180mm f/2.8 Elmarit-R II
- Leica Order No. - 11 923, 11 273-Apo version (shown)
- Production era - 1979-1998 < 10,499 + 500 Apo version lenses
- Variants - 3-cam or R-only versions
- F stop range - f/2.8-f/22
- Closest focusing distance - 1.8 m / 5.91 ft
- Smallest object field -
- Angle of view diagonal - 14 degrees
- Filter type - E67
- Accessories - Filter-ring: 14264
- Materials -
- Dimensions -
- Weight - 1325 g /2.92 lb
- Inscription - LEITZ APO-ELMARIT-R 1:2.8/180
- Designer -
180mm f/2.8 Elmarit-R II Serial Numbers
| 2939701 | 2940700 | 180mm f/2.8 Elmarit-R | 1978 | 1000 |
| 2983601 | 2984100 | 180mm f/2.8 Elmarit-R (3-cam) | 1979 | 500 |
| 2999501 | 2999998 | 180mm f/2.8 Elmarit-R | 1979 | 498 |
| 3126501 | 3127000 | 180mm f/2.8 Elmarit-R | 1981 | 500 |
| 3134001 | 3134500 | 180mm f/2.8 Elmarit-R | 1981 | 500 |
| 3144001 | 3144500 | 180mm f/2.8 Elmarit-R | 1981 | 500 |
| 3190701 | 3191700 | 180mm f/2.8 Elmarit-R | 1982 | 1000 |
| 3249101 | 3250100 | 180mm f/2.8 Elmarit-R | 1983 | 1000 |
| 3324201 | 3325200 | 180mm f/2.8 Elmarit-R | 1984 | 1000 |
| 3356801 | 3357800 | 180mm f/2.8 Elmarit-R (3-cam) | 1985 | 1000 |
| 3446921 | 3447920 | 180mm f/2.8 Elmarit-R (3-cam) | 1987 | 1000 |
| 3565373 | 3565872 | 180mm f/2.8 Elmarit-R (3-cam) | 1991 | 500 |
| 3617885 | 3617885 | 180mm f/2.8 Elmarit-R | 1993 | 1 |
| 3644476 | 3644975 | 180mm f/2.8 Elmarit-R | 1994 | 500 |
| 3729791 | 3730290 | 180mm f/2.8 Elmarit-R | 1995 | 500 |
| 3786360 | 3786859 | 180mm f/2.8 Elmarit-R | 1997 | 500 |
| 3798410 | 3798909 | 180mm f/2.8 Apo-Elmarit-R | 1997 | 500 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1978-1997 | 10,999 |
