135mm f/2.8 Elmarit-M III
Revision as of 15:45, 15 May 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 829 LLC - 184
  • Production era - 1976-1996 < 9,850 lenses
  • Variants -
  • Type - As camera lens + optical cell unscrews for use with focusing adapter 16464 on Visoflex
  • Number of lenses /groups - 5 /3
  • F stop range - f/2.8-f/32
  • Closest focusing distance - 1.5 m /4.92 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 18 degrees
  • Filter type - E55
  • Accessories -
  • Dimensions length x diameter - 114 x 66 mm / 4.49 x 2.60 in
  • Weight - 780 g /1.72 lb
  • Inscription - ELMARIT-M 1:2.8/135 LEITZ CANADA 3XXXXXX
  • Designer -
  • On the street - €EU 960 in 2007
  • Forum discussion
135mm f/2.8 Elmarit-M III Serial Numbers
.* Lens 2728702 is Tele-Elmarit-M 2.8/90mm
.** Lens 3178214 is 135mm f/2.8 Elmarit-M
2726921 *2728920 *135mm f/2.8 Tele-Elmarit 1974 1000
2771201 2773200 135mm f/2.8 Elmarit 1976 2000
2788651 2789650 135mm f/2.8 Elmarit-M 1976 1000
2849551 2850050 135mm f/2.8 Elmarit-M 1977 500
2872601 2873100 135mm f/2.8 Elmarit 1977 500
2997001 2998000 135mm f/2.8 Elmarit-M 1979 1000
3178201 **3179200 135mm f/2.8 Elmarit-R** 1982 [1000]
3294401 3294900 135mm f/2.8 Elmarit-M 1983 500
3486701 3487200 135mm f/2.8 Elmarit-M 1989 500
3536768 3537467 135mm f/2.8 Elmarit-M 1990 700
3608020 3608119 135mm f/2.8 Elmarit-M 1992 100
3615430 3615579 135mm f/2.8 Elmarit-M 1993 150
3641826 3642125 135mm f/2.8 Elmarit-M 1993 300
3686631 3687030 135mm f/2.8 Elmarit-M 1995 400
3720303 3720502 135mm f/2.8 Elmarit-M 1995 200
TOTAL ASSIGNED SERIAL NUMBERS 1974-1995 9,850
