Summicron (I) f= 9 cm 1:2
Revision as of 18:44, 2 April 2010 by Admin (talk | contribs) (→Summicron (I) f= 9 cm 1:2 Serial Numbers)
- Leica Order No. - SOOZI, SEOOM 11123 11133 LLC - 174
- Production era - 1957-1962, 490 screw lens, 4430 bayonet lens < 10,300 lenses
- Variants - All black, all chrome, and black and chrome versions; preset ring with f/16 or f/22 minimum aperture
- F stop range - f/2-f/22 or f/2-f/16
- Diaphragm setting /type -
- Filter type - E48
- Accessories - Hood: HMOOD
- Materials -
- Dimensions length x diameter - 110 x 66 mm / 4.33 x 2.60 in
- Weight - 660 g /1.46 lb
- Inscription - LEITZ CANADA 165XXXX SUMMICRON 1:2/90
Ernst Leitz Canada Ltd. Midland Summicron f = 9cm 1:2 Nr. 158xxxx - Designer - Walter Mandler
Serial numbers compiled from Puts Pocket Pod.* Lens 1615415 is Summicron 2 / 90 (ELC.S-chrom)
1119001 | 1119200 | Summicron f= 9 cm 1:2 (ELW.S-black) | 1953 | 200 |
1477001 | 1477100 | Summicron f= 9 cm 1:2 (ELC.S-black+chrom) | 1957 | 100 |
1580001 | 1581000 | Summicron f= 9 cm 1:2 (ELC.S-black+ELC.M-chrom) | 1958 | 1000 |
1615001* | 1616000 | *Summaron f= 3.5 cm 1:2.8 | 1958 | [1000] |
1651001 | 1652000 | Summicron f= 9 cm 1:2 | 1959 | 1000 |
1652451 | 1653450 | Summicron f= 9 cm 1:2 (S-chrom) | 1959 | 1000 |
1680001 | 1682000 | Summicron f= 9 cm 1:2 (ELC.M-chrom) | 1959 | 2000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1953-1960 | 2,300 |
Lens superseded by Summicron (II) f= 9 cm 1:2
