Elmar (I) f= 5 cm 1:3.5
- Leica Code /No. – ELMAR LLC - 113
- Production era - 1930-1950
- Variants - Nickel and Chrome Metric and foot versions 11 o'clock bell push
- Lens mount - Screw-thread
- Number of lenses /groups – 5 /3
- Aperture range – f/3.5-f/18 & f/16
- Focusing range – 1 m / 3.28 ft < ∞
- Smallest object field -
- Diaphragm setting /type -
- Angle of view (diagonal) - 45 degrees
- Filter type - A36
- Accessories – Hood: FISON
- Weight – 125 g / 4.4 oz
- Inscription - Leitz Elmar 1:3,5 F=50mm
- Designer - Max Berek
Serial numbers compiled from Puts Pocket PodNote: Some of the numbers between 1946 and 1950 should be assigned to Elmar (II) f= 5 cm 1:3.5
| -93750 - 99900- | pre-156001 | Elmar 5 cm 1:3.5 | -1933 | unknown |
| 156501 | 157000 | Elmar 5 cm 1:3.5 | 1933 | 500 |
| 157001 | 160000 | Elmar 5 cm 1:3.5 | 1933 | 3000 |
| 163101 | 165000 | Elmar 5 cm 1:3.5 | 1933 | 1900 |
| 169001 | 171000 | Elmar 5 cm 1:3.5 | 1933 | 2000 |
| 172501 | 176000 | Elmar 5 cm 1:3.5 | 1933 | 3500 |
| 179001 | 182000 | Elmar 5 cm 1:35 | 1933 | 3000 |
| 183101 | 186000 | Elmar 5 cm 1:3.5 | 1933 | 2900 |
| 187001 | 190000 | Elmar 5 cm 1:3.5 | 1933 | 3000 |
| 200001 | 205000 | Elmar 5 cm 1:35 | 1934 | 5000 |
| 211101 | 214000 | Elmar 5 cm 1:3.5 | 1934 | 2900 |
| 222001 | 225000 | Elmar 5 cm 1:3.5 | 1934 | 3000 |
| 230301 | 235000 | Elmar 5 cm 1:35 | 1934 | 4700 |
| 242001 | 245000 | Elmar 5 cm 1:3.5 | 1935 | 3000 |
| 253001 | 256000 | Elmar 5 cm 1:3.5 | 1935 | 3000 |
| 261001 | 265000 | Elmar 5 cm 1:3.5 | 1935 | 4000 |
| 275001 | 280000 | Elmar 5 cm 1:3.5 | 1936 | 5000 |
| 290001 | 295000 | Elmar 5 cm 1:3.5 | 1936 | 5000 |
| 304001 | 310000 | Elmar 5 cm 1:35 | 1934 | 6000 |
| 311501 | 315000 | Elmar 5 cm 1:35 | 1934 | 3500 |
| 315101 | 320000 | Elmar 5 cm 1:35 | 1936 | 4900 |
| 322001 | 325000 | Elmar 5 cm 1:35 | 1936 | 3000 |
| 327001 | 332000 | Elmar 5 cm 1:35 | 1936 | 5000 |
| 338001 | 345000 | Elmar 5 cm 1:35 | 1936 | 7000 |
| 358001 | 365000 | Elmar 5 cm 1:35 | 1937 | 7000 |
| 390001 | 400000 | Elmar 5 cm 1:35 | 1937 | 10000 |
| 427001 | 437000 | Elmar 5 cm 1:35 | 1938 | 10000 |
| 460301 | 465000 | Elmar 5 cm 1:35 | 1938 | 4700 |
| 473001 | 480000 | Elmar 5 cm 1:35 | 1938 | 7000 |
| 498001 | 503000 | Elmar 5 cm 1:35 | 1939 | 5000 |
| 510001 | 515000 | Elmar 5 cm 1:35 | 1939 | 5000 |
| 533001 | 538000 | Elmar 5 cm 1:35 | 1939 | 5500 |
| 542001 | 550000 | Elmar 5 cm 1:35 | 1940 | 8000 |
| 567101 | 570000 | Elmar 5 cm 1:35 | 1941 | 2900 |
| 571301 | 573000 | Elmar 5 cm 1:35 | 1941 | 1700 |
| 573401 | 575000 | Elmar 5 cm 1:35 | 1941 | 1600 |
| 582301 | 583500 | Elmar 5 cm 1:35 | 1942 | 1200 |
| 583501 | 584500 | Elmar 5 cm 1:35 | 1942 | 1000 |
| 591001 | 592000 | Elmar 5 cm 1:35 | 1942 | 1000 |
| 593501 | 594500 | Elmar 5 cm 1:35 | 1943 | 1000 |
| 595000 | 596000 | Elmar 5 cm 1:35 | 1945 | 1001 |
| 597001 | 600000 | Elmar 5 cm 1:35 | 1945 | 3000 |
| 601001 | 603000 | Elmar 5 cm 1:35 | 1946 | 2000 |
| 609001 | 610000 | Elmar 5 cm 1:35 | 1946 | 1000 |
| 612001 | 615000 | Elmar 5 cm 1:35 | 1946 | 3000 |
| 630001 | 633000 | Elmar 5 cm 1:35 | 1946 | 3000 |
| 633101 | 635000 | Elmar 5 cm 1:35 | 1947 | 1900 |
| 638001 | 643000 | Elmar 5 cm 1:35 | 1947 | 5000 |
| 647001 | 652000 | Elmar 5 cm 1:35 | 1948 | 5000 |
| 670001 | 675000 | Elmar 5 cm 1:35 | 1948 | 5000 |
| 688001 | 693000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 707001 | 712000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 727001 | 732000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 741001 | 750000 | Elmar 5 cm 1:35 | 1949 | 9000 |
| 769001 | 775000 | Elmar 5 cm 1:35 | 1950 | 6000 |
| 790020 | 790036 | Elmar 5 cm 1:35 | 1950 | 17 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1930-1950 | 1 |
