Leica Standard (model E)
Revision as of 14:49, 29 April 2010 by Admin (talk | contribs)
1938 Leica IE, with a Leitz Elmar (I) f= 5 cm 1:3.5
  • Code names - AROOG = ALVOO + ELMAR; AROOG CHROM = ALVOO CHROM + ELMAR per Farines List; and from 1933 catalog: LEMAX = LENOT + ELMAR and in 1933 NY catalog this combination was shown as LYSTA.
  • Production era - 1932-1950; 13,545 in black; 13,680 in chrome cameras (ed. note: 12,229 less than the assigned numbers below)
  • Variants - Last of the bodies with a top-set viewfinder and without a coupled rangefinder; late versions used a type III body, identified by the strap lugs and a plug on the front where the slow-speed dial would have been installed
  • Body - aluminum with black lacquered, chrome or nickel plated brass top plate, base plate and knobs
  • Size L x H x W - 133 x 67 x 33 mm / 5.2 x 2.6 x 1.3 in.
  • Body weight - 368 g / 12.9 oz.
  • Designer - Oskar Barnack
  • Forum discussion
  • Variants - Chrome -c- and black lacquer versions
  • Brochures
Camerapedia Leica Standard
Leica Standard (model E) Serial Numbers
SN Start SN End Product Year Batch
101001 106000 Standard 1932 5000
114001 114050 Standard Chrom 1933 50
115901 116000 Standard Chrom 1934 100
123001 123580 Standard 1934 580
137401 137625 Standard 1934 225
138701 138950 Standard Chrom 1934 250
139901 139950 Standard 1934 50
141501 141850 Standard 1934 350
147001 147075 Standard 1934 75
TOTAL ASSIGNED SERIAL NUMBERS 1925-1930 58,486
147176-c-147875, 149351-c-149450, 150851-151100, 152501-c-152600, 154801-c-154900, 158301-158350, 159201-159350, 161151-161450, 163401-163450, 163951-164150, 165301-165500, 167751-168000, 168851-169000, 169201-169350, 171551-171900, 172801-173000, 173501-173650, 175501-175700, 177701-177800, 179576-179800, 180701-180800, 182501-182700, 183601-183750, 185501-185650, 185701-185800, 188301-188600, 191651-191750, 193201-193450, 194851-194950, 196551-196750, 197401-197500, 200651-200750, 201601-201700, 203301-203400, 205501-205700, 207401-207600, 210401-c-210900, 212401-212700, 213301-213600, 214401-214800, 217301-217500, 222301-222700, 224601-224800, 233501-233700, 239801-240000, 241701-241900, 244201-244400, 244801-245000, 248401-248600, 249501-249700, 251301-251500, 253601-253800, 256401-256600, 257601-c-257800, 259801-259900, 261801-262000, 264801-265000, 267901-268000, 271101-271600, 277501-277900, 278601-278800, 286501-286800, 291001-291200, 291801-292000, 292201-292400, 293901-294000, 295301-295400, 296601-296900, 299901-300000, 300101-300200, 300301-300400, 301601-301700, 303801-303900, 305701-305701, 307501-308000, 308301-308500, 309001-309200, 312001-312200, 312501-312800, 312800-313500, 314301-314500, 316701-316900, 318301-318500, 320701-321000, 322201-322700, 327801-328000, 329001-329400, 330301-330500, 330801-331000, 333301-333600, 341301-341500, 342001-342200, 348501-348600, 349051-349300, 352101-352150, 352150-353600, 353801-354000, 355001-ny-355650; 39,454 total assigned numbers 1931-1948 assigned per Serial Numbers Leica Cameras
