50mm f/1.4 Summilux-M II
- Leica Order No. - 11 113 black, 11 114 chrome LLC - 127
- Production era - 1966-1995 Serial Numbers: 1844001-
- Variants - Black and chrome versions
- F stop range - f/1.4-f/16
- Diaphragm setting /type -
- Filter type - E43
- Accessories - Hood: 12586
- Materials - Black anodized aluminum or chrome plated brass
- Dimensions (length x diameter) - 54.5 x 47.7 mm /
- Weight - 275 g aluminum, 380 g chrome
- Inscription - LEITZ WETZLAR SUMMILUX 1:1.4/50 E46 388XXXX
- Designer - Walter Mandler
- Leica Order No. - SOWGE 11014, SOOME 11114, 11621 LLC - 126
- Production era - 1959-1961; Serial Nos. 16416xx-1844000
- Variants - Black and silver versions
- F stop range - f/1.4 > f/16
- Smallest object field - 410 x 620 mm
- Filter type - E43
- Accessories - Hood: XOOIM 12521 used with OROBA or ORNIO cap (see Forum discussion [1] below}
- Materials - Lacquer on chrome plated brass
- Dimensions length x diameter - 52 x 53 mm / 2.05 x 2.09 in
- Weight - 320 g /11.29 oz screw; 360 g /12.70 oz bayonet
- Inscription - LEICA SUMMILUX 1:1.4/50 E46 388XXXX
- Designer - Erich Wagner
50mm f/1.4 Summilux-M II Serial Numbers
| 1897001 | 1899000 | Summilux f= 5 cm 1:1.4 | 1961 | 2000 |
| 1927001 | 1929000 | Summilux f= 5 cm 1:1.4 | 1962 | 2000 |
| 1945001 | 1947000 | Summilux f= 5 cm 1:1.4 | 1962 | 2000 |
| 1999999 | 2000001 | Summilux f= 5 cm 1:1.4 | 1963 | 3 |
| 2028001 | 2029000 | Summilux f= 5 cm 1:1.4 | 1964 | 1000 |
| 2039701 | 2040700 | Summilux f= 5 cm 1:1.4 | 1964 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1961-1964 | 1 |
