90mm f/2.8 Elmarit-R I
Revision as of 17:47, 10 June 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 239 / 11 229 LLC - 172
  • Production era - 1964-1983 < 29,000 lenses
  • Variants - 1-cam, 2-cam and 3-cam versions
  • Number of lenses /groups - 5 / 4
  • F stop range - f/2.8-f/22
  • Closest focusing distance - 70 cm / 2.30 ft
  • Smallest object field - 140 x 210 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E55 Series 7 + 14161 filter ring
  • Accessories - ELPRO close focusing attachment
  • Materials -
  • Dimensions length x diameter - 72 x 65 mm / 2.83 x 2.56 in
  • Weight - 500 g /1.1 lb
  • Inscription - ELMARIT-R 1:2.8/90 LEITZ CANADA 2XXXXXX
  • Designer - Walter Mandler
  • On the street - €EU 240 in 2008
  • Forum discussion
90mm f/2.8 Elmarit-R I Serial Numbers
.* Lens 1743979 is gold prototype R 2.8/90mm
1743501 *1746500 90mm f/2 *Summicron 1960 [3000]
1965001 1966000 90mm f/2.8 Elmarit-R (1-cam) 1962 1000
2011701 2013700 90mm f/2.8 Elmarit-R (1-cam) 1963 2000
2077501 2078500 90mm f/2.8 Elmarit-R 1965 1000
2094501 2095500 90mm f/2.8 Elmarit-R 1965 1000
2108801 2110800 90mm f/2.8 Elmarit-R 1965 2000
2129951 2131950 90mm f/2.8 Elmarit-R 1965 2000
2148551 2150550 90mm f/2.8 Elmarit-R 1965 2000
2170701 2171700 90mm f/2.8 Elmarit-R 1966 1000
2208101 2210100 90mm f/2.8 Elmarit-R (2-cam) 1966 2000
2267251 2269250 90mm f/2.8 Elmarit-R 1968 2000
2333801 2335800 90mm f/2.8 Elmarit-R 1969 2000
2374901 2376900 90mm f/2.8 Elmarit-R 1969 2000
2414101 2416100 90mm f/2.8 Elmarit-R 1970 2000
2442001 2444000 90mm f/2.8 Elmarit-R (2-cam) 1970 2000
2536251 2538250 90mm f/2.8 Elmarit-R (3-cam) 1972 2000
2734951 2735950 90mm f/2.8 Elmarit-R 1975 1000
2807401 2809400 90mm f/2.8 Elmarit-R 1976 2000
TOTAL ASSIGNED SERIAL NUMBERS 1960-1976 29,000
Lens superseded by 90mm f/2.8 Elmarit-R II
