Summicron (I) f= 9 cm 1:2
  • Leica Order No. - SOOZI, SEOOM 11123 11133 LLC - 174
  • Production era - 1957-1962, 490 screw lens, 4430 bayonet lens
  • Variants - All black, all chrome, and black and chrome versions; preset ring with f/16 or f/22 minimum aperture
  • Number of lenses /groups - 6 /5
  • F stop range - f/2 > f/22
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E48
  • Accessories - Hood: HMOOD
  • Materials -
  • Dimensions length x diameter - 110 x 66 mm / 4.33 x 2.60 in
  • Weight - 660 g /1.46 lb
  • Inscription - LEITZ CANADA 165XXXX SUMMICRON 1:2/90; Ernst Leitz Canada Ltd. Midland Summicron f = 9cm 1:2 Nr. 158xxxx
  • Designer - Walter Mandler
  • Forum discussion
Summicron (I) f= 9 cm 1:2 Serial Numbers
1119001 1119200 Summicron f= 9 cm 1:2 1953 200
1477001 1477100 Summicron f= 9 cm 1:2 1957 100
1580001 1581000 Summicron f= 9 cm 1:2 1958 1000
1651001 1652000 Summicron f= 9 cm 1:2 1959 1000
1652451 1653450 Summicron f= 9 cm 1:2 1959 1000
1680001 1682000 Summicron f= 9 cm 1:2 1959 2000
1740001 1743500 Summicron f= 9 cm 1:2 1960 3500
1743501 1746500 Summicron f= 9 cm 1:2 1960 3000
1817001 1819000 Summicron f= 9 cm 1:2 1960 2000
TOTAL ASSIGNED SERIAL NUMBERS 1953-1960 13,800
