28mm f/2.8 Elmarit II
				Revision as of 18:18, 15 November 2010 by Admin (talk | contribs) (→28mm f/2.8 Elmarit II Serial Numbers)
- Leica Order No. - 11 801 - 11 802 /LLC - 145
 - Production era - 1972-1980 < 7,050 lenses
 - Variants - two other designs like pic's above, 1. version look very similar to Elmarit I (Wetzlar), but has no deep intruding lens-element, so it can be used with M5 and all other Leicas with built-in meter.
 - Lens mount - Leica M-bayonet for use with M5 + CL
 - Compatibility - Can be used on M9 cameras (without exposure metering for early lens before s/n 2314921).
 - Number of lenses /groups - 8 /6
 - F stop range - f/2.8-f/22
 - Smallest object field -
 - Filter type - Series 7 - E48
 - Accessories - Viewfinder: 12007 SLOOZ - Hood: 12501
 - Materials - Black lacquered brass
 - Weight - 225 g /7.94 oz
 - Inscription - LEITZ CANADA ELMARIT 1:2.8/28 2XXXXXX
 - Designer - Walter Mandler, Gary Edwards & Erich Wagner
 - On the street - $US 850 in 2010
| 2314801 | 2316000 | 28mm f/2.8 Elmarit (ELC) | 1969 | 1200 |
| 2459501 | 2460500 | 28mm f/2.8 Elmarit (ELC-11801) | 1970 | 1000 |
| 2523801 | 2524800 | 28mm f/2.8 Elmarit (ELC-11801) | 1972 | 1000 |
| 2543501 | 2544500 | 28mm f/2.8 Elmarit | 1972 | 1000 |
| 2733951 | 2734950 | 28mm f/2.8 Elmarit (ELC) | 1975 | 1000 |
| 2757901 | 2758150 | 28mm f/2.8 Elmarit | 1975 | 250 |
| 2768001 | 2768500 | 28mm f/2.8 Elmarit | 1976 | 500 |
| 2880201 | 2880600 | 28mm f/2.8 Elmarit (ELC-11801) | 1977 | 400 |
| 2885701 | 2886400 | 28mm f/2.8 Elmarit (ELC) | 1978 | 700 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1969-1978 | 7,050 |
Lens superseded by 28mm f/2.8 Elmarit-M III
