50mm f/1 Noctilux-M
- Leica Order No. - 11 821 - 11 822 - 11 603 / LLC - 131
- Production era - 1976-2008 / Serial Nos. -2919656 1st version; -3220708 2nd version; < 17,295 lenses Puts lists 4 versions per hood size including the last version with built-in hood 1994-2008.
- Variants - 1st version has E58 filter size; 2 E60 versions come without hood; last E60 version has built-in hood
- Number of lenses/groups - 7 /6
- Aperture range - f/1-f/16
- Focusing range - 1 m / 3.28 ft < ∞
- Smallest object field - 410 mm x 615 mm
- Maximum magnification - 1:17
- Diaphragm setting / type - With click-stops, half values available, manual diaphragm
- Angle of view diagonal, horizontal, vertical - 47°, 40°, 27°
- Position of entrance pupil - 42.9 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - internal thread for screw-in type filters E 60 / built-in, telescopic (1st version had E 58 filter size)
- Accessories - Leica M Viewfinder Magnifiers 1.25x & 1.4x; Hood: 12519, 12539, 12544
- Focal length - 52.4 mm / 2.06 in
- Length to bayonet flange - 62 mm - 2.4 in
- Largest diameter - approx. 69 mm / 2.7 in
- Weight - 580 g (1st version), 630 g / 20.5, 24.7 oz
- Inscription - NOCTILUX 1:1/50 LEITZ CANADA 2XXXXXX or LEICA NOCTILUX-M 1:1/50 E 60 2XXXXXX
- Designer - Walter Mandler and Gerhardt Bechmann Aug 1970
- On the street - $US 6,495 (Uncoded version) 14,695.00 (Last 100 - Boxed Edition) in 2008
50mm f/1 Noctilux Serial Numbers
| 2749631 | 2750630 | 50mm f/1 Noctilux | 1975 | 1000 |
| 2853851 | 2854850 | 50mm f/1 Noctilux | 1977 | 1000 |
| 2913801 | 2914800 | 50mm f/1 Noctilux | 1978 | 1000 |
| 2918901 | 2919900 | 50mm f/1 Noctilux | 1978 | 1000 |
| 3114001 | 3114700 | 50mm f/1 Noctilux | 1981 | 700 |
| 3153501 | 3154500 | 50mm f/1 Noctilux | 1981 | 1000 |
| 3220001 | 3221000 | 50mm f/1 Noctilux | 1982 | 1000 |
| 3406201 | 3406700 | 50mm f/1 Noctilux-M (3rd) | 1986 | 500 |
| 3434501 | 3435000 | 50mm f/1 Noctilux | 1986 | 500 |
| 3442401 | 3442900 | 50mm f/1 Noctilux | 1987 | 500 |
| 3478151 | 3478650 | 50mm f/1 Noctilux-M | 1988 | 500 |
| 3497901 | 3498200 | 50mm f/1 Noctilux | 1989 | 300 |
| 3510296 | 3510795 | 50mm f/1 Noctilux-M | 1990 | 500 |
| 3533468 | 3533967 | 50mm f/1 Noctilux-M | 1990 | 500 |
| 3569473 | 3569972 | 50mm f/1 Noctilux-M | 1991 | 500 |
| 3603070 | 3603669 | 50mm f/1 Noctilux-M | 1992 | 600 |
| 3617898 | 3617899 | 50mm f/1 Noctilux-M | 1993 | 2 |
| 3637776 | 3637925 | 50mm f/1 Noctilux-M | 1993 | 150 |
| 3680931 | 3681530 | 50mm f/1 Noctilux-M | 1995 | 600 |
| 3737701 | 3738700 | 50mm f/1 Noctilux-M | 1996 | 1000 |
| 3813125 | 3815124 | 50mm f/1 Noctilux-M | 1997 | 2000 |
| 3913143 | 3913222 | 50mm f/1 Noctilux-M | 2001 | 80 |
| 3928201 | 3928463 | 50mm f/1 Noctilux-M | 2001 | 263 |
| 3940114 | 3940613 | 50mm f/1 Noctilux-M | 2002 | 500 |
| 3956561 | 3957060 | 50mm f/1 Noctilux-M | 2002 | 500 |
| 3978039 | 3978538 | 50mm f/1 Noctilux-M | 2004 | 500 |
| 3984534 | 3985033 | 50mm f/1 Noctilux-M | 2004 | 500 |
| unknown | -3985699- | 50mm f/1 Noctilux-M | 2006-2008 | 100 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1975-2005 | 17,295 |
Lens superseded by 50mm f/0.95 ASPH Noctilux-M
