100mm f/4 Macro-Elmar-R
Revision as of 02:06, 16 May 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 232-helical - 11 230-bellows - 11 270-bellows-set / LLC - 179
  • Production era - 1978-1995 < 16,254 lenses including Helical and Bellows versions
  • Variants - Helical 3-cam and bellows unit without cams
  • Number of lenses /groups - 4 / 3
  • F stop range - f/4-f/22
  • Closest focusing distance - 1.10 m / 3.60 ft
  • Smallest object field - 38 x 57 mm (bellows) - 72 x 106 mm (helical)
  • Diaphragm setting /type - 8-blade
  • Angle of view diagonal - 25 degrees (bellows) - 27 degrees (helical)
  • Filter type - E55
  • Accessories - Bellows: 16860
  • Materials -
  • Dimensions length x diameter - 120 x 67.5 mm / 4.72 x 2.66 in (bellows) - 90 x 67.5 / 3.54 x 2.66 in (helical)
  • Weight - 670 g /1.48 lb (bellows) - 540 g /1.19 lb (helical)
  • Inscription - MACRO-ELMAR-R 1:4/100 LEITZ CANADA [WETZLAR] 2XXXXXX
  • Designer -
  • On the street - €EU 336-384 in 2008
  • Forum discussion
[4]
100mm f/4 Macro-Elmar-R Serial Numbers
2279851 2280850 100mm f/4 Makro-Elmar-R (bellows) 1968 1000
2290951 2291950 100mm f/4 Macro-Elmar-R 1968 1000
2390201 2391200 100mm f/4 Macro-Elmar-R 1970 1000
2416101 2417200 100mm f/4 Macro-Elmar-R (bellows) 1970 1100
2623101 2623600 100mm f/4 Macro-Elmar-R (bellows) 1973 500
2681201 2681700 100mm f/4 Macro-Elmar-R (bellows) 1974 500
2860601 2860800 100mm f/4 Macro-Elmar-R 1977 200
2883701 2885700 100mm f/4 Macro-Elmar-R 1978 2000
2926901 2928900 100mm f/4 Macro-Elmar-R (helical) 1978 2000
2933351 2933500 100mm f/4 Macro-Elmar-R (bellows) 1978 150
2973251 2974250 100mm f/4 Macro-Elmar-R 1979 1000
2982001 2982100 100mm f/4 Macro-Elmar-R 1979 100
3031801 3032800 100mm f/4 Macro-Elmar-R 1980 1000
3052601 3053600 100mm f/4 Macro-Elmar-R (helical) 1980 1000
3084501 3084950 100mm f/4 Macro-Elmar-R 1980 450
3349801 3350800 100mm f/4 Macro-Elmar-R (helical) 1985 1000
3409891 3411890 100mm f/4 Macro-Elmar-R 1986 2000
3596460 3596709 100mm f/4 Macro-Elmar-R (bellows) 1992 250
3655822 3655825 100mm f/4 Macro-Elmar-R 1994 4
TOTAL ASSIGNED SERIAL NUMBERS 1968-2005 16,254
