90mm f/2.8 Elmarit-R II
- Leica Order No. - 11 806 LLC - 173
- Production era - 1980-1998 < 16,615 lenses
- Variants -
- Number of lenses /groups - 4 / 4
- F stop range - f/2.8-f/22
- Closest focusing distance - 70 cm / 2.30 ft
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E55
- Accessories - ELPRO close focusing attachment type 3
- Materials -
- Weight - 450 g /0.99 lb
- Inscription - ELMARIT-R 1:2.8/90 LEITZ CANADA 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 500 in 2002
90mm f/2.8 Elmarit-R I Serial Numbers
| 2908101 | 2909100 | 90mm f/2.8 Elmarit-R | 1978 | 1000 |
| 2929901 | 2931000 | 90mm f/2.8 Elmarit-R | 1978 | 1100 |
| 2982101 | 2982600 | 90mm f/2.8 Elmarit-R | 1979 | 500 |
| 2988101 | 2989100 | 90mm f/2.8 Elmarit-R | 1979 | 1000 |
| 3088001 | 3089000 | 90mm f/2.8 Elmarit-R | 1981 | 1000 |
| 3250101 | 3251100 | 90mm f/2.8 Elmarit-R | 1983 | 1000 |
| 3260101 | 3261100 | 90mm f/2.8 Elmarit-R | 1983 | 1000 |
| 3300201 | 3301200 | 90mm f/2.8 Elmarit-R | 1984 | 1000 |
| 3323201 | 3324200 | 90mm f/2.8 Elmarit-R | 1984 | 1000 |
| 3344201 | 3346200 | 90mm f/2.8 Elmarit-R | 1984 | 2000 |
| 3376001 | 3377000 | 90mm f/2.8 Elmarit-R | 1985 | 1000 |
| 3384201 | 3386000 | 90mm f/2.8 Elmarit-R | 1986 | 1800 |
| 3408701 | 3408890 | 90mm f/2.8 Elmarit-R | 1986 | 190 |
| 3551468 | 3553467 | 90mm f/2.8 Elmarit-R | 1991 | 2000 |
| 3616580 | 3617079 | 90mm f/2.8 Elmarit-R | 1993 | 500 |
| 3637101 | 3637325 | 90mm f/2.8 Elmarit-R | 1993 | 225 |
| 3660531 | 3660830 | 90mm f/2.8 Elmarit-R | 1994 | 300 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1978-1994 | 16,615 |
