180mm f/2.8 Elmarit-R I
Revision as of 22:22, 28 February 2011 by Admin (talk | contribs) (→‎Comment)
  • Leica Order No. - 11 919 LLC - 187
  • Production era - 1968-1979 < 17,000 lenses
  • Variants - 1, 2 or 3-cam, ELC & ELW versions
  • Number of lenses /groups - 5 / 4
  • F stop range - f/2.8-f/22
  • Closest focusing distance - 1.8 m / 5.91 ft
  • Smallest object field -
  • Diaphragm setting /type - 8-blade
  • Angle of view diagonal - 14 degrees
  • Filter type - Series 8 + 14165
  • Accessories - Filter-ring: 14165
  • Materials -
  • Weight - 1325 g /2.92 lb
  • Inscriptions - ELMARIT-R 1:2.8/180 LEITZ CANADA 2XXXXXX
    ELMARIT-R 1:2.8/180 LEITZ WETZLER 2XXXXXX
  • Designer -
  • On the street - €EU 280 in 2010
  • Forum discussion
180mm f/2.8 Elmarit-R I Serial Numbers
2161001 2161500 180mm f/2.8 Elmarit-R 1966 500
2226001 2226500 180mm f/2.8 Elmarit-R 1967 500
2247901 2249900 180mm f/2.8 Elmarit-R (ELW.2-cam) 1967 2000
2280851 2283350 180mm f/2.8 Elmarit-R 1968 2500
2354301 2356300 180mm f/2.8 Elmarit-R (3-cam) 1969 2000
2455501 2457500 180mm f/2.8 Elmarit-R (3-cam) 1970 2000
2498101 2499100 180mm f/2.8 Elmarit-R 1971 1000
2511601 2512600 180mm f/2.8 Elmarit-R 1972 1000
2542501 2543500 180mm f/2.8 Elmarit-R 1972 1000
2673201 2674200 180mm f/2.8 Elmarit-R (2-cam) 1974 1000
2698601 2699600 180mm f/2.8 Elmarit-R (2-cam) 1974 1000
2753051 2754050 180mm f/2.8 Elmarit-R (3-cam) 1975 1000
2838801 2839800 180mm f/2.8 Elmarit-R (ELW.3-cam) 1977 1000
2913101 2913600 180mm f/2.8 Elmarit-R 1978 500
TOTAL ASSIGNED SERIAL NUMBERS 1966-1978 17,000
Lens superseded by 180mm f/2.8 Elmarit-R II
