Leica 0
Revision as of 20:25, 27 April 2010 by Admin (talk | contribs)
Early Leica drawings adapted from manufacturer's brochures in The Leica Pages
0-34.jpg Preproduction series of 31 cameras, Serial #100-130, hand-made in 1923 & 1924. Since the focal plane shutter was not self capping on the first seven examples, they required the use of a lens cap which was attached with a cord to a small bracket on the camera body. This feature was retained on the second batch even though they had a self-capping shutter. The viewfinder (either folding or telescoping type) is located directly above the lens. (Image and data courtesy of Massimo Bertacchi
  • Production era - 1923-1924; 31 cameras
  • Variants - First a folding finder, later replaced by a tubular finder with crosshairs, and then finally without viewfinder
  • Body - aluminum with black lacquered brass top plate, base plate and nickel plated knobs
  • Size L x W x H - 133 x 39 x 65 mm / 5.24 x 1.54 x 2.60 in
  • Forum discussion
  • Anastigmat Lens - LLC - 112
  • Production era - 1920-1925
  • Variants - non-self-closing and self-closing lens
  • Lens mount - Fixed to camera
  • Number of lenses /groups - 4 /3
  • F stop range - f/3.5 > f/12
  • Closest focusing distance - 1 m / 3.28 ft
  • Materials - Lacquered brass
  • Weight - 135 g /4.76 oz
  • Inscription - Leitz Anastigmat 1:3,5 F=50mm
  • Designer - Max Berek, Zeiss Anastigmat lens design by Paul Rudolph (1858-1935)
Leica 0 Serial Numbers
Serial numbers from Cameraquest - total assigned numbers
100 130 O Serie 1923-1924 31
TOTAL ASSIGNED SERIAL NUMBERS 1923-1924 31
