O
Revision as of 17:30, 4 January 2011 by Admin (talk | contribs)
Forum discussion
OAGNO Medical copy stand using PLOOT 1938-19?? -
OAPDO Medical copy stand using PLOOT 1939-19?? Italian item
OCEGO Leica Ig body 1957-1963 -
OCLOM Visoflex II with 4x 90 magnifier, bayonet mount 1962-19?? -
OCMOR Visoflex lens 1:3.5 / 65 Elmar 1960-1970 11062
ODULO PROON reflex housing + PAMOO right-angle magnifier 1940-19?? -
OEFGO Leica If body 1952-1957 -
OEGIO Leica If with viewfinder for 50 mm lenses; Leica Ic in 1950 NY catalog 1952-1957 -
OEINO Leica If with viewfinder for 50 mm lenses and ELMAR 1952-1957 -
OERDO Summicron 90 short mount with preset diaphragm Forum discussion 19??-19?? 11126
OESBO Summicron 90 short mount with standard diaphragm ring Forum discussion 19??-19?? 11124
OEUPO Extension ring for Summicron (II) f= 9 cm 1:2 with !:4.5 reproduction ratio 1959-19?? 16474
OHEBO-M 19??-19?? -
OHIKO Stereo unit Stereoly complete with Stemar lens OISBO, prism, and viewfinder for screw-mount cameras 1954-1957 -
OHIKO-M Stereo unit complete with Stemar lens OISBO, prism, and viewfinder for M-mount cameras 1954-1957 -
OHTEO OIPVO stereo viewer + OIFCO light unit 1950's -
OHUGO No. 1 light yellow filter; paired for Stemar mount ca.1959 NY item
OHVIO Orange filter; paired for Stemar mount ca.1959 NY item
OHWLO UVa filter; paired for Stemar mount ca.1959 NY item
OIASO Stemar stereo lens for M-camera 1954-1957 -
OIDYO Cylidrical chrome, half frame viewfinder used with Stemar stereo unit similar in shape to SBOOI 1954-1957 -
OIFCO Stereo light unit 1950's -
OIGEO Stereo lens hood for use on Stemar when prism is not attached 1954-1957 ELC
OIMPO Prism for front of Stemar for subject distances beyond 10 feet; hinged front cover added in 1955 1954-1957 -
OIPVO Stereo viewer with independently focusing eye pieces; brittle plastic housing 1950's -
OIRZO-M Stereo unit complete with Stemar lens, OIGEO hood, prism, and viewfinder for M-mount cameras 1954-1957 -
OIRZO-S Stereo unit complete with Stemar lens, OIGEO hood, prism, and viewfinder for screw-mount cameras 1940-1953 -
OISBO Stemar stereo lens 1954-1957 -
OIVHO Rear cover for bayonet-mount Stemar 1950's -
OIWKO Lens cap with bayonet for Stemar 1950's -
OIXMO Rear cover for screw-mount Stemar 1950's -
OIZQO Rear cover for Stemar prism 1950's -
OKARO Orange filter to improve contrast between rangefinder images for FOKUS or Leica IIc, IIf, IIIb, IIIc and IIIf in chrome Forum discussion [1] 1939-1962 14058
OKBZO Diopter correction lens for near-sightedness for Leica IIIg 1960-19?? 14064
OKLMO Connecting piece to convert Focomat Ic enlarger to copy use with column VOOQF and arm OKYNO 1956-19?? 16744
OKVCO Diopter correction lens for astigmatism for Leica IIIg 1960-19?? 14066
OKYNO Arm for Focoslide Valloy II enlarger 1956-19?? 16748
OKZPO Copy stand 25 1/2 inch column with guide rail 19??-19?? 16747
OLEYO Single exposure camera with IBSOR shutter used with Elmar 3.5, 5, and 10.5 cm lenses 1934-1935 JCB's a little...15
OLIGO Single exposure camera with Ibsor shutter used a variety of lenses 1934-1939 JCB's a little...15
OLLUX Hood for 35mm f/1.4 Summilux I 1961-19?? -
OLORA Single exposure camera without shutter 1936-19?? NY item
OMAPO Close focus accessory with parallax for 50 mm 1:4 lens; per Lager: catalog item only, no known examples are known 1939 -
OMEXO Complete copy stand including OOZEG, OOZAB, ZOOXY, VALOO, LVFOO, KGOON, OPKOM, ROOYH and ONLIO 1951-19?? Forum discussion
OMIFO Close focus accessory with parallax for 90mm f/4 Elmar lens 1949-1968 -
ONLIO Canvas carrying bag portion of OMEXO for Focoslide 1951-19?? -
