Super-Angulon f= 2.1 cm 1:4
Revision as of 21:35, 2 April 2010 by Admin (talk | contribs) (→Super-Angulon f= 2.1 cm 1:4 Serial Numbers)
- Leica Order No. - SUOON, SUMOM, 11 102 LLC - 138
- Production era - 1958-1981, 1462 screw and 5292* M-bayonet < 27,000 lenses (*low number, perhaps ca.20,000 based on assigned s/n list below - or more of the 1:4 lenses should be listed as the 1:3.4 lens or as R lens - see s/n notes)
- Manufacturer - Schneider-Kreuznach
- Variants -
- Lens mount - Leica Screw-thread and unique M-bayonet addaptor removable for screw-mount use
- Number of lenses /groups - 9 /4
- F stop range - f/4-f/22
- Closest focusing distance - 40 cm /1.31 ft
- Smallest object field -
- Diaphragm setting /type -
- Angle of view diagonal - 92 degrees
- Filter type - E42
- Accessories - Viewfinder: SBKOO; Hood: IWKOO 12502
- Weight - 250 g /8.82 oz
- Inscription - SUPER-ANGULON 1:4/21 LEITZ WETZLAR 1XXXXXX
- Designer - Guenther Klemt - Schneider Kreuznack
Serial numbers compiled from Puts Pocket Pod.* Note: JCB has 1967101 as the first batch f= 2.1 cm 1:3.4 lens - see Forum discussion [1] above - Puts has this batch with the 1:4 lens
.** Westlicht has at least one in this batch as R lens
^ Schouten has lens 2027728 & 2035381 as 1:3.4 not 1:4
1583001 | 1583100 | Super-Angulon f= 2.1 cm 1:4 | 1958 | 100 |
1604001 | 1605000 | Super-Angulon f= 2.1 cm 1:4 (S-mount) | 1958 | 1000 |
1645301 | 1647000 | Super-Angulon f= 2.1 cm 1:4 (M-mount) | 1959 | 1700 |
1672501 | 1673500 | Super-Angulon f= 2.1 cm 1:4 (S-mount) | 1959 | 1000 |
1674501 | 1675500 | Super-Angulon f= 2.1 cm (S-mount)1:4 | 1959 | 1000 |
1676001 | 1677000 | Super-Angulon f= 2.1 cm 1:4 (M-mount) | 1959 | 1000 |
1714501 | 1717000 | Super-Angulon f= 2.1 cm 1:4 (M-mount) | 1959 | 2500 |
1967101* | 1968100 | Super-Angulon f= 2.1 cm 1:4* | 1962 | 1000 |
2027501^ | 2028000 | Super-Angulon f= 2.1 cm 1:4^ (S-mount) | 1964 | 500 |
2035001^ | 2036000 | Super-Angulon f= 2.1 cm 1:4^ (S-mount) | 1964 | 1000 |
2054001 | 2056000 | Super-Angulon f= 2.1 cm 1:4 | 1964 | 2000 |
2057501 | 2059500 | Super-Angulon f= 2.1 cm 1:4 | 1964 | 2000 |
2283351 | 2283950 | Super-Angulon f= 2.1 cm 1:4 | 1968 | 600 |
2318401 | 2319000 | Super-Angulon f= 2.1 cm 1:4 | 1969 | 600 |
2353301 | 2354300 | Super-Angulon f= 2.1 cm 1:4 | 1969 | 1000 |
2396401 | 2398400 | Super-Angulon f= 2.1 cm 1:4 | 1970 | 2000 |
2448001 | 2450000 | Super-Angulon f= 2.1 cm 1:4 | 1970 | 2000 |
2485201 | 2487200 | Super-Angulon f= 2.1 cm 1:4 | 1971 | 2000 |
2613101 | 2615100 | Super-Angulon f= 2.1 cm 1:4 | 1973 | 2000 |
2820351 | 2821350 | Super-Angulon f= 2.1 cm 1:4 | 1977 | 1000 |
2982601 | 2983100 | Super-Angulon f= 2.1 cm 1:4 | 1979 | 500** |
3105001 | 3105500 | Super-Angulon f= 2.1 cm 1:4 | 1981 | 500 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1958-1981 | 27,000 |
