28mm f/2.8 Elmarit-M IV
- Leica Order No. - 11 809 / LLC - 146
- Production era - 1992-2006 / Serial Nos. -
- Number of lenses/groups - 8/7
- Focusing range - 0.7 m / 2.3 ft < ∞
- Aperture - 2.8 > 22 - with clickstops (including half values), manual diaphragm
- Smallest object field/Largest reproduction ratio - 533 mm x 800 mm / 1:22.2
- Angle of view (diagonal, horizontal, vertical) - 75°, 65°, 46°
- Position of entrance pupil - 15.2 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-in filters size E46 / separate, clip-on type, lockable
- Accessories - Hood: 12547
- Materials - Black lacquered alloy
- Focal length - 28.2 mm / 1.1 in
- Length to bayonet flange - 41.4 mm / 1.6 in
- Largest diameter - 53 mm / 2.1 in
- Weight - approx. 260 g / 9.2 oz
- Inscription - LEICA ELMARIT-M 1:2.8/28 E46 (Serial No.)
- On the street - $US 1,095 in 2008
- Leica Order No. - 11 804 LLC - 145
- Production era - 1979-1993
- Variants -
- Number of lenses /groups - 8 /6
- F stop range - f/2.8 > f/22
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E49
- Accessories - Hood: 12536
- Materials - Black lacquered brass
- Weight - 250 g /8.82 oz
- Inscription - LEITZ LENS MADE IN CANADA ELMARIT 1:2.8/28 or LEITZ ELMARIT 1:2.8/28 3XXXXXX
- Designer - Walter Mandler
28mm f/2.8 Elmarit IV Serial Numbers
| 3585865 | 3586379 | 28mm f/2.8 Elmarit-M | 1992 | 515 |
| 3608370 | 3608929 | 28mm f/2.8 Elmarit-M | 1992 | 560 |
| 3617890 | 3617894 | 28mm f/2.8 Elmarit-M | 1993 | 5 |
| 3633901 | 3634900 | 28mm f/2.8 Elmarit-M | 1993 | 1000 |
| 3662831 | 3663830 | 28mm f/2.8 Elmarit-M | 1994 | 1000 |
| 3671031 | 3672030 | 28mm f/2.8 Elmarit-M | 1994 | 1000 |
| 3708803 | 3709802 | 28mm f/2.8 Elmarit-M | 1995 | 1000 |
| 3743089 | 3744088 | 28mm f/2.8 Elmarit-M | 1996 | 1000 |
| 3768220 | 3769219 | 28mm f/2.8 Elmarit-M | 1996 | 1000 |
| 3793010 | 3794009 | 28mm f/2.8 Elmarit-M | 1997 | 1000 |
| 3847500 | 3848499 | 28mm f/2.8 Elmarit-M | 1998 | 1000 |
| 3895051 | 3896050 | 28mm f/2.8 Elmarit-M | 2000 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1992-2000 | 1 |