OOBAZ Late version focusing stage known as Focoslide for Screw-thread cameras using N series helical focusing lenses and extension tubes 1958-19?? 16607
OOEUK 16 x 14 1/2 inch light box with 4 lamps 1951-19?? 16763
OOEVM 9 1/2 x 7 inch light box with 4 lamps Fontenelle archive 1951-19?? 16762
OOFRC Remote shutter release and winder operated by two chords 1936-19?? -
OOGAN OOBAZ Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 1958-19?? 16632, 16603-3/8" bush
OOGIT OOBAZ Focoslide + VXOOT + VALOO for Elmar (III) f= 5 cm 1:3.5 1958-19?? 16633, 16604-3/8" bush
OOGUM OOBAZ Focoslide + ZOGOO for Focotar 1958-19?? 16634, 16612-3/8" bush
OOMAP OOTGU Focoslide + ZOGOO for Focotar 1956-19?? 16682, 16674-3/8" bush
OOMEX OOTGU Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 1958-19?? 16633, 16604-3/8" bush
OOMYL OOTGU Focoslide + VSPOO + VTROO for Summicron 1956-19?? 16681, 16678-3/8" bush
OORES Rotating focusing mount with screen; early versions with single lens; 1937 double; slide-in and bayonet versions 1934-1950's JCB's a little...17
OOTGU Late version focusing stage known as Focoslide for M-cameras using N series helical focusing lenses and extension tubes 1957-19?? 16680
OOZAB Focusing stage known as Focoslide; early version had single bar on spring-loaded arm; later version with adjustable positioning bar; last version was H-shaped to clear flash bracket lug Fontenelle archive 1938-1957 -
OOZAB-G Focusing stage known as Focoslide for accepting Leica IIIg camera 1951-1957 -
OOZEG Folding horse-shoe type copy stand portion of OMEXO for Focoslide 1951-19?? -
OOZIS Collapsible, horseshoe shaped copy stand 1939-19?? -
OOZKU Set of 5 extension rings for OOZIS copy stand 1939-19?? -
OOZMY Complete copy outfit including OOZAB, ZOOXY, ROOYH, VALOO, LVFOO and OPKOM release 1952-19?? -
OPDUR Medical copy stand using OPRAL and OPFAS 19??-19?? -
OPFAS Medical copy stand using frame with handle and chest support 1932-19?? -
OPKOM Cable release portion of OMEXO for Focoslide; 20 inches with lock 1951-19?? Fontenelle archive
OPRTO Diopter correction lens for near-sightedness for Leica IIc, IIf, IIIb, IIIc and IIIf 1951-19?? 14060
OPRYL Medical copy stand using lower body strut with webbing sling 19??-19?? -
OPSVO Diopter correction lens for astigmatism for Leica IIc, IIf, IIIb, IIIc and IIIf 1951-19?? 14065
OQWCO Lens cap Forum discussion 19??-19?? 14028
OQZIO Diopter correction lens for near-sightedness for Viso magnifiers LVFOO and PEGOO 1960-19?? 14063
ORAKO Orange filter to improve contrast between rangefinder images for FOKUS or Leica II, III and IIIa in black or chrome Forum discussion 1936-1962 14057
ORBMO Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder 1941-19?? NY item
ORESO SPOOV copy stand + OORES rotating stage 1936-19?? -
ORLEO Diopter correction lens for astigmatism for Leica M-cameras to 1977 1956-1977 14062
ORMGO Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder 1941-19?? NY item
OROBA Cap used with XOOIM hood (in reverse position) on a 50 mm Summilux Forum discussion 19??-19?? -
OROLF Lens turret for 3 lenses with handle; no more than 250 were made OROLF image 1960 [2] [3] [4]
ORPDO A42 slip-over, chromed plated brass with felt lining front cap for 21mm f/3.4 Super-Angulon-R 1958-1963 14031
ORPNO Front cap for f = 12.5 cm 1:2.5 Hektor - with rear cap HGOOI it became a container for the lens JCB's a little...If 19??-19?? -
ORQPO Hood for Summarex f= 8.5 cm 1:1.5; early version was black with clamping screw, later chrome for bayonet fitting 1951-1960 12525
JCB's a little...IIIf
ORTOX Diopter correction lens for near-sightedness for Leica M-cameras to 1977 1951-1977 -
ORTUX Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder Forum discussion 1933-19?? 14061
