D
| DACMO | Replacement for core spools | ? | - |
| DACNO | Replacement for core spools | ? | - |
| DAMCO | Replacement spool | ? | - |
| DANCO | Replacement spool for 120 film | ? | - |
| DAMOT | NY Code for BINDOMAT | 1949 | - |
| DAMOX | NY Code for BINDOMAT | 1953 | - |
| DBOOF | - | ||
| DBZOO | - | ||
| DCBOO | - | ||
| DCOOE | - | ||
| DECIMAR | Binoculars – 10 x 60 – 5.8 deg | 1937-1959 | - |
| DECIMARIT | Binoculars – 10 x 60 – 5.8 deg – CF type | 1937-1959 | - |
| DEEMH | Iris diaphram for Molna BEECH microscope lamp | 1939 | - |
| DEEML | Bulb for Molna BEECH microscope lamp | ? | - |
| DEEMN | Bulb for Molna BEECH microscope lamp | ? | - |
| DEEMO | ? | - | |
| DEEMP | Bulb for Molna BEECH microscope lamp | ? | - |
| DEEQK | Lamp system for microscope side lighting | - | |
| DEFOO | Spiral developing tank, 400 ml | 1938 | - |
| DEOOC | Small CHICO flash, capacitor type, with ivory plastic housing | 1954-1959 | - |
| DEOOG | Small CHICO flash, capacitor type, with black plastic housing | ? | - |
| DFHOO | Small CHICO flash, capacitor type for Leica IIf and Leica IIIf | 1954-1965 | 15608 |
| DFOOB | Flash bracket of ivory plastic | 19??-19?? | 15609 |
| DFOOF | Small CHICO flash, capacitor type for Leica IIf and Leica IIIf with cable | ? | - |
| DGKOO | Flash cable to connect CHICO to other cameras | ? | 15612 |
| DHMOO | Ivory plastic box for CHICO | ? | - |
| DHLOO | Plastic box, black, for CHICO | ? | - |
| DIOOY | Diopter check wheel from -5 to +4 | 1955 | - |
| DIREKT | Self-timer | 1932 | - |
| DIROM | Self-timer | 1935 | - |
| DIRON | Self-timer for periods of up to 10 ½ sec. | 1936 | New York version |
| DLUUW | - | ||
| DMUOO | Visoflex intermediate ring used to attach Summicron 50 mm to bellows or enlarger No. 17672 | ? | - |
| DNWOO | M>L39 adapter ring for Focomat IIc | - | |
| DOBOR | - | ||
| DOOCQ | Focotar 4.5/50, adaptor for the Reprovit II - ROOXU | 1951 | - |
| DOOHF | Focotar 4.5/50 | 1953-1975 | 17581 |
| DOOIT | Magnifying lens Elmar f3, 5 50mm | ?-1953 | replaced by the Focotar 1:4.5 50mm (I) |
| DOOLU | Spirit Bubble Level | - | |
| DOORX | Extension ring for Focotar; adapter to mount Paxette lenses on Valoy II enlarger Forum discussion | 17585 | |
| DOOLU/S | Spirit level accessory shoe, in black, nickel or chrome | 1929-1939 | - |
| DOOSL | 25” clamp bracket for micro stand SPMOO | 1938 | - |
| DRXOO | Aluminum container for one cassette, and later, for 2 cassettes | 1952 | 14010 |
| DTEEO | MONLA microscope lamp green filter | 1930s | - |
| DTEEP | Green filter for photo purposes | ? | - |
| DUFAN | Dufaycolor Type A | 1936 | NY item |
| DUFAS | Dufaycolor Type C | 1936 | NY item |
| DUFAT | Dufaycolor Type D | 1936 | NY item |
| DUFUZ | Dufaycolor Type E | 1936 | NY item |
| DUFEN | Dufaycolor for emphasis | 1936 | NY item |
| DUFEP | Dufaycolor for Kodachrome | 1936 | NY item |
| DUFES | Dufaycolor for Kodachrome professional conversion filter | ? | NY item |
| DUFEX | Dufaycolor for flash Kodachrome | ? | NY item |
| DUFEZ | Dufaycolor for Kodachrome, Skylight | ? | NY item |
| DUFTU | Dufaycolor Type B for tungsten | 1936 | NY item |
| DUUER | - | ||
| DUUNV | - | ||
| DUUOI | - | ||
| DUUPW | - | ||
| DUUQK | - | ||
| DUUVZ | - | ||
| DUUXA | Prado 150 projector with Dimaron 10 cm 1:2.8 lens | 1948-ca.1967 | - |
| DUUYO | Prado 150 projector with Hektor 8.5 cm 1:2.5 lens | 1948-ca.1967 | - |
| DXOOK | Rubberized shoulder strap | 1960 | 14094 |
| DXOOL | Rubberized shoulder strap | 1962 | - |
| DXOOM | Dark leather shoulder strap | ? | - |
| DXOON | Calf leather shoulder strap with rubber top | ? | - |
| DYUUI | Mirror for the "Leitz Betrachtungskasten" Projector Fontenelle archive | 1937-?? | - |
| DZUUH | - |
