180mm f/3.4 APO-Telyt-R
Revision as of 14:20, 3 April 2010 by Admin (talk | contribs) (→180mm f/3.4 APO-Telyt-R Serial Numbers)
- Leica Order No. - 11 240 < 2947024 > 11 242 /LLC - 188
- Production era - 1975-1998 < 17,051 lenses
- Variants - 3-cam and R-cam only versions
- Number of lenses /groups - 7 / 4
- F stop range - f/3.4-f/22
- Closest focusing distance - 2.5 m / 8.2 ft
- Smallest object field - 276 x 414 mm
- Diaphragm setting /type -
- Angle of view diagonal - 14 degrees
- Filter type - E60
- Accessories -
- Materials -
- Dimensions length x diameter - 135 x 68 mm / 5.31 x 2.68 in
- Weight - 750 g /1.65 lb
- Inscription - LEITZ CANADA APO-TELYT-R 1:3.4/180 XXXXXXX
- Designer - Walter Mandler
- On the street - €EU 528 in 2007
2748631 | 2749630 | 180mm f/3.4 APO-Telyt-R | 1975 | 1000 |
2776451 | 2777450 | 180mm f/3.4 APO-Telyt-R (3-cam) | 1976 | 1000 |
2814901 | 2815900 | 180mm f/3.4 APO-Telyt-R | 1977 | 1000 |
2856851 | 2857350 | 180mm f/3.4 APO-Telyt-R | 1977 | 500 |
2866801 | 2867800 | 180mm f/3.4 APO-Telyt-R | 1977 | 1000 |
2914801 | 2915800 | 180mm f/3.4 APO-Telyt-R | 1978 | 1000 |
2945701 | 2947200 | 180mm f/3.4 APO-Telyt-R (3-cam) | 1978 | 1500 |
2987101 | 2988100 | 180mm f/3.4 APO-Telyt-R | 1979 | 1000 |
2992701 | 2993700 | 180mm f/3.4 APO-Telyt-R | 1979 | 1000 |
3044101 | 3045100 | 180mm f/3.4 APO-Telyt-R | 1980 | 1000 |
3070801 | 3071800 | 180mm f/3.4 APO-Telyt-R | 1980 | 1000 |
3072801 | 3073800 | 180mm f/3.4 APO-Telyt-R | 1980 | 1000 |
3127001 | 3128000 | 180mm f/3.4 APO-Telyt-R (11 242) | 1981 | 1000 |
3156501* | 3158500 | *Summilux f= 5 cm 1:1.4 | 1981 | 2000 |
3164001 | 3165000 | 180mm f/3.4 APO-Telyt-R | 1982 | 1000 |
3478901 | 3479100 | 180mm f/3.4 APO-Telyt-R | 1988 | 200 |
3486401 | 3486700 | 180mm f/3.4 APO-Telyt-R | 1989 | 300 |
3523796 | 3524295 | 180mm f/3.4 APO-Telyt-R | 1990 | 500 |
3563873 | 3564372 | 180mm f/3.4 APO-Telyt-R | 1991 | 500 |
3598820 | 3599219 | 180mm f/3.4 APO-Telyt-R | 1992 | 400 |
3610680 | 3610979 | 180mm f/3.4 APO-Telyt-R | 1993 | 300 |
3617886 | 3617886 | 180mm f/3.4 APO-Telyt-R | 1993 | 1 |
3637626 | 3637775 | 180mm f/3.4 APO-Telyt-R | 1993 | 150 |
3680031 | 3680430 | 180mm f/3.4 APO-Telyt-R | 1995 | 400 |
3712003 | 3712302 | 180mm f/3.4 APO-Telyt-R | 1995 | 300 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1975-1995 | 17,051 |