ORTVO Cap that screws into body lens opening 19??-19?? 14055
ORUXO Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder 1938-19?? 14069
ORWYB Diopter correction lens for near-sightedness for Leica IIIb 1939-19?? NY item
ORYCE Diopter correction lens for astigmatism for Leica IIIb 1939-19?? NY item
ORYFO Rear dust cap for screw lenses 1951-19?? 14050
OSBLO Magnifying eye-piece for 5 or 9 cm screw lens; converts lens to small telescope - see Photography Accessories for Monoscopes 1954-19?? Cosmonet OSBLO
OSERO Diopter correction lens for astigmatism for Viso magnifiers LVFOO and PEGOO 1960-19?? 14069
OTDYM Visoflex II without magnifier, bayonet mount Forum discussion 1962-19?? 16455
OTEMO Stemar attachment for subject distance of 3 - 10 meters; only 20 of these were delivered 1950's -
OTHEO 5 x stereo viewer 1950's -
OTPLO Telyt 20 cm 1:4.5 for Visoflex 19??-19?? JCB's a little...11
OTPRO 1:1.25 magnification accessory for OTZFO focusing mount used with Visoflez II/ III ? 16471
OTQNO Visoflex ring addapter for Elmar 9 cm 1959-19?? 16468
OTRPO Visoflex extension tube for near focusing with universal focusing mount Forum discussion 1959-19?? 16471
OTSRO Adapter for use of 13.5 cm Hector lens with OTZFO focusing mount used with Visoflex II/ III Forum discussion 1959-19?? 16472
OTVXO 5x chimney eyepiece for Visoflex II Forum discussion 1962-19?? 16461
OTXBO 4x 90 degree eyepiece for Visoflex II Forum discussion 1962-19?? 16461
OTYDO Visoflex II without magnifier, screw mount Forum discussion 1962-19?? 16457
OTZFO Universal focusing mount for Visoflex II/ III for use with 1:3.5 / 65 Elmar, 90mm Elmarit and 135mm Elmar lenses Forum discussion ? 16464
Forum discussion
OUAGO Visoflex addapter for using Elmar 9 cm Forum discussion 1959-19?? 16467
OUBIO Visoflex II/ III adapter for Hektor 125 mm; Elmar and Hektor 135 mm in short mounts; TELYT Visoflex lenses Forum discussion [5] 1959-19?? 16466
Forum discussion
OUCLOO Visoflex II with 4x 90 magnifier, screw mount 1962-19?? 16458
OUEPO Close-focus adaptor to be used with either the Summicron (II) f= 9 cm 1:2 in ZOOEP/16463 or 16462 adaptor or the 2.8/135 in 16462 adaptor. This usage will yield a 1:4.5 reproduction scale. Forum discussion 1959-19?? 16474
OUFRO Extension ring for 35/50mm M-bayonet lenses with 1:1 ratio ? 16469
OUFRO Visoflex extension ring for 5 and 3.5 cm lenses 1959-19?? 16469
OUTSO Projection head to fit ground glass screen of Focoslide or Reprovit 1951-19?? 16750
OVAFO Base and 48 x 1 5/8" diameter column for Reprovit I 1951-19?? -
OVURO Valoy II copy stand with 32 inch column and UWOOS bracket for Focoslide 1960-19?? 16701
OZTFO Connector ring for the 65mm Elmar and 90 mm Elmarit to R-body Forum discussion 19??-19?? -
OZTNO Cable release addaptor for using screw release on M-camera Forum discussion [6] 1955-19?? 14088
OZTOM Double cable release for M-camera Forum discussion 19??-19?? 16491
OZUPO Visoflex I housing - JCB's Visoflex I Collection Fontenelle archive 1951-19?? 16484
OZWTO Double cable release for Visoflex I with time lock screw; early chrome and later black versions JCB's a little...11 Fontenelle archive 1951-19?? 16492 Fontenelle archive
OZWTO-M Double cable release for Visoflex M-camera with time lock screw; early chrome and later black versions Forum discussion 1951-19?? 16491 Fontenelle archive
OZXOM Visoflex I with 5x chimney eyepiece, bayonet mount 19??-19?? 16482
OZXVO Cable release for Visoflex I for screw cameras only; pneumatic so called "sports release" 1954-19?? 16493
OZYXO Visoflex I with 5x chimney eyepiece, screw mount 1951-1954 16485
OZYXO-M Visoflex with 5x chimney eyepiece, bayonet mount 19??-19?? 16482
