250mm f/4 Telyt-R II
Revision as of 14:46, 14 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 925 / LLC - 193
  • Production era - 1980-1994 < 3,663 lenses
  • Variants - 3-cam version
  • Number of lenses /groups - 7 / 6
  • F stop range - f/4 > f/22
  • Closest focusing distance - 1.7 m / 5.57 ft
  • Smallest object field - 124 x 168 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 10 degrees
  • Filter type - E67
  • Accessories -
  • Materials -
  • Dimensions length x diameter - 195 x 75 mm / 7.68 x 2.95 in
  • Weight - 1230 g /2.71 lb
  • Inscription - LEITZ CANADA TELYT-R 1:4/250 MM 3XXXXXX
  • Designer - Walter Mandler
  • On the street - €EU
  • Leica Order No. - 11 920 / LLC - 192
  • Production era - 1970-1979; Serial Nos. -3050600
  • Variants - 2 and 3-cam versions
  • Number of lenses /groups - 6 / 5
  • Closest focusing distance - 4.5 m / 14.76 ft
  • Angle of view diagonal - 7 degrees
  • Filter type - E55
  • Accessories -
  • Materials -
  • Dimensions (length x diameter) - 100 X 65.5 mm /3.94 x 2.58 in
  • Weight - 1380 g /3.04 lb
  • Inscription - LEITZ CANADA TELYT-R 1:4/250 MM 2XXXXXX
250mm f/4 Telyt-R I Serial Numbers
3050601 3051100 250mm f/4 Telyt-R 1980 500
3075801 3076300 250mm f/4 Telyt-R 1980 500
3108501 3109000 250mm f/4 Telyt-R 1981 500
3185701 3187700 250mm f/4 Telyt-R 1982 2000
3583669 3583830 250mm f/4 Telyt-R 1991 162
3617889 3617889 250mm f/4 Telyt-R 1993 1
TOTAL ASSIGNED SERIAL NUMBERS 1980-1993 3,663
