50mm f/1.4 Summilux-M II
  • Leica Order No. - 11 113-black - 11 100-black - 11 114-chrom /LLC - 127
  • Production era - 1961-1991 < 43,505 lenses
  • Variants - Black, chrome and 1913-1983 anniversary versions
  • F stop range - f/1.4-f/16 with full click-stops > 2028001 < half click-stops
  • Closest focusing distance - 1 m /3.28 ft
  • Smallest object field - 277 x 416 mm
  • Diaphragm setting /type - 12-blade
  • Filter type - E43
  • Accessories - Hood: - XOOIM - 12521 - 12586
  • Materials - Black anodized aluminum or chrome plated brass
  • Dimensions (length x diameter) - 54.5 x 47.7 mm /
  • Weight - 275 g aluminum, 380 g chrome
  • Inscription - LEITZ WETZLAR SUMMILUX 1:1.4/50 E46 388XXXX
  • Designer - Walter Mandler
50mm f/1.4 Summilux-M II Serial Numbers
.* Lens 2992238 is Summilux-M 35 mm f/1.4
.** Lens 3156855 is Leica Apo - Telyt - R 3,4 / 180
1844001 1846000 Summilux f= 5 cm 1:1.4 (M+S-chrom) 1961 2000
1883001 1884000 Summilux f= 5 cm 1:1.4 (chrom) 1961 1000
1884101 1885000 Summilux f= 5 cm 1:1.4 1961 900
1897001 1899000 Summilux f= 5 cm 1:1.4 (chrom) 1961 2000
1927001 1929000 Summilux f= 5 cm 1:1.4 (chrom) 1962 2000
1945001 1947000 Summilux f= 5 cm 1:1.4 (chrom) 1962 2000
1999999 2000001 Summilux f= 5 cm 1:1.4 1963 3
2028001 2029000 Summilux f= 5 cm 1:1.4 (black+chrom) 1964 1000
2039701 2040700 Summilux f= 5 cm 1:1.4 (black) 1964 1000
2048501 2049500 Summilux f= 5 cm 1:1.4 1964 1000
2071501 2073500 Summilux f= 5 cm 1:1.4 (black+chrom) 1964 2000
2198101 2199100 Summilux f= 5 cm 1:1.4 (black) 1966 1000
2220201 2221200 Summilux f= 5 cm 1:1.4 1967 1000
2308251 2309750 Summilux f= 5 cm 1:1.4 (black) 1968 1500
2345301 2347300 Summilux f= 5 cm 1:1.4 (black) 1969 2000
2418201 2420200 Summilux f= 5 cm 1:1.4 (black) 1970 2000
2503101 2505100 Summilux f= 5 cm 1:1.4 (black) 1972 2000
2568551 2570550 Summilux f= 5 cm 1:1.4 (black) 1973 2000
2624601 2625600 Summilux f= 5 cm 1:1.4 (black) 1973 1000
2628051 2629600 Summilux f= 5 cm 1:1.4 1973 1550
2821351 2822350 Summilux f= 5 cm 1:1.4 1977 1000
2848051 2849050 Summilux f= 5 cm 1:1.4 (11 114+gold bands) 1977 1000
2980551 2981000 Summilux f= 5 cm 1:1.4 1979 450
2991701 *2992700 Summilux-M f= 5 cm 1:1.4 1979 1000
3033901 3034400 Summilux f= 5 cm 1:1.4 1980 500
3076301 3076800 Summilux-M f= 5 cm 1:1.4 (black+11 100) 1980 500
3156501** 3158500 Summilux f= 5 cm 1:1.4 (black+13-83) 1981 2000
3251101 3252100 Summilux-M f= 5 cm 1:1.4 1983 1000
3340201 3341200 Summilux-M f= 5 cm 1:1.4 (black) 1984 1000
3415891 3416890 Summilux-M f= 5 cm 1:1.4 (black) 1986 1000
3444901 3445900 Summilux-M f= 5 cm 1:1.4 1987 1000
3481901 3482900 Summilux f= 5 cm 1:1.4 1989 1000
3483501 3484600 Summilux f= 5 cm 1:1.4 (platinum.150 yr) 1989 1100
3493301 3495300 Summilux f= 5 cm 1:1.4 (black) 1989 2000
3500000 3500000 Summilux-M f= 5 cm 1:1.4 1989 1
3500150 3500150 Summilux-M f= 5 cm 1:1.4 1989 1
TOTAL ASSIGNED SERIAL NUMBERS 1961-1989 43,505
Lens superseded by 50mm f/1.4 Summilux-M III
