135mm f/2.8 Elmarit-M II
Revision as of 20:30, 31 March 2010 by Admin (talk | contribs) (→135mm f/2.8 Elmarit-M II Serial Numbers)
- Leica Order No. - 11 829 LLC - 184
- Production era - 1964-1973 < 10,301 lenses
- Variants -
- Number of lenses /groups - 5 /3
- F stop range - f/2.8-f/32
- Closest focusing distance - 1.5 m /4.92 ft
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E55
- Accessories - Filter-ring: 14161
- Weight - 730 g /1.61 lb
- Inscription - ELMARIT-M 1:2.8/135 LEITZ CANADA 1XXXXXX
- Designer - Walter Mandler
Serial numbers compiled from Puts Pocket Pod.* Lens 2064302 is Elmarit-M 11829 2.8/135mm
.** Lens 2728702 is Tele-Elmarit-M 2.8/90
2063501 | *2065500 | *35mm f/2.8 Elmarit-R* | 1964 | [2000] |
2151551 | 2152550 | 135mm f/2.8 Elmarit | 1965 | 1000 |
2223201 | 2224000 | 135mm f/2.8 Elmarit | 1967 | 800 |
2258901 | 2259900 | 135mm f/2.8 Elmarit | 1968 | 1000 |
2288951 | 2289950 | 135mm f/2.8 Elmarit | 1968 | 1000 |
2324301 | 2326300 | 135mm f/2.8 Elmarit | 1969 | 2000 |
2424201 | 2425700 | 135mm f/2.8 Elmarit | 1970 | 1500 |
2466501 | 2468500 | 135mm f/2.8 Elmarit | 1970 | 2000 |
2655901 | 2656900 | 135mm f/2.8 Elmarit-M | 1973 | 1000 |
2681801 | 2682800 | 135mm f/2.8 Elmarit-M | 1974 | 1000 |
2726921 | **2728920 | **135mm f/2.8 Tele-Elmarit | 1974 | 1000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1964-1976 | 10,301 |
Lens superseded by 135mm f/2.8 Elmarit-M III
