90mm f/2 Summicron-R
- Leica Order No. - 11 219 - 11 254 LLC - 175
- Production era - 1970-1977 with 1-piece built-in lens hood, 1977-2000 with 2-piece built-in lens hood < 37,954 lenses
- Variants - 2-cam and 3-cam versions
- F stop range - f/2-f/16
- Closest focusing distance - 70 cm / 2.30 ft
- Smallest object field - 140 x 210 mm /1:6
- Diaphragm setting /type -
- Filter type - Series 7 (1st) E55
- Accessories -
- Materials -
- Dimensions length x diameter - 62.5 x 70 mm / 2.46 x 2.76 in
- Weight - 560 g /1.23 lb
- Inscription - SUMMICRON-R 1:2/90 LEITZ CANADA 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 384 in 2008 - $US 260 (2-cam) - 550 (3-cam) in 2010
90mm f/2 Summicron-R Serial Numbers
Serial numbers compiled from Puts Pocket Pod.*Note: Batch 2947201 is listed as Summicron-M - at least one lens in batch was -R (per Westlicht)
2400001 | 2402000 | 90mm f/2 Summicron-R | 1970 | 2000 |
2462501 | 2464500 | 90mm f/2 Summicron-R | 1970 | 2000 |
2505601 | 2507600 | 90mm f/2 Summicron-R | 1972 | 2000 |
2544501 | 2545700 | 90mm f/2 Summicron-R | 1972 | 1200 |
2627051 | 2628050 | 90mm f/2 Summicron-R | 1973 | 1000 |
2714001 | 2715000 | 90mm f/2 Summicron-R | 1974 | 1000 |
2748131 | 2748630 | 90mm f/2 Summicron-R | 1975 | 500 |
2760151 | 2761150 | 90mm f/2 Summicron-R | 1975 | 1000 |
2781651 | 2782650 | 90mm f/2 Summicron-R | 1976 | 1000 |
2811401 | 2813400 | 90mm f/2 Summicron-R | 1977 | 2000 |
2839801 | 2840800 | 90mm f/2 Summicron-R | 1977 | 1000 |
2873101 | 2874100 | 90mm f/2 Summicron-R | 1977 | 1000 |
2838801 | 2839800 | 90mm f/2 Summicron-R | 1977 | 1000 |
2880601 | 2881600 | 90mm f/2 Summicron-R | 1978 | 1000 |
2947201 | 2950200 | 90mm f/2 Summicron-M* | 1978 | (3000) |
3029801 | 3031800 | 90mm f/2 Summicron-R | 1980 | 2000 |
3046601 | 3048600 | 90mm f/2 Summicron-R | 1980 | 2000 |
3059801 | 3061300 | 90mm f/2 Summicron-R | 1980 | 1500 |
3073801 | 3075800 | 90mm f/2 Summicron-R | 1980 | 2000 |
3118001 | 3119000 | 90mm f/2 Summicron-R | 1981 | 1000 |
3129501 | 3133500 | 90mm f/2 Summicron-R | 1981 | 4000 |
3342201 | 3344200 | 90mm f/2 Summicron-R | 1984 | 2000 |
3381001 | 3381700 | 90mm f/2 Summicron-R | 1985 | 700 |
3405001 | 3405700 | 90mm f/2 Summicron-R | 1986 | 700 |
3426691 | 3427690 | 90mm f/2 Summicron-R | 1987 | 1000 |
3484601 | 3484900 | 90mm f/2 Summicron-R | 1989 | 300 |
3533968 | 3534467 | 90mm f/2 Summicron-R | 1990 | 500 |
3566873 | 3567472 | 90mm f/2 Summicron-R | 1991 | 600 |
3583861 | 3583862 | 90mm f/2 Summicron-R | 1992 | 2 |
3607620 | 3608019 | 90mm f/2 Summicron-R | 1992 | 400 |
3614980 | 3615429 | 90mm f/2 Summicron-R | 1993 | 450 |
3617882 | 3617883 | 90mm f/2 Summicron-R | 1993 | 2 |
3686231 | 3686630 | 90mm f/2 Summicron-R | 1995 | 400 |
3719603 | 3720302 | 90mm f/2 Summicron-R | 1995 | 700 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1970-1995 | 37,954 |
Lens superseded by 90mm f/2 APO-Summicron-R ASPH
