50mm f/1.4 Summilux R I
  • Leica Order No. - 11 675 - 11 176 - 11 875 - 11 777 LLC - 128
  • Production era - 1970-1998
  • Variants - 2-cam and 3-cam; black and olive green "Safari" versions
  • Number of lenses /groups - 7 / 6
  • F stop range - f/1.4-f/16
  • Closest focusing distance - 50 cm / 1.64 ft
  • Smallest object field - 180 x 270 mm
  • Diaphragm setting /type -
  • Filter type - E55
  • Accessories - Hood: 12508 until Serial No. 2806500 when built-in hood became standard
  • Materials -
  • Dimensions length x diameter - 50.6 x 68.5 / 1.99 x 2.7 in
  • Weight - 395 g / 13.9 oz
  • Inscription - SUMMILUX-R 1:1.4/50 LEITZ CANADA 2XXXXXX
  • On the street - €EU 360 IN 2008
50mm f/1.4 Summilux R I Serial Numbers
2411021 2411040 50mm f/1.4 Summilux R 1970 20
2470501 2472500 50mm f/1.4 Summilux R 1971 2000
2475001 2477000 50mm f/1.4 Summilux R 1971 2000
2492051 2494050 50mm f/1.4 Summilux R 1971 2000
2515501 2517550 50mm f/1.4 Summilux R 1972 2050
2805401 2807400 50mm f/1.4 Summilux R 1976 2000
2845051 2847050 50mm f/1.4 Summilux R 1977 2000
2899801 2902800 50mm f/1.4 Summilux R 1978 3000
2931101 2933100 50mm f/1.4 Summilux R 1978 2000
2952501 2954500 50mm f/1.4 Summilux R 1978 2000
2999999 3000001 50mm f/1.4 Summilux R 1979 3
3032801 3033900 50mm f/1.4 Summilux R 1980 1100
3076801 3077800 50mm f/1.4 Summilux R 1980 1000
3114701 3115700 50mm f/1.4 Summilux R 1981 1000
3169001 3171000 50mm f/1.4 Summilux R 1982 2000
3231301 3233300 50mm f/1.4 Summilux R 1982 2000
3290401 3292400 50mm f/1.4 Summilux R 1983 2000
3295201 3296200 50mm f/1.4 Summilux R 1984 1000
3386001 3388000 50mm f/1.4 Summilux R 1986 2000
3498201 3499999 50mm f/1.4 Summilux R 1989 1799
3500001 3500074 50mm f/1.4 Summilux R 1989 74
3500075 3500075 50mm f/1.4 Summilux R 1989 1
3500076 3500149 50mm f/1.4 Summilux R 1989 74
3500151 3500200 50mm f/1.4 Summilux R 1989 50
3609180 3609679 50mm f/1.4 Summilux R 1992 500
3633401 3633900 50mm f/1.4 Summilux R 1993 500
3676531 3677030 50mm f/1.4 Summilux R 1994 500
3702552 3702702 50mm f/1.4 Summilux R 1995 151
3729291 3729790 50mm f/1.4 Summilux R 1995 500
3794010 3794509 50mm f/1.4 Summilux R 1997 500
3797910 3798409 50mm f/1.4 Summilux R 1997 500
TOTAL ASSIGNED SERIAL NUMBERS 1970-1997 1
Lens superseded by 50mm f/1.4 Summilux-R II
