21mm f/4 Super-Angulon-R
Revision as of 17:40, 28 March 2010 by Admin (talk | contribs) (→21mm f/4 Super-Angulon-R Serial Numbers)
- Leica Order No. - 11 813 LLC - 139
- Production era - 1978-1994 < 6,850 lenses
- Manufacturer - Schneider-Kreuznach
- Variants - 2-cam and 3-cam versions
- Number of lenses /groups - 10 /8
- F stop range - f/4-f/22
- Closest focusing distance - 20 cm / 7.87 in
- Smallest object field - 221 x 148 mm
- Diaphragm setting /type - Automatic, pre-set
- Angle of view diagonal - 92 degrees
- Filter type - Series 8.5
- Accessories - Hood: 12506
- Materials -
- Dimensions length x diameter - 43.5 x 78 mm / 1.71 x 3.07 in
- Weight - 420 g /0.93 lb
- Inscription - SUPER-ANGULON-R 1:4/21 LEITZ WETZLAR 2XXXXXX
- Designer - Walter Woeltche 22 Oct 1996
Serial numbers compiled from Puts Pocket Pod.*Note: -R missing in list - Lens 2613184 is -R
2613101 | 2615100 | 21mm f/4 Super-Angulon* | 1973 | 2000 |
2917001 | 2917150 | 21mm f/4 Super-Angulon-R | 1978 | 150 |
2918401 | 2918900 | 21mm f/4 Super-Angulon-R | 1978 | 500 |
2982601 | 2983100 | 21mm f/4 Super-Angulon* | 1979 | 500 |
3084001 | 3084500 | 21mm f/4 Super-Angulon-R | 1980 | 500 |
3120001 | 3120500 | 21mm f/4 Super-Angulon-R | 1981 | 500 |
3140301 | 3141000 | 21mm f/4 Super-Angulon-R | 1981 | 700 |
3158501 | 3160500 | 21mm f/4 Super-Angulon-R | 1981 | 2000 |
3288401 | 3290400 | 21mm f/4 Super-Angulon-R | 1983 | 2000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1973-1983 | 8,850 |
