24mm f/2.8 Elmarit-R
Revision as of 21:43, 6 April 2010 by Admin (talk | contribs) (→24mm f/2.8 Elmarit-R Serial Numbers)
- Leica Order No. - 11 221 without ROM, 11 257 ROM possible cam-3 only, 11 331 with ROM
- Production era - 1974-2006 < 20,200 lenses
- Manufacturer - Minolta
- Variants - 1974-1990 without ROM, 1990-1996 ROM possible, 1996-2006 with ROM
- Number of lenses /groups - 9 / 7
- F stop range - f/2.8-f/22
- Closest focusing distance - 30 cm / 11.81 in
- Smallest object field - 374 x 250 mm
- Diaphragm setting /type - automatic, pre-set
- Angle of view diagonal - 84 degrees
- Filter type - Series 8
- Accessories - Hood: 12506, 12523
- Materials -
- Dimension length x diameter - 48.5 x 67 mm / 1.91 x 2.64 in
- Weight - 420 g /0.93 lb
- Inscription - ELMARIT-R 1:2.8/24 LEITZ WETZLAR 3XXXXXX
- On the street - €EU 2,600 in 2006
- Puts-R courtesy of Mario Mazziol
| 2718151 | 2718650 | 24mm f/2.8 Elmarit-R | 1974 | 500 |
| 2766501 | 2768000 | 24mm f/2.8 Elmarit-R | 1976 | 1500 |
| 2832351 | 2834350 | 24mm f/2.8 Elmarit-R (11 257+221) | 1977 | 2000 |
| 2904801 | 2906800 | 24mm f/2.8 Elmarit-R (11 221) | 1978 | 2000 |
| 3007151 | 3009150 | 24mm f/2.8 Elmarit-R | 1979 | 2000 |
| 3071801 | 3072800 | 24mm f/2.8 Elmarit-R | 1980 | 1000 |
| 3101501 | 3102500 | 24mm f/2.8 Elmarit-R | 1981 | 1000 |
| 3152501 | 3153500 | 24mm f/2.8 Elmarit-R | 1981 | 1000 |
| 3208801 | 3209800 | 24mm f/2.8 Elmarit-R (11 221) | 1982 | 1000 |
| 3328201 | 3329200 | 24mm f/2.8 Elmarit-R (11 221) | 1984 | 1000 |
| 3370001 | 3371000 | 24mm f/2.8 Elmarit-R | 1985 | 1000 |
| 3404001 | 3405000 | 24mm f/2.8 Elmarit-R | 1986 | 1000 |
| 3428691 | 3429690 | 24mm f/2.8 Elmarit-R | 1987 | 1000 |
| 3500201 | 3501200 | 24mm f/2.8 Elmarit-R (11 331) | 1989 | 1000 |
| 3635401 | 3635600 | 24mm f/2.8 Elmarit-R | 1993 | 200 |
| 3657831 | 3658330 | 24mm f/2.8 Elmarit-R | 1994 | 500 |
| 3754126 | 3754625 | 24mm f/2.8 Elmarit-R | 1996 | 500 |
| 3783830 | 3784329 | 24mm f/2.8 Elmarit-R (11 331) | 1997 | 500 |
| 3836875 | 3837374 | 24mm f/2.8 Elmarit-R | 1998 | 500 |
| 3883247 | 3883746 | 24mm f/2.8 Elmarit-R | 2000 | 500 |
| 3949534 | 3950033 | 24mm f/2.8 Elmarit-R | 2002 | 500 |
| unknown | unknown | 24mm f/2.8 Elmarit-R | 2006 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1974-2005 | 20,200 |
