Summilux (I) f= 5 cm 1:1.4
  • Leica Order No. - SOWGE 11014, SOOME 11114, 11621 LLC - 126
  • Production era - 1959-1961 < 21,600 lenses (584 screw-mount lenses, per Schouten)
  • Variants - Black and clear anodized, knurled and cylindrical versions
  • F stop range - f/1.4-f/16
  • Smallest object field - 410 x 620 mm
  • Diaphragm setting /type -
  • Filter type - E43
  • Accessories - Hood: XOOIM 12521 used with OROBA or ORNIO cap (see Forum discussion [1] below}
  • Materials - Lacquer on chrome plated brass
  • Dimensions length x diameter - 52 x 53 mm / 2.05 x 2.09 in
  • Weight - 320 g /11.29 oz screw; 360 g /12.70 oz bayonet
  • Inscription - LEICA SUMMILUX 1:1.4/50 E46 388XXXX
  • Designer - Erich Wagner
  • Forum discussion
  • Reviews
Summilux (I) f= 5 cm 1:1.4 Serial Numbers
.* At least one in this batch is a Summaron 1:2.8/35mm per Westlicht
1640601 1642000 Summilux f= 5 cm 1:1.4 (screw-mount) 1958 1400
1644001 1645000 Summilux f= 5 cm 1:1.4 1958 1000
1660001 1662000 *Summilux f= 5 cm 1:1.4 1959 2000
1688001 1689500 Summilux f= 5 cm 1:1.4 1959 1500
1690801 1691700 Summilux f= 5 cm 1:1.4 1959 900
1701501 1704000 Summilux f= 5 cm 1:1.4 1959 2500
1730001 1731100 Summilux f= 5 cm 1:1.4 1960 1100
1757001 1760000 Summilux f= 5 cm 1:1.4 1960 3000
1765001 1766200 Summilux f= 5 cm 1:1.4 1960 1200
1777001 1780000 Summilux f= 5 cm 1:1.4 1960 3000
1788001 1790000 Summilux f= 5 cm 1:1.4 1960 2000
1844001 1846000 Summilux f= 5 cm 1:1.4 (screw-mount) 1961 2000
TOTAL ASSIGNED SERIAL NUMBERS 1958-1961 21,600
