1946 | 3000 |
633101 | 635000 | Elmar 5 cm 1:35 | 1947 | 1900 |
638001 | 643000 | Elmar 5 cm 1:35 | 1947 | 5000 |
647001 | 652000 | Elmar 5 cm 1:35 | 1948 | 5000 |
670001 | 675000 | Elmar 5 cm 1:35 | 1948 | 5000 |
688001 | 693000 | Elmar 5 cm 1:35 | 1949 | 5000 |
707001 | 712000 | Elmar 5 cm 1:35 | 1949 | 5000 |
727001 | 732000 | Elmar 5 cm 1:35 | 1949 | 5000 |
741001 | 750000 | Elmar 5 cm 1:35 | 1949 | 9000 |
769001 | 775000 | Elmar 5 cm 1:35 | 1950 | 6000 |
790020 | 790036 | Elmar 5 cm 1:35 | 1950 | 17 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1930-1950 | 1 |
