90mm f/2 Summicron-M III
- Leica Order No. - 11 136 - 11 137 LLC -
- Production era - 1982-1998 < 30,151 lenses
- Variants - Black and silver versions; 1st version with telescoping shade that covers f-stop ring when not deployed
- Number of lenses /groups - 5 /4
- F stop range - f/2.8-f/22
- Diaphragm setting /type -
- Filter type - E55
- Accessories -
- Materials - Black anodized aluminum or silver lacquered brass
- Dimensions length x diameter - 77 x 63.5 mm / 3.03 x 2.50 in
- Weight - 475 g /1.05 lb in black; 690 g / 1.52 lb in silver
- Inscription - LEITZ SUMMICRON-M 1:2/90 3XXXXXX
- Designer - Walter Mandler
- On the street - €EU 456 in 2008
90mm f/2 Summicron-M III Serial Numbers
Serial numbers compiled from Puts Pocket Pod.* Lens nos. 2814052 & 2814349 are 90mm not 35mm as listed
| 2813401 | *2814900 | Summicron-M f= *3.5 cm 1:2 (black.1) | 1977 | [1500] |
| 2947201 | 2950200 | Summicron-M f= 9 cm 1:2 | 1978 | 3000 |
| 3163001 | 3164000 | Summicron-M f= 9 cm 1:2 (black) | 1982 | 1000 |
| 3177201 | 3178200 | Summicron-M f= 9 cm 1:2 | 1982 | 1000 |
| 3209801 | 3211800 | Summicron-M f= 9 cm 1:2 | 1982 | 2000 |
| 3222301 | 3223300 | Summicron-M f= 9 cm 1:2 | 1982 | 1000 |
| 3263401 | 3265400 | Summicron-M f= 9 cm 1:2 | 1983 | 2000 |
| 3298201 | 3299200 | Summicron-M f= 9 cm 1:2 | 1984 | 1000 |
| 3365801 | 3366800 | Summicron-M f= 9 cm 1:2 | 1985 | 1000 |
| 3391001 | 3391800 | Summicron-M f= 9 cm 1:2 | 1986 | 800 |
| 3436501 | 3437500 | Summicron-M f= 9 cm 1:2 | 1987 | 1000 |
| 3455071 | 3455870 | Summicron-M f= 9 cm 1:2 | 1987 | 800 |
| 3458371 | 3459070 | Summicron-M f= 9 cm 1:2 | 1988 | 700 |
| 3473901 | 3474700 | Summicron-M f= 9 cm 1:2 | 1988 | 800 |
| 3482901 | 3483500 | Summicron-M f= 9 cm 1:2 | 1989 | 600 |
| 3523296 | 3523795 | Summicron-M f= 9 cm 1:2 | 1990 | 500 |
| 3532468 | 3533467 | Summicron-M f= 9 cm 1:2 | 1990 | 1000 |
| 3574634 | 3575633 | Summicron-M f= 9 cm 1:2 | 1991 | 1000 |
| 3594960 | 3595959 | Summicron-M f= 9 cm 1:2 | 1992 | 1000 |
| 3608120 | 3608369 | Summicron-M f= 9 cm 1:2 | 1992 | 250 |
| 3615580 | 3616579 | Summicron-M f= 9 cm 1:2 | 1993 | 1000 |
| 3617902 | 3617902 | Summicron-M f= 9 cm 1:2 | 1993 | 1 |
| 3642376 | 3643275 | Summicron-M f= 9 cm 1:2 | 1993 | 900 |
| 3643276 | 3644475 | Summicron-M f= 9 cm 1:2 | 1993 | 1200 |
| 3665831 | 3666030 | Summicron-M f= 9 cm 1:2 | 1994 | 200 |
| 3687031 | 3688230 | Summicron-M f= 9 cm 1:2 | 1995 | 1200 |
| 3688231 | 3689030 | Summicron-M f= 9 cm 1:2 | 1995 | 800 |
| 3702703 | 3703802 | Summicron-M f= 9 cm 1:2 | 1995 | 1100 |
| 3703803 | 3704802 | Summicron-M f= 9 cm 1:2 | 1995 | 1000 |
| 3720503 | 3721802 | Summicron-M f= 9 cm 1:2 | 1995 | 1300 |
| 3721803 | 3722802 | Summicron-M f= 9 cm 1:2 | 1995 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1977-1995 | 30,151 |
