Summaron f= 3.5 cm 1:2.8
Revision as of 19:06, 25 March 2010 by Admin (talk | contribs) (→Summaron f= 3.5 cm 1:2.8 Serial Numbers)
- Leica Order No. - SIMOO 11106P screw-lens; SIMOM 11306Y M2 lens; SIMWO 11106Q boxed M3 version with "specs" and caps LLC - 151
- Production era - 1958-1963 - 5,289 screw lenses; 1958-1974 - 30,400 bayonet lenses
- Serial nos. - 1148001-
- Variants - Screw, M2, and M3 with "specs" versions
- Lens mount - Leica Screw and M-bayonet
- Smallest object field -
- Diaphragm setting /type - 10 blade
- Angle of view diagonal - 64 degrees
- Filter type - E39
- Accessories - Hood: IROOA 12571, 12585, 12526, 12538
- Dimensions (length x diameter) - 29 x 51 mm / 1.14 x 2.01 in
- Weight - 210 g /7.41 oz
- Inscription - SUMMARON 1:2.8/3.5 LEITZ WETZLAR 1XXXXXX
Serial numbers compiled from Puts Pocket Pod.*Lens nos. 1678272 & 1679028 in this batch are 3.5 cm not 5.6 cm as listed
1615001 | 1616000 | Summaron 3.5 cm 1:2.8 | 1958 | 1000 |
1627001 | 1630000 | Summaron 3.5 cm 1:2.8 | 1958 | 3000 |
1662001 | 1668000 | Summaron 3.5 cm 1:2.8 (screw-mount) | 1959 | 6000 |
1677001 | 1680000 | Summaron *5.6 cm 1:2.8 (screw-mount) | 1959 | [3000] |
1694001 | 1697000 | Summaron 3.5 cm 1:2.8 (screw-mount) | 1959 | 3000 |
1731101 | 1733000 | Summaron 3.5 cm 1:2.8 | 1960 | 1900 |
1754001 | 1756000 | Summaron 3.5 cm 1:2.8 | 1960 | 2000 |
1782001 | 1784000 | Summaron 3.5 cm 1:2.8 | 1960 | 2000 |
1808001 | 1809000 | Summaron 3.5 cm 1:2.8 | 1960 | 1000 |
1810001 | 1811000 | Summaron 3.5 cm 1:2.8 | 1960 | 1000 |
1814001 | 1816000 | Summaron 3.5 cm 1:2.8 | 1960 | 2000 |
1903001 | 1906000 | Summaron 3.5 cm 1:2.8 (screw-mount) | 1961 | 3000 |
1921001 | 1924000 | Summaron 3.5 cm 1:2.8 | 1962 | 3000 |
1930201 | 1932700 | Summaron 3.5 cm 1:2.8 | 1962 | 2500 |
1947001 | 1950000 | Summaron 3.5 cm 1:2.8 | 1962 | 3000 |
2006001 | 2007500 | Summaron 3.5 cm 1:2.8 | 1963 | 1500 |
2049501 | 2051000 | Summaron 3.5 cm 1:2.8 | 1964 | 1500 |
2080501 | 2082500 | Summaron 3.5 cm 1:2.8 | 1965 | 2000 |
2100901 | 2102900 | Summaron 3.5 cm 1:2.8 | 1965 | 2000 |
2152551 | 2154550 | Summaron 3.5 cm 1:2.8 | 1965 | 2000 |
2217201 | 2219200 | Summaron 3.5 cm 1:2.8 | 1967 | 2000 |
2240001 | 2241000 | Summaron 3.5 cm 1:2.8 | 1967 | 1000 |
2309751 | 2312750 | Summaron 3.5 cm 1:2.8 | 1968 | 3000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1958-1968 | 49,400 |
