Elmar 1:4 / 135mm
- Leica Order No. - 11750, 11850 LLC - 183
- Production era - 1960-1965, 3282 screw and 20,396 bayonet < 25,900 lenses
- Variants -
- F stop range - f/4-f/22
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E39
- Accessories - Hood: IUFOO 12575; for use with Visoflex see forum discussion [1] below
- Materials -
- Weight - 440 g /0.97 lb
- Inscription - ELMAR 1:4/135 LEITZ WETZLAR 1XXXXXX
- Designer - Walter Mandler
Elmar 1:4 / 135mm Serial Numbers
| 1733001 | 1734000 | Elmar 1:4 / 135mm (screw-mount) | 1960 | 1000 |
| 1768001 | 1771000 | Elmar 1:4 / 135mm | 1960 | 3000 |
| 1774001 | 1777000 | Elmar 1:4 / 135mm | 1960 | 3000 |
| 1801001 | 1804000 | Elmar 1:4 / 135mm | 1960 | 3000 |
| 1824001 | 1827000 | Elmar 1:4 / 135mm (screw-mount) | 1960 | 1000 |
| 1880001 | 1883000 | Elmar 1:4 / 135mm | 1961 | 3000 |
| 1884001 | 1884100 | Elmar 1:4 / 135mm | 1961 | 100 |
| 1890001 | 1894800 | Elmar 1:4 / 135mm | 1961 | 4800 |
| 1901001 | 1903000 | Elmar 1:4 / 135mm | 1961 | 2000 |
| 1906001 | 1909000 | Elmar 1:4 / 135mm (screw-mount) | 1961 | 3000 |
| 1964001 | 1965000 | Elmar 1:4 / 135mm | 1962 | 1000 |
| 2007501 | 2008500 | Elmar 1:4 / 135mm | 1963 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1960-1963 | 25,900 |
