100mm f/4 Macro-Elmar-R
- Leica Order No. - 11 232 / LLC - 179
- Production era - 1978-1995
- Variants - With bellows and no cams
- Number of lenses /groups - 4 / 3
- F stop range - f/4 > f/22
- Closest focusing distance - 1.10 m / 3.60 ft
- Smallest object field - 38 x 57 mm
- Diaphragm setting /type -
- Angle of view diagonal - 25 degrees
- Filter type - E55
- Accessories -
- Materials -
- Dimensions length x diameter - 120 x 67.5 mm / 4.72 x 2.66 in
- Weight - 670 g /1.48 lb
- Inscription - MACRO-ELMAR-R 1:4/100 LEITZ CANADA 2XXXXXX
- Designer -
- On the street - €EU 336 in 2008
100mm f/4 Macro-Elmar-R Serial Numbers
Serial numbers compiled from Puts Pocket PodNote: Same list is used for Bellows and Helical versions
2290951 | 2291950 | 100mm f/4 Macro-Elmar-R | 1968 | 1000 |
2390201 | 2391200 | 100mm f/4 Macro-Elmar-R | 1970 | 1000 |
2416101 | 2417200 | 100mm f/4 Macro-Elmar-R | 1970 | 1100 |
2623101 | 2623600 | 100mm f/4 Macro-Elmar-R | 1973 | 500 |
2681201 | 2681700 | 100mm f/4 Macro-Elmar-R | 1974 | 500 |
2860601 | 2860800 | 100mm f/4 Macro-Elmar-R | 1977 | 200 |
2883701 | 2885700 | 100mm f/4 Macro-Elmar-R | 1978 | 2000 |
2926901 | 2928900 | 100mm f/4 Macro-Elmar-R | 1978 | 2000 |
2933351 | 2933500 | 100mm f/4 Macro-Elmar-R | 1978 | 150 |
2973251 | 2974250 | 100mm f/4 Macro-Elmar-R | 1979 | 1000 |
2982001 | 2982100 | 100mm f/4 Macro-Elmar-R | 1979 | 100 |
3031801 | 3032800 | 100mm f/4 Macro-Elmar-R | 1980 | 1000 |
3052601 | 3053600 | 100mm f/4 Macro-Elmar-R | 1980 | 1000 |
3084501 | 3084950 | 100mm f/4 Macro-Elmar-R | 1980 | 450 |
3349801 | 3350800 | 100mm f/4 Macro-Elmar-R | 1985 | 1000 |
3409891 | 3411890 | 100mm f/4 Macro-Elmar-R | 1986 | 2000 |
3596460 | 3596709 | 100mm f/4 Macro-Elmar-R | 1992 | 250 |
3655822 | 3655825 | 100mm f/4 Macro-Elmar-R | 1994 | 4 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1968-2005 | 1 |
