Summicron (II) f= 9 cm 1:2
  • Leica Order No. - SEOOF 11123, SEOOM 11133 LLC - 175
  • Production era - 1959-1979 < 43,530 lenses
  • Variants - Black and chrome, f/16, f/22, scalloped focusing knurl (SFK), and preset diaphragm in short mount (PDS) for use with Visoflex
  • Number of lenses /groups -
  • F stop range - f/2-f/16 or f/22
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E49
  • Accessories - Built-in hood - Viewfinder:
  • Materials - Clear and black anodized aluminum
  • Dimensions length - 64.5 mm / 2.55 in
  • Weight - 685 g /1.51 lb
  • Inscriptions - Ernst Leitz Canada Summicron f-9cm 1:2 Nr.158xxxx
    LEITZ CANADA 168XXXX SUMMICRON 1:2 / 90
  • Designer - Walter Mandler
  • Forum discussion
Summicron (II) f= 9 cm 1:2 Serial Numbers
.*Lens nos. 1745260 & 1745738 are 2/35 Summicron
^ Visoflex 9 cm 1:2 Summicron are in this batch
" Lens 2544666 in R-batch has M-bayonet
1651001 1652000 Summicron f= 9 cm 1:2 (SFK.S-chrom+M-black) 1959 1000
1652451 1653450 Summicron f= 9 cm 1:2 (SFK.S-chrom) 1959 1000
1680001 1682000 Summicron f= 9 cm 1:2 (SFK.M+S-chrom) 1959 2000
1740001 ^1743500 Summicron f= 9 cm 1:2 (SFK.S-chrom+M-black+M-chrom) 1960 3500^
1743501 *1746500 Summicron f= *9 cm 1:2 1960 3000*
1817001 1819000 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1960 2000
1580001 1581000 Summicron f= 9 cm 1:2 1958 1000
1651001 1652000 Summicron f= 9 cm 1:2 1959 1000
1652451 1653450 Summicron f= 9 cm 1:2 1959 1000
1680001 1682000 Summicron f= 9 cm 1:2 1959 2000
1740001* 1743500 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1960 3500
1743501* 1746500 Summicron f= 9 cm 1:2 1960 3000
1817001 1819000 Summicron f= 9 cm 1:2 1960 2000
1983001 1983900 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1963 900
2025001 2026000 Summicron f= 9 cm 1:2 1964 1000
2068501 2069500 Summicron f= 9 cm 1:2 1964 1000
2150551 2151550 Summicron f= 9 cm 1:2 (SFK.PDS-black) 1965 1000
2203101 2204100 Summicron f= 9 cm 1:2 1966 1000
2246051 2247150 Summicron f= 9 cm 1:2 (SFK.M-black) 1967 1100
2332801 2333800 Summicron f= 9 cm 1:2 1969 1000
2370801 2371800 Summicron f= 9 cm 1:2 1969 1000
2413101 2413600 Summicron f= 9 cm 1:2 (M-black) 1970 500
2499651 2500650 Summicron f= 9 cm 1:2 1971 1000
2544501" 2545700 Summicron-R" f= 9 cm 1:2 (black) 1972 [1200]
2623601 2624600 Summicron-M f= 9 cm 1:2 1973 1000
2659451 2660450 Summicron-M f= 9 cm 1:2 1973 1000
2731921 2731921 Summicron f= 9 cm 1:2 1974 1
2731922 2731950 Summicron f= 9 cm 1:2 1975 29
2751051 2752050 Summicron f= 9 cm 1:2 1975 1000
2770201 2771200 Summicron-M f= 9 cm 1:2 1976 1000
2791651 2792650 Summicron-M f= 9 cm 1:2 (M-black) 1976 1000
TOTAL ASSIGNED SERIAL NUMBERS 1958-1976 43,530
Lens superseded by 90mm f/2 Summicron-M III
